Posted By: sail6000
05 proposed Formula 20 rules outline - - 05/17/05 07:11 PM
Mission
For people of good will to race together for the enjoyment of the sport in accordance with the Racing Rules of Sailing and in the spirit of rule #2 of fair sailing under ISAF rules –To compete within recognized principles of sportsmanship and fair play.
Intent
To race 20-ft catamarans of various design features as a fleet on a first across the finish line wins basis, both in around-the-buoys and distance racing.
Amendments
We wish to keep the rules as simple as possible and rely on the good intent of sailors in accordance with standard safety requirements per sailing rules, required gear, and class principles as stated. Amendments per majority vote of active class members.
Formula 20 Class Rules.
LENGTH - 20 ft one inch maximum (Stern to bow measurement)
BEAM - 8.5 ft –max.hull W L measurement at rest
WEIGHT –MIN boat wt 385 LBS
SAIL AREA – –> MAINSAIL = 210 sq/ft including mast, 53 sq/ft jib, and 270 sq/ft spin
*All measurements per standard current ISAF measurement rules
Roller furlers and main reef points may be used.
All teams to use the same set of sails for a regatta or distance race, but may be replaced if severely damaged to allow a team to continue racing with the permission of race organizers per event racing instructions.
Mainsails are to be within measurement and pattern of, or identical to existing I-20 mains -
All sails are to be commercially available to any and all sailing teams min one month before an event or sails may not be used for that event.
Existing class cat designs will be accepted as listed per mfg. or sailmaker.
Racing will be on the honor system, but any boat may be challenged and checked along with the protesting party also being checked for weight and sail area compliance.
CREW – One or more may be crew. All must be capable of righting from a capsize.
CREW WEIGHT -A class min of 320 Lb. Weight may be carried by lighter teams to meet minimum weight requirements.
BOAT WEIGHT -fully rigged with all attached gear and sails
MASTS May be of aluminum and/or carbon fiber or combinations of non conducting materials in standard section tapered or uniform.
A Max 32 ft length
With-standard wire rigging in any configuration
HULLS - Any standard material or configuration
BOARDS - Any standard material or configuration
RUDDERS– Any standard material or configuration
SPIN POLES –A maximum 14 foot length may be used made of any material in standard configuration with snuffer configuration of any type.
CLASS EMBLEM - The starboard side of the mainsail MAY carry the Open -Formula-20 logo of racing Formula 20s along with individual sail number for scoring purposes.
Dispensation
Older existing designs may be given dispensation per F-20 committee by owners request in design feature trade offs.
Example = an existing heavier mast rig and standard class smaller mainsail in compensation for larger spin area, again only applied to older existing designs per owners request.
Intent
Amendments
A Max 32 ft length
Dispensation
