Catsailor.com F-16 wings..
Posted By: Rolf_Nilsen F-16 wings.. - 09/27/07 11:39 AM
I suppose most have seen the A-cat wing buildt by Ben Hall after input from the Cogito team. There is a thread on it in the open forum, but it seems like there have been a bit too much F-16 talk and F-16 members being too vocal "out there" <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> so I'll ask my questions here instead.
I wonder what the lift to drag ratio for a wing is compared to a wingmast with soft sail. I know the theorethical gains are on an order of 2-3, but I dont know about practical use.
In real world, how much faster would a wing make an F-16 upwind?
Since the wing dont have a mainsheet, just an AoA adjustment, would it be a challenge to reinforce the wing for spinnaker use? All forces would have to go down the stays, but since the wing have a larger crossection than a mast.. Wouter?
The F-16 rules specify a soft sail. But if the A-cat wing testing proves the wing to be both practical and robust. How about it? What are people thinking when they see this? I know Timbo is a supporter of wings <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />
I think Ben Halls wing project is really cool. If it proves both fast and robust, I would be interested in playing with wings (might even have some fun with wings anyway, just for fun, when other projects are finished).
Posted By: Anonymous
Re: F-16 wings.. - 09/27/07 12:00 PM
I'd like to see if I understand the principle of the thing... Is the issue that with a soft sail, as the speed of the air over the sail increases, part of the available energy gets lost deforming the sail surface, but that a solid wing doesn't deform as much and so more energy gets translated into lift?
Personally I think this is a really interesting project (perfect for A Class, as others have pointed out) and one we should all keep an eye on, but considering the general philosophy of formula sailing ("mildly restricted class rules indicative of a controlled development class... small advancements in handling and general behaviour of the designs are allowed") I don't anticipate a move away from soft sails for existing formula classes in the near term.
Posted By: Hans_Ned_111 Re: F-16 wings.. - 09/27/07 12:22 PM
1.4.4 The distance, at right angles to the mast axis, measured around and back to the same point is referred to as the "mast circumference". The mast circumference shall not be more than 0.500 m.
This is box rule 1.4.4 of the F16 class. It is not possible to make a wing with a circumference more than half a meter.
That's besides all the technical problems there will be in sailing behaviour, but it is always possible to have a try.
Hans
Posted By: Rolf_Nilsen Re: F-16 wings.. - 09/27/07 12:30 PM
Hans, this is just for fun, toying with the idea. If we as a class want to go that direction we would need to change the rules and vote over it of course. I just want to hear what others think about these things.
Mark, the wing dont deform as much as a sail, the pressure differences are larger for less drag and you can avoid the separation bubble just behind the mast on the windward side (you get those even with wingmasts).
Re: F-16 wings.. - 09/27/07 12:33 PM
Absolutely. I was just trying to preempt anyone who might be thinking it could be possible at some point in the future to change the rule (Rolf seemed to be entertaining such an idea) by pointing out that you also run into the basic class philosophy expressed in 2.3.1.
Posted By: fin. Re: F-16 wings.. - 09/27/07 12:36 PM
The rig I have provides me with enough challenges! I'll leave wings to the more capable and adventurou$. <img src="http://www.catsailor.com/forums/images/graemlins/wink.gif" alt="" /> They're neat to look at though and I'm certainly not opposed to them.
Posted By: Hans_Ned_111 Re: F-16 wings.. - 09/27/07 12:38 PM
I know it is just for fun Rolf, but people don't always read what is mentioned the comment was only to prevent a heavy discussion, maybe people start to think we want to change the rules because of this wing on the A.
It is by the way not new that this is tried out on the A class there was a Swiss guy i think in 1988, who did try it. But it did not work, weight and trimming was a big problem and special on the downwind leg. I hope Ben will sail it at the worlds so i have a better look at it.
Hans
Posted By: Matt M Re: F-16 wings.. - 09/27/07 01:14 PM
Hans
Every few years someone comes out with a wing. Given the advancement in sail and mast materials, the added advantage of a solid foil has to be much less than it used to be. The other issue is that to gain the full advantage of this type of addition (also holds true for foils, but even more so) the other limiting factors of the box rule like beam and length really hinder the true potential of the feature.
