Posted By: flyingfool
Newbie to Hobie - 05/30/07 03:22 PM
a few questions as I'm new to Hobie 16.
I just bought a '75 H16 last fall and have been fixing her up. Anyhow I have a bit of sailing experience but none on Hobie's. Anyhow my questions.
1) My mast to tramp frame has a metal cup on the frame and a metal ball on the base of the mast. Do these sit metal to metal? Or is there some sort of liner that should be on one side or the other to prevent wear and lubrication?
2)How tight should the shroads and fore stay be? Do they make some sort of tool to leverage it so they are tight to insert the clevis pins?
3) The pylon to tramp frame has a single bolt and a plastic nut at each pylon. On mine these are loose so that I can spin the bolt. Is this correct? Or should these be tightened? If so to what torque value? It seems to me with these being loose that it allows for a lot of flex or play between the two hulls.
4) Sail numbers. What is the significance of these? I have a H16 and my first 2 numbers are 16. Is this just a coincidence? What about the remaining numbers?
Thanks
Thanks
