Posted By: aodhan F16 Jib for Taipan - 07/16/09 04:33 PM
Hi all,
I am in the process of installing a selftacker on my Taipan 4.9 and was wondering if anyone had a Jib for sale that might work.
Also if anyone had one made would they still have the measurements used.
Thanks
Aidan
Posted By: LuckyDuck Re: F16 Jib for Taipan - 07/16/09 07:00 PM
Where are you located Aidan. I have a jib from the Blade that I have never used. Ed
Posted By: aodhan Re: F16 Jib for Taipan - 07/16/09 07:40 PM
I am located just outside of Toronto in Canada. I will send you PM to discuss
Posted By: CaptainKirt Re: F16 Jib for Taipan - 07/19/09 07:09 PM
Make sure the distance from the front hull tangs to the main beam are the same between the two boats-
Kirt
Posted By: aodhan Re: F16 Jib for Taipan - 07/19/09 11:55 PM
Kirt,
Thanks for the advice. I will check it out.
/ Aidan
Posted By: Cab Re: F16 Jib for Taipan - 07/20/09 12:47 AM
Also, the blade jib tacks to the spin pole, not to the bridle forestay connection.
Posted By: aodhan Re: F16 Jib for Taipan - 07/20/09 03:24 AM
I was planning on installing a compression post between the bridle connection and spin pole and doing the same on the taipan but thanks for the info