Intial test have shown the wing is faster in certain conditions and cretain point s of sail. It is also more difficult to set up, some more expensive and restricts the boat even more in what conditions it can be used. Ben will have it at Worlds. Over a wide range of conditions I do not feel it is flexible enough to anything more than a very large topic of discussion at the event. Long term the class will continue as it has in the past.
My $.02,(.005 Euro) but it interesting to watch .
Matt
Posted By: mini Re: F-16 wings.. - 09/27/07 01:27 PM
Why do select numer of people insist on requiring a "Class" to develope their concepts?
No one is stopping anyone from taking a boat and adding foils, wings, or any number of other mdifications. If you can make it work, great, start your own class.
Most people can not admit that they are the issue with their getting better results in their sailing. It has to be the result of their boat, or their rake, or thier weight, not the fact they are not as good a sailor as the person who beat them. A class needs at least some consistancy to grow. I am all for radical ideas and development, but it does not mesh with a large class organization. I love the F16 concept and would like to see a world wide class not just a few guys tinkering in their garrage.
You want to get really radical, there is a group for you. Give Steve Clark a call and get into the C class.
Posted By: Wouter Re: F-16 wings.. - 09/27/07 01:45 PM
I don't see a problem here. On conventional masts the bending of the top is necessary to get control over the draft and twist of the sail high up. Ergo the hound fittings can not be placed to high on the mast. Especially not since that aggrevated the bending of the mast in the middle (spreaders) where you actually don't want it to bend.
With a wingsail you can relieved of that necessity and so you can place the hound fittings at the spinnaker gate if you want to. As such all the spi loads will go down the stayes as addited tension and down the mast as compression; you have lost the much more damaging bend loads.
With this you just need to make sure the stays themselves and the attachment points on the hull can take the new loads and you are done. I dare venture that the basic 4mm 1x19 and attachment points I have now are sufficient to handle this already.
Posted By: Wouter Re: F-16 wings.. - 09/27/07 02:14 PM
When Phill Brander, Kirt Simmons and myself wrote and perfected the class rules, making use of many good suggestions by the early F16 sailors, we actively ruled out a wing sail. This is not to say that we intended it to stay forbidden for ever.
I think we all saw the class rules as a living thing and understand that at times the class rules need to be amended to garantee the continued succes of the class, just as much as disallowing things is required at times to garantee the same.
Additionally it was considered valuable to allow experiments in a controlled environment so they could both proof or disproof themselves. I feel Rolf has understood that part of the F16 rules very well. He even mentioned it himself during the T-foil discussions of several months back.
Basically the construct was a follows. Elements that were considered prohibitively expensive, cumbersome or inaccessible to the large majority of the F16 target group were banned by the rules. Wingsails were on of them. Elements that were expected to become practical, affordable and accessible within a relatively short time frame were allowed. The latter included carbon masts and T-foil rudders as well as the general use of carbon, kevlar and high performance sail cloths like cuben fibre and the "sail drive" laminates. One could say the class was geared towards making the most of the refinements encountered during its first decade.
A provision was added where an experimental craft deploying an outlawed component could be allowed to enter F16 races and possible be scored as well. An official request to the local F16 head or the International body is required for that and these may turn down your request if they feel that there is a good reason to do so. This provision is included to allow geeks to try out new stuff on the F16's. The deal they can get is that if they can proof it to work, to be affordable and accessible to the large majority of F16 sailors then a F16 rule change may follow.
This concept is fully intended to avoid losing the game in the future as some classes did when the asymmetric spinnaker was introduced on cats. If such a development comes along in the future then I feel the F16 class such serious consider adopting it.
Basically you sometimes have to go with the times (adopt new technologies) for survival even if that means a temporary setback to the class.
