Posted By: HangOver Jammed rudder pins - 04/29/06 04:36 PM
I did a quick search in forums but couldn't find anything new to try so thought i'd ask.
Basicly my rudder pin has jammed in the casting, it's off the boat but i left the pin in the casting for lack of a better place to keep it over the winter and it is now jammed such that no amount of oil and hitting it with a mallet will free it.
can anyone offer any other suggestions?
thanks, Andy
Posted By: Anonymous
Re: Jammed rudder pins - 04/29/06 05:57 PM
Andy:
You might try some CLR. I got a zipper loose with it.
Doug Snell
Hobie 17
Sunfish
Soon to be Mystere 4.3
www.tcdyc.com Posted By: dave mosley Re: Jammed rudder pins - 04/29/06 07:40 PM
liquid wrench will free anything
Posted By: HangOver Re: Jammed rudder pins - 04/29/06 08:00 PM
i should have said i'm from the uk and while i haven't seen the products you mention over here i have been trying a penetrant oil to no avail
Posted By: fin. Re: Jammed rudder pins - 04/29/06 08:04 PM
I think CLR is an acronym for calcium, lime and rust. It is used to clean bathroom tile and the like.
Posted By: MauganN20 Re: Jammed rudder pins - 04/29/06 08:36 PM
ACK to liquid wrench!
PB Blaster. Find some at your autoparts store where all the spraycan stuff is. Will free frozen spark plugs in engine blocks. Let it soak for about 10-15 minutes then hit it with a second soaking, wait another 5, then hit it one more time and then try to free it.
If that doesn't work, cut pin, drill it out, and go buy another.
Posted By: Jake Re: Jammed rudder pins - 04/29/06 09:48 PM
What kind of boat? (it might help to understand what the pin and casting look like).
Re: Jammed rudder pins - 04/29/06 11:43 PM
Had a zipper that was corroded REAL bad to the metal slide. Soaked it overnight and it cam loose. Try CLR (Calcium, Lime and Rust) if you can find it.
Doug
Posted By: HangOver Re: Jammed rudder pins - 04/30/06 03:13 PM
the boat is a hobie 16, I've got the casting soaking in some oil again now but if that doesn't free it up i'll have a look around the auto parts stores when they open again on tuesday (it's a public holiday on monday)
thanks for the suggestions, i'll let you know how i get on
Posted By: hobie1616 Re: Jammed rudder pins - 04/30/06 06:52 PM
After soaking it in penetrating oil for a while you might tap on the pins with a punch from underneath.
If you can't break it loose it might be easier to remove the gudgeons from the boat and cut the pins. Repalce the gudgeons and pins and polish the holes in the rudder castings before assembly.
Posted By: HangOver Re: Jammed rudder pins - 05/05/06 10:10 PM
finaly got it out, since it was already off the boat i had a guy with a vice have a go at it and it came straight out
