Posted By: Sycho15
Questions cocerning the H14Maxi - 04/13/04 06:34 PM
Would someone be so kind as to help me figure out the correct angle of mast rake for a H14Maxi? Either the actual degree of rake, or a measurement off the main halyard, as per directions below:
Set the trampoline frame to level (both fore-aft and side-side).
Set a board across the trampoline frame from one side to the other.
Let the main halyard hang perfectly verticle (weight the end), and move the board along the trampoline frame until it contacts the halyard.
Measure the distance from the center of the mast mast-beam to where the halyard contacts the board.
I want to make my own shrouds that will connect straight to the hulls like the H16. I need to know which angle to set the mast, then I can figure out the rest.
Also- how long is the spinnaker pole? I will most likely mount it with a carriage bolt like Dan did.