If you want to see what happens when you don't do this then look at the Unicorns, Old Tornado's, Taipans and Spitfires. Brilliant craft in their own right, but nevertheless they are losing the game against never designs that can make use of the improvements made since these classes were launched.
But even more importantly I believe that the F16's as they are now are pretty efficient already. As such I believe 90% of the hot topics like full foiling and the wingsail will fall down when put to the test against well designed conventional boats. When that happens then the whole discussion becomes mute and such a thing can be extremely healthy to the class as you have ended the discussion beyond any doubt, second guessing or hard feelings.
What I'm trying to say here is that it may actually be alot smarter to allow such things as the wingsail to be tested inside your class structure (but in a controlled manner) then disallowing it upfront. It was this realisation that lead to the open structure in the class rules (we allow alot of things and materials while others except the A's simply don't) and the provision (even stimulation) of testing new concepts on the F16's against conventional F16's.
And to finish this line of reasoning off. I found new developments and their testing to be a promotional gift from God. Every sailor out there loves to read about new stuff and do comparisons between old and new. It also gives the class a very "can do" mentality that many sailors appreciate. You attract the brightest minds and most proliferic homebuilders to your class. You get awarded with a thriving class with many active members and a well respected stature in the catamaran scene. All of these are worth alot of temporary setbacks when you have to make a choice between them. However, often you don't need to choose between these and with careful guidence they can be made to enchance one another.
An example of the last is the creation of a healthy turn-over of boats. I refer to my departing brief for more info on that. Slow development (= slow outdating of boats) is GOOD ! Because it takes long enough for a boat to become outdated and uncompetitive, but when it does it becomes a very attractively prices entry point for newbies who will not be held back much at all by a small technical disadvantages when they still have to learn so much. Take a look at the F18's for an example of that. Nacra Inter 18's won't win you a World or European championship but it does bring in lots of new members to the class and keeps boat builders afloat through spare parts.
So Rolf if you want to, then go ahead. You got my help !
Just make sure that practicallity, affordability, accessibility are included in the design stages or just accept your setup will not be awarded an "experimental dispensation"
And just to make perfectly clear; an craft on an "experimental dispensation" can never become an F16 champion even though he may be scored 1st. The dispensation is only there to proof yourself and your concept in the large fleet, not as a "cheat route to a championship".
Posted By: scooby_simon Re: F-16 wings.. - 09/27/07 06:49 PM
My reaction would be that I'd love to give it a try, but I do not have 200 hours spare to build one (time was quoted on a Sailing Anarchy thread on this A class wing).
My second reaction is I'd hate to see what would happen to the rig if you wash it while sailing in waves and 25kts of wind.
My third reaction is. Lets watch with interest and see what happens. Maybe one day, but not in the forseable future.
Let people with fuller pockets develop it and then see what happens. Flying a kite off it might also be an "interesting exercise".
People my jump and ask why I don't want to ban this like variable trim rudders. The simple reason is that this may well be retro-fittable to current platfrom, where as my research shows that the variable trim issue would cause us to redesign our boats totally.
Posted By: Stewart Re: F-16 wings.. - 09/27/07 07:36 PM
The thing I am interested in is how much or little pressure is on the wing "main sheet".. The old wrist gives up around 30 minutes on the water after the wrist reconstruction.. I believe Miss Nylex also had a 2:1 main..
The issue is mounting a kite.. and how that will change the main characteristics.. How a wing will take the kite loads etc..
One the development side.. I fully expect the wing will be banned in F16 asap.. As soon as one appears..
You must admit we have had this tendency even under your chairmanship..
Posted By: Wouter Re: F-16 wings.. - 09/27/07 08:04 PM
I admit that we had our disagreements in the past about what could be allowed and what shouldn't. On the other hand have you checked who kept the carbon masts in the F16 class, the carbon beams, the Kevlar, nomex and all other kinds of materials like Cuben Fibre ? And lets not forget the T-foils and even the banana boards and canted boards !
Yes. under my tenure the glueing in of the beams was forbidden. So too continiously adjustment of the mast rake and the ability to rake the mast to windward. And a mast height limit was introduced into the class rules.
