Posted By: uogecko
Infusion rudder tuning - 06/08/10 11:58 PM
I've been setting up my Infusion according to the online assembly manual. I've measured the distance between the 2 rudders and set the trailing edge to be about 2mm further out than the leading edge (exactly as the manual states). The manual shows the measurements taken directly below the rudder castings (about even with the bottom of the hull).
As you can see from the attached photos there is about a 1/4 of an inch gap between each rudder arm and the tiller connector. That means that when I turn the rudders the little rubber piece that bends doesn't have much space to stretch and resists the turning quite a bit. In fact, if I let go over the tiller the rudders will auto-center pretty quickly.
Anyone have experience with this? Did I take measurements from the wrong part of the rudders?
