Posted By: Anonymous
Hull repair help - 06/15/09 05:53 PM
Anyone got any great ideas how to fix this gash? It has partially penetrated the foam and there appears to be some delamination around it. I'm thinking of cutting it out, but I don't know what kind of foam to use or how to make it the right thickness so I can glass in a couple of layers of laminate to rebuild the hull exterior.
Re: Hull repair help - 06/15/09 07:39 PM
One suggestion I got this afternoon is to just cut out the damaged foam and fill the area with epoxy, then build up the hull exterior.
Posted By: hobie1616 Re: Hull repair help - 06/16/09 12:52 AM
You can cut out the damage and fill with two part foam.
Re: Hull repair help - 07/13/09 01:08 PM
I ended up cutting out about a one inch by four inch section of foam. I drilled a few holes around the "wound" in the delaminated areas and injected epoxy until it oozed into the opening. After that set I filled the hole with Marine Tex. It looks good... We'll have to see how it holds up!