Looking over this comparison I say my rep sheet is pretty favourable in the way of allowing new
stuff.
With respect to the wing if the choice was out to me then I would look closely at its survivability, rightability when singlehanding, it performance (gain ?), how practical it is in transport and its costs. If a favourable judgement can be passed on all of these points then yes I think I'll be a long way towards being convinced that it should be allowed. Still, I don't expect this to happen in reality, mostly I expect the gains made by the wing around the bouys in a fleet to be to small to really be attractive when compared to the ease of the conventional rig.
So like others I don't see introduced to the F16's any time soon.
Posted By: Stewart Re: F-16 wings.. - 09/27/07 08:07 PM
**chuckles** not that we don't trim the boat by weight distribution now..
Thanks for the chuckle.. <img src="http://www.catsailor.com/forums/images/graemlins/grin.gif" alt="" />
Posted By: phill Re: F-16 wings.. - 09/27/07 10:07 PM
Rolf,
I agree with Hans.
Talk about wings and the pros and conns but once you start talking about putting them on an F16 it is bad for the class's image.
It undermines confidence in the stability of the class rules.
The wing is clearly and intentionally outside the rules and any boat with such a fixture could not be called an F16.
Add two feet to your hulls, and you can within the class1 18sq rules, have a legal craft. Although many believe it was Wild Turkey's wing that significantly contributed to the loss of interest in the class1 18sq class.
Posted By: TonyJ Re: F-16 wings.. - 09/28/07 12:06 AM
You have a class in it's infantasy, with a hand full of boats being sailed around the world, still looking for main player manufactures to get involved,you have countries with out associations, a country with 20 boats sailing under the radar and there is talk of adding a wing to the rules.
It dosn't even make interesting reading.
TJ
Re: F-16 wings.. - 09/28/07 12:27 AM
Then feel free to move along.
Posted By: Rolf_Nilsen Re: F-16 wings.. - 09/28/07 09:43 AM
All interesting reactions to what I tought was a fun question to tumble around with.
Once it is clear a wing is against the class rules, I dont see the harm in discussing the pros and cons of a wing. I firmly believe in open discussion and information exchange, even in the ugly face of politics. Philosophically, some of the opinions voiced here saying that discussion of a topic is damaging for the class is pretty interesting. Especially so considering the virtues modern western society was tufted on and what happens when we deviate from these ideals. Enough said about that, but I fear we will have an ideological showdown sometime in the future.
Matt M, congratulations on being selected for building the moulds and hulls of Bens new boat. It must have been very interesting to be part of this project.
Your and Hans points on downscaling problems is good information. I guess we all will follow Ben as closely as possible at the worlds. Part of my question was just how much more efficient would a wing be today against current rigs. You pretty much answered that, and we will see the results from the litmus test shortly. Interesting times..
Re: F-16 wings.. - 09/28/07 12:53 PM
The history of modern western society also demonstrates how easily people misunderstand each other.
Posted By: Matt M Re: F-16 wings.. - 09/28/07 02:21 PM
TJ
A bit harsh but true.
None of this has any real relavance to the Class organization, and presents a real deterent to the continued growth of the class.
Being at least partialy involded in all of these options and being someone who is interested in their potential, someday I would like to find the time to dabble myself. But, I would not want any of these things incorporated into the F16 though as it does not make sense.
To really make foils an advantage, the beam is way to small on our boats. To gain any real advantage with a wing both the beam and water length are too small. To have a 2 man boat that has good pitch numbers the length needs to closer to 18 feet. All of these items point to an already existing class - 18SQ If you guys really want to dable, you need to dirrect your verbal efforts on reviving this class.
Matt
Posted By: warbird Re: F-16 wings.. - 09/29/07 01:19 AM
Perhaps the wing thought is not applicable to F16, but that does not mean that F16 sailors should not throw the idea around..Wings on an H17...then clip ons for 18 and 16 qnd some people making them for H14s.....Gettaway.....
The boat with the best resale value in this country is definately the H17....??
