Posted By: Captain_Dave
For newbies...what worked and what didn`t ! - 09/13/05 04:41 PM
As some of you know, I restored an old 1977 H16 (see post "major restorations" for more details) and have finally been sailing it - loving it even more than I thought I would. In the course of my restoration which began last January, I have asked many questions on this site and received much advice - most of it very, very good. So, mostly for the other newbies like me, I would like to respond to some of the advice and mention a few things regarding what worked for me and what did not.
(1) Sailing gloves...don`t leave home without em! And, keep a spare set for visiting crew members.
(2) Boat shoes/water socks are a MUST HAVE item for you AND YOUR CREW. You may think you (or your crew) can sail barefoot, and actually you can...but when it comes time to right a capsized, freshly waxed H16 on a beautiful breezy day, you`ll be wishing to God you had those rubber shoes between your bare feet and that hull.
(3) Someone mentioned using cheap, industrial saran-type wrap over the entire mast while trailering as well as carrying along basic cleaning supplies. This sounded a little uneccessary to me, but since I had some of the wrap (10 bucks for about a thousand feet), I figured why not. This was great advice. After doing 18 miles on a gravel road in the rain, the only clean thing I had left was that mast and the new white sails in my catbox. The wrap takes less that 3 minutes to apply and costs just pennies. Take a razor so as to remove it easily with one slice up the luff track.
(4) Restoring the colour on an old vinyl tramp with automotive vinyl dye works quite well. It is cheap and easy. Be sure to remove all contaminants first and be prepared for occassional touch-ups.
(5) I had read some information regarding the old-style Seaway jib cars being difficult to uncleat under load - this is an understatement of the highest order! I subsequently asked for advice regarding their replacement and the general consensus was...I was a newbie...don`t worry about it...and, if it ain`t broke don`t fix it -BAD ADVICE. These cars have a serious design flaw (in my opinion) - they came out of the box broken! If you have the money, replace them. They really do suck.
(6) Spend the time to put together a great tool kit with lots of spare parts. Use your imagination as to what might break (pretty much anything) or get dropped in the drink. Stock up on what you can afford, you won`t regret it - I guarantee it! The stresses on these boats can be incredible.
(7) Carry a properly rigged righting line (and righting bag with block and tackle if sailing solo) the FIRST time you go out. Do not assume you will not need it because you will "only be sailing slow". This boat is awesome in a good wind, and you WILL need this equipment. This was definitely GOOD ADVICE.
(8) Do not even think about sailing this boat solo your first time out...unless you really, REALLY understand sailing and the power of this boat. Even then, it is best to take someone with you.
(9) Do not be afraid of this boat - be informed and respectful. However, at times the H16 will most certainly scare the stuffing out of you. To be truthful, I was a bit scared prior to sailing the H16 - it is my first sailboat - though I am an experienced boater and navigator... Read lots of catamaran stuff, get some videos, understand ALL the parts of your boat and their individual state of repair. Be equipped for every eventuality you can imagine.
(10) Velcro line-wraps are a great invention.
(11) Carry a short (4 to 6 ft) length of rope with you when you sail. It may come in handy. I broke my tiller yoke in a strong wind that was blowing me onshore towards a cliff. That rope allowed me to quickly lash my tiller and get back to safety. And yes, I had a spare yoke in my tool kit!
(12) Krylon Fusion adheres and holds up amazingly well to a properly prepped old rudder (albeit I can only vouch for fresh water sailing). They look brand new...it is a great product.
(13) Bridle vanes, windvanes, 8 track tape - whatever... MUST HAVE - even the first time out!
(14) Mast bearings are definitely equal to more than the some of their (single) part. Don`t forget one. The luff-track bearing from Hobie is pretty handy too.
(15) Stepping the mast may surprise you the first time you do it. It is heavier and more awkward than you may think - even for a strong guy. Be sure to have someone else there the first time FOR SURE - and have a plan. With good technique, it gets a lot easier. As for the advice that "two people can step a mast WITHOUT a stepping link kit" - this is bad advice. Though I am sure it is possible, I am also sure it is quite dangerous for the inexperienced...get the stepping link kit and buy a spare too!
(16) Check and re-check that all your lines and travellers run freely and and have no tangles BEFORE you leave the beach - EVERY time you go out. I seem to have a brain-block on this one and it can really be a pain in the butt when you forget to do this.
(17) Silicon spray is something you need on a regular basis, especially on the travellers. Keep some in the tool kit.
(18) I LIKE my Baby-Bob mast float a lot - if only for that little bit of confidence and security it imparts. Besides that, I really like the look of it too. Nobody has called me a sissy yet (not to my face anyhow - thats all I care about). I say; BABY-BOB and proud of it! We can always start a support group if the ridicule gets too much!
(19) With the above information and more - especially regarding the books and videos - you can be flying your hulls, completing your tacks, and righting your capsized boat the very first time you go sailing. BUT, be prepared for the experience, it is powerful and addictive... truly one of lifes` greater pleasures - at least it is for me!
Hope this helps someone,
Dave
Dave
