stealth marine F16 needs a new daggerboard!
Posted By: sindrulf
stealth marine F16 needs a new daggerboard! - 05/28/12 05:32 PM
Suddenly today the leeward daggerboard broke in half while we were out in the waves. I am trying to contact John Pierce. Is he still active with his boats?
Posted By: Jalani
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 06:09 PM
The Stealth F16 uses a standard 49er daggerboard. Any 49er supplier could sell you one.
John is still around and making to order. He can be contacted via email at stealthmarine(at)tiscali.co.uk
Posted By: sindrulf
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 07:16 PM
Wow! Nice to know. Thanks!
Posted By: sindrulf
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 07:28 PM
Oh my god they were expensive!
Ovington Boats have them at 577GBP. Do you know of any other shops in europe?
Posted By: Rolf_Nilsen
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 07:52 PM
Build one wink
Or repair the broken one, if you still have both parts..
Posted By: pgp
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 08:34 PM
Speaking of building. Is vacuum bagging small parts (dagger board size) worth the effort? I'm doing something similar and it seems good vacuum pumps are expensive.
Posted By: Jalani
Re: stealth marine F16 needs a new daggerboard! - 05/28/12 08:57 PM
Try Simon Hiscocks at Schock Sailing:
Schock
Re: stealth marine F16 needs a new daggerboard! - 05/29/12 06:40 AM
If you are getting into building, get a vacum pump. If you have a compressor you could consider a cheap venturi vacum pump. Alternatively pick up a used refrigderator compressor from a recycling center.
Posted By: waynemarlow
Re: stealth marine F16 needs a new daggerboard! - 05/29/12 09:23 AM
I think the later Stealths has a specific board and not the 49ER which the early boats had. Length was the same but very different in chord width.
I have a spare wider 49er style board which is sitting in the back of the garage which I could sell for not a lot of money, where are you based ?
Posted By: Cab
Re: stealth marine F16 needs a new daggerboard! - 05/29/12 12:18 PM
Pete,
I have had great luck with one of these. No oil. Does not get hot even when running for 12 hours straight. Around $250 seems to be the going price on ebay for a used one.
http://www.ebay.com/itm/Welch-2585B...ps&hash=item43af0f721e#ht_522wt_1398
Posted By: pgp
Re: stealth marine F16 needs a new daggerboard! - 05/29/12 01:09 PM
I'll give it a look thanks! What was the application?
© 2024 Catsailor.com Forums
