Posted By: uogecko Infusion mainsheet reeving - 03/26/10 11:13 PM
The online manual (older) for the Infusion setup does not show the same blocks that actually ship with the boat now (HC8454 on the traveler up to HC7668 on the boom). Has anyone found a reeving diagram that is helpful?
Thanks
Posted By: uogecko Re: Infusion mainsheet reeving - 03/26/10 11:15 PM
This is the system that shipped with the Infusion:
http://www.harken.com/OneDesign/tornado.phpThis is the best picture I can find, but it's almost impossible to follow:
http://www.murrays.com/mm5/merchant...&Category_Code=N-C&Store_Code=MS Posted By: TEAMVMG Re: Infusion mainsheet reeving - 03/27/10 05:30 PM
Remember that the top block should be at 90 degrees to the main lower block, every one tries to line them up above each other
Posted By: NacraKid Re: Infusion mainsheet reeving - 03/27/10 06:10 PM
as macca told me "work in towards the guts!"
First bit is the hardest to work out if you don't know how to do it, the old system on the manual and this new one reve up the same at first except that the double in the middle has been moved out to each side.
Posted By: uogecko Re: Infusion mainsheet reeving - 03/27/10 07:36 PM
Thanks but I was really hoping to find a clear diagram. I do know that the top blocks should be perpendicular to the lower blocks but both top and bottom should rotate freely, right? Harken includes little metal "limiters" that can be used to keep them from rotating. I know I'll want the lower blocks to rotate freely but what about the uppers?
Posted By: CatSailingHu Re: Infusion mainsheet reeving - 03/28/10 07:06 AM
remove the small metal limiter...
Posted By: macca Re: Infusion mainsheet reeving - 03/28/10 02:21 PM
Good question guys....
When we did the manual it was prior to the newer style Harken blocks coming out.
I will see if I can get a new demo done up.
Posted By: macca Re: Infusion mainsheet reeving - 03/28/10 02:28 PM
As a tip in the meantime:
Always have the top block at 90deg to the bottom one.
Start at the cleat (through the ratchet backwards)
go through the back sheave on the top block
then on the side sheave on the bottom (from the back side towards the front)
then to the front sheave on the top block
then to the bottom block (side, line goes from front to back)
from here its herd to go wrong, you just follow your way from the back towards the front.
Posted By: uogecko Re: Infusion mainsheet reeving - 03/28/10 04:27 PM
A new guide would be awesome! Meanwhile thanks for the tip!
Posted By: uogecko Re: Infusion mainsheet reeving - 03/29/10 06:04 PM
Harken just sent me a 10:1 reeving guide for the Infusion mainsheet setup I have. It's too big to attach to this post so let me know if you want it and I can email it to you.
Posted By: JFR Re: Infusion mainsheet reeving - 05/07/12 08:10 PM
Sorry for asking. Have my boat miles away and need to order new mainsheet. What length are you using (I remember it to be 13.5 meter? but it sounds lengthy) provided you use it back-to-back. Also, am I right in assuming tapering would be arround 3 meters to be able to lock it upwind in full swing and outside tapered area (using normal mast rake).
Cheers,
Jonas
Posted By: stampede Re: Infusion mainsheet reeving - 06/07/12 06:37 AM
hope this helps
http://www.harken.com/pdf/4450.pdfcheers from germany
in case you are looking for a 10:1 combo i can provide a diagram on request.
cheers from germany
Posted By: Just Sail Re: Infusion mainsheet reeving - 06/12/12 02:45 PM
Here is a reeving diagram for the infusion mainsheet system. Its a reworked of the original.pdf version that Uogecko sent me last year, now in .jpg
Posted By: stampede Re: Infusion mainsheet reeving - 04/15/13 09:04 PM
Anyone Here To provide some advice on harken 378&379 12:1 mainsheet combo reeving Diagramm?
All help is appreciated
Greetings Form germany
Posted By: Just Sail Re: Infusion mainsheet reeving - 04/16/13 01:30 PM
http://www.murrays.com/mm5/merchant...roduct_Code=28-121&Category_Code=N-CVery confusing but perhaps you can make it out from this diagram...failing that send an email to Harken