Hobie clearly see the commercial value in the wings....
so is that value real in sporting endeavours?
Contempt before investigation is the play of the frightened and ignorant.
Personally I do not see the value in wings unless solo and wanting to compette against two up boats.
In F16 this might not make sense as I imagine the one up boats are already competitive.
And there in lies the rub.
Competitive...for that is where the excitement is.
Simply having a faster boat is only fun for those with big egos and low self-esteem.
I drove a lot of miles in a Miata MX5....which a lot of people say is a girls car.
I live on a long and very windy and hilly road. This car was a huge thrill and easily holds the record in against even the latest BMW sports convertible V8 400 horse $200K speedster much to the chagrin of it's pathetic owner.
Oncethe Miata hits the highway it is an underpowered, bumpy little girls car....but in its place it is a giant killer.
So, if people want wings..maybe a manufacturer like Hobie need to create the class or sailors who like wings need to create their own class....people are so disappointed with the loss of the 17. Maybe an F16 sailor who wants wings need to flag the F16 and get an H17....
F16 has an avid following of people who are happy with the platform and want to sail their best against other like minded individuals and attract more.....
You might end up with rudder foils but no wings.....where you do end up is dependant on the enrolement of the most people in the idea.
The minute talk is not allowed though....it is a faciest regeim and that is likey to drive people away, not encourage them.
Posted By: Robi Re: F-16 wings.. - 09/29/07 01:51 AM
Warbird:
Did you read the entire thread? The discussion is not about the wings the H17 uses, but instead a hard wing-sail.
Posted By: gree2056 Re: F-16 wings.. - 09/29/07 03:24 AM
Surely Warbird just made a mistake, I kept reading hoping he would reveal that he was joking.
Posted By: warbird Re: F-16 wings.. - 09/29/07 04:38 AM
Sorry, got up early to watch the rugby, ........I'll have a granny-nap and try to think a little more clearly in the future.
Posted By: phill Re: F-16 wings.. - 09/29/07 06:48 AM
Warbird,
You have illustrated the point that Hans was making.
People don't always get the full understanding.
In this case you misunderstood the meaning of wings.
Others could have a more subtle missunderstanding regarding how such a discussion could influence the F16 rules regarding wing sails.
There are many who watch the forum that do not post and therefore there would be no opportunity to correct their missunderstanding.
I have misunderstood things like this myself.
IN the context of this thread my view is that any boat 16 ft long with a solid wing is not an F16 no matter what the other specs are.
The F16 rules do not allow it.
The potential for confusion/misunderstanding begins as soon as the words F16 and Wings appear in the subject together.
These things are interesting but need to be discussed in a manner such that there can be no misunderstanding.
While we could talk about placing a wing sail on a 16ft platform, I think the concept of a modern wing sail within the rule set of the Cat 1 18sq is a much more interesting and viable concept.
BTW:-
If we were talking about the H17 type of wings.
This was allowed for when the rules were drawn up provided the craft meets the beam regulations.
Posted By: Marcus F16 Re: F-16 wings.. - 09/30/07 10:23 AM
I hope the fellow that is sailing that "A" has a few spares....if he cartwheel's the thing....I imagine it would be a mess.
Also expensive mess.!!
Posted By: Buccaneer Re: F-16 wing sail - 09/30/07 07:13 PM
Wing sail? $$$$$$$$ <img src="http://www.catsailor.com/forums/images/graemlins/cool.gif" alt="" />
Posted By: Wouter Re: F-16 wings.. - 10/01/07 11:15 AM
Very preliminary but here is one comment that answers your question (as taking from the latest A-cat race) :
>>The wing didnt win, although Ben is very fast. ... . He didnt capsize and on Sat when it was
>>windy and puffy I was pacing him upwind on the first beat. Once we went around the top mark he
>>was gone, way deeper and faster. He said later that upwind he was pinching and needed to put the
>>bow down and go.
