Posted By: Dazz Dyneema jib halyard - 08/15/08 04:57 AM
Hi everyone
Im about to replace the jib halyard on the capricorn, I would like to use dyneema but i am concerned about the stretch as my halyard is not adjustable on water.
are there many peeps using dyneema over wire now?
Posted By: mikekrantz Re: Dyneema jib halyard - 08/18/08 02:15 PM
Use vectran if you are concerned about creep.
Posted By: TEAMVMG Re: Dyneema jib halyard - 08/23/08 06:41 PM
Don't do it unless you can rig an easy on the water tensioner
Posted By: davefarmer Re: Dyneema jib halyard - 08/24/08 04:13 AM
I'm happy using Vectran.
dave
Posted By: Anonymous
Re: Dyneema jib halyard - 08/25/08 12:32 AM
Dazz,
the last owner of your boat was a know nothing layabout. Whatever you do change all his systems and rope selections etc.
Posted By: Dazz Re: Dyneema jib halyard - 08/27/08 07:37 AM
Thanks Scarecrow, I'm sure TA will be pleased to hear that :P
There are some realy good setups on this boat that I havnt seen anywhere else.
I have made some changes, done a bucket load of maintenace (all standing rigging, diamonds, all shock cord, new sheets..) mostly so the boat is easier to deal with on a week to week basis.
The forestay is being replaced today, the furler is coming out as the jib doesnt furl anyway. The choice between a rope or wire jib halyard determins the type of pulley that will be swaged onto the forestay.
Im sticking with wire.
Posted By: Juha Re: Dyneema jib halyard - 06/23/15 07:55 AM
Hi there,
I would like to replace the jib halyard on my Nacra Infusion mk II. What line are recommending for the halyard? Should I use Dacron or some other material, such as Vectran?
Here's the Nacra's manual how to replace the halyard ->
http://goo.gl/ohNDxi .
Thanks in advance.
Posted By: Dazz Re: Dyneema jib halyard - 06/25/15 12:06 AM
What a fortune teller you turned out to be Scarecrow. by the time I had finished it was virtually identical in setup to the C2, so when i made the move to a new boat, everything was the just the same but faster/easier to sail.
Juha, any old piece of string will do for a nacra halyard. If you have the stock hook/ring arrangement then there is no load on the halyard at all.
Posted By: Gilo Re: Dyneema jib halyard - 06/28/15 08:11 PM
Vectran has a very bad UV resistance. I don't think the line will last longer than 3 years. My preference would be dyneema.
Setting up an adjustable jib halyard is quite easy and definately worth the investment if you are racing.
