The first half of the hull was primed with epoxy mixed with 407 and it had been fared out - dried. The lay-up had a slight amount of 407 in the first application of cloth then the second layer of cloth was straight epoxy.
On the second half of the hull, which I will lay up in the next week or so, most of the hull is H-60 with some H-80 in the stress spots. Most of the hull is just bare foam since I used Gorilla Glue and was able to fare the hull very easy. I will skim the hull with epoxy and a slight amount of 407 then go back and start the lay-up of the first layer of carbon. Follow-up with the second layer with straight resin, and of course vacuum bag it out. All of this this will be done in one session.
The skim out bog is very runny. Usually I use one pump resin, one hardener, and a scoop of 407. For this bog I use 6-R, 6-H, and 1-2 of 407. Here is a pic of working the bog.
Description: working the bog into the cloth