Source :
http://www.catsailor.com/forums/sho...umber=119992&page=0&vc=1If this is indeed true (which need far more testing to determine) then this may actually mean that it is not attractive for F16's. Afterall we have the spinnaker for downwind work and we already go very deep and fast there. A fuller wingsail with slots won't do much then as the spinnaker is rotating the apparent wind over the mainsail to almost an upwind setting anyway. Also the spinnaker will be providing 80% of the power, thius implying any mainsail gains are devided by a factor of 5 and could well be negligiable in the overall picture.
Personally I believe this to be actually be a DISADVANTAGE of the wing sail. A sailor sheets the mainsail out to reduce power and lifting. Letting out the traveller instead will also work but many have found that this looses too much drive (and speed) at the same time as well. Try it yourself on your boat. I mean controlling the heel with the mainsheet and then with ony the traveller. When using the traveller you'll be losing pointing ability and speed every time you travel out. I don't see how this can be different with a wingsail.
Basically as will all new concepts. You get advantages ONLY at the expense of a set of disadvantages. If the first set is more important in achieving your end goals (win a bouy race) then the development is succesful. Otherwise it will fail. Also what may be succesful on a spinnakerless A-cat may well not be succesful on a cat with a spinnaker sail.
All very interesting.
Posted By: Stewart Re: F-16 wing sail - 10/01/07 03:53 PM
quote from the builder/owner Ben Hall..
"The cost of the materials in the wing were right around $2000 (1400 Euro at today's rate). A total of around 300 hours (about the same as one of the A Cats I built from scratch) went into building the wing. If I had to build it again the time would be about 100 hrs less."
Posted By: Wouter Re: F-16 wing sail - 10/01/07 04:00 PM
Basically 10.000 USD for a wingsail.
A soft sail rig costs about 5000 USD.
Posted By: Stewart Re: F-16 wing sail - 10/02/07 09:53 AM
Wouter where did you get those figures from?
Ben Hall stated the figures his wing cost..
Posted By: Marcus F16 Re: F-16 wing sail - 10/02/07 11:51 AM
He engineered them...... <img src="http://www.catsailor.com/forums/images/graemlins/tongue.gif" alt="" />
Posted By: Wouter Re: F-16 wing sail - 10/02/07 12:23 PM
Labour hours are not for free, pick an hourly rate and the do the math ourself.
Posted By: Stewart Re: F-16 wing sail - 10/03/07 05:16 AM
Its a fudge then..
Posted By: Tony_F18 Re: F-16 wing sail - 10/03/07 10:07 AM
Build it in China! $1/h should cover it.
Posted By: Timbo Re: F-16 wing sail - 10/03/07 11:00 AM
You meant a dollar per day, not per hour. At least they let their kids work 15 hour days though, so you will get your money's worth...
Posted By: Wouter Re: F-16 wing sail - 10/03/07 11:51 AM
Would you order a refined and delicate piece of equipment like a wingsail with a 1 USD/ hour labour force ?
Posted By: Tony_F18 Re: F-16 wing sail - 10/03/07 11:58 AM
Sure, why not.
(Its probably where 90% of all my other delicate equipment comes from!)
Posted By: Stewart Re: F-16 wing sail - 10/03/07 03:47 PM
Let me see..
Look up.. see a light globe/fitting? Where do you think 85% of these are made?
you have a LCD screen in your laptop? a LCD TV? Like to guess where these were made? What about those who purchase/swear by IBM computers?..
Ok not all factories in China make quality products.. But there are a growing number who do.. Add to this eastern Europe (where the second level gliders are manufactured)... and India..
Given time and transfer of technology I would suspect they could make one.. Then that is only my opinion..
Posted By: ncik Re: F-16 wing sail - 10/03/07 10:56 PM
The Bladerider moths are built in Asia somewhere. After a few teething issues with construction, they are fine now.
The latest issue of Professional Boat Builder (free at
Pro Boat Builder) has an article about the latest sail production in Asia that is being used by some very big name manufacturers. Some are claiming better manufacturering practices because more time can be spent on the product. They also talk about the living and working conditions though, which western society would not put up with in these times. An interesting read and generally a very good magazine for boaties, not just builders.
