Posted By: Dan Berger
OK, now that I have it, what do I do with it?? - 02/20/04 01:58 PM
Just thought I would start a new thread about sailing with a Hooter (or blaster).
I installed a hooter on my 14 and I have sailed it a few times. Unfortunately, the boat has spent a lot of time on its side, but the rest of the time was a blast (or hoot, or whatever). I have only had a chance to sail it in moderate wind, too.
Some back ground on my set-up: I am not running with a jib--too many strings on the tramp and I don't think I could get the right angle for the pole under the bridles. I use the same holes in the tramp for the Hooter control blocks that the jib would use. I also set up a barber haul system that pulls the jib sheet out to the front corner casting.
OK, questions:
UPWIND: I tightened the Hooter halyard pretty tight and sailed it just like a big jib. I expected not to sail as close to the wind as with a jib, and I was right. I set up a barber hauler and played with the slot, too. I found that I needed to open it just a little because if I didn't, it made the front part of the main stall. I also found that the leeward stern was REALLY submerged. Moving far forward helped this, but it really made for a nervous ride. For those of you who have sailed with a Hooter (Rick, Bob), does this sound right?
DOWNWIND: I didn't play with halyard tension, so I left it pretty tight. Since the rig moved forward, it naturally loosened the leading edge of the Hooter. The edge of the Hooter curled like a spinnaker, so I sailed the boat as if it were a spinnaker by pumping the Hooter and steering down when it heated up too much. I had the main almost all the way in (and tight) and I used full barber haul to take the jib sheet to the side frame. I noticed in some of Bob's pictures, he is going down wind with the main traveler pretty far out. I thought that would put too much pressure on the mast and that when going down wind, you over rotate the mast while under traveling the main...Again, sound right??
I figured I would just chase Bob around the course at SF, but I would like to be a little prepared!!
OK, questions:
