Posted By: Wouter
Discussion ! ISAF or TEXEL poll came in as 2:2:2 - 08/13/01 08:31 AM
Discussion ! ISAF or TEXEL or other poll came in as 2:2:2
<br>
<br>Obviously there is a need to discuss the pros and Cons of the systems and determine which of the two will be the defaukt F16HP system in order to calculate the handicap.
<br>
<br>To start the discussion a bit :
<br>
<br>Texel :
<br>
<br>- Simple clear and understandable to all, it is well documented . Only has three variables in main formula "Rated weight, Rated sailarea and Rated length" These three variables are calculated using more variables such as luff lengths and mast side length.
<br>
<br>- The three main variables are also the once that are fixed in the F16HP rule : Rated weight is fixed at 250 kg's (100 kg's boat and 150 kg's crewweight), mainsail area max 13 sq. mtr. and max length = 5 mtr. (Rated jib area is also used by we use this as the equalizer)
<br>
<br>- NO influence on number from different style of boards or having carbon mast.
<br>
<br>- Genaker rating is " on and off" style not proportional.
<br>
<br>- Texel rating is know to be of the mark when it comes down to rating non genaker board to genaker boats. And catrigged boats to non catrigged boats
<br>
<br>
<br>ISAF :
<br>
<br>-Rates more things such as Carbon mast and and rates boards proportional as well as the genaker area.
<br>
<br>- ISAF probably is more internationally recognized than Texel.
<br>
<br>- ISAF is more complex than Texel and is using much more formula's
<br>
<br>- ISAF is reported to be based around the Texel main formula but I have troubkle finding similarities in the formula. However both system rate non genaker , non carbon, boardless boats exactly the same, so the claim could be true.
<br>
<br>- ISAF, I'm suspicious about the rating of the boards. Example Standard Taipan 4.9 with genaker is just as fast or faster than F18 under texel but about under ISAF the same boat with teh max genaker size of 21 sq.mtr. has a rating difference of Taipan 4.9 - F18 = 1,0176 - 1,0060 = 0,0116 = 1,16 %. And this is purely caused by the Taipan 4.9 boards. The heavier Stealth with less sailarea and smaller luffs is rated just as fast purely on the makeup on the boards. My own calculations are more in compliance with Texel. Using ISAF could well give tje Taipan alot more jib area to compensate for its board makeup. A more striking example is the Cirrus Ecole, I now that one points at least as high as the F18's Tiger and Inter 18 but it gets rewarded by an extra handicap point for using the tornado centreboards which don't go very deep.
<br>
<br>- ISAF may well have the same catrigged versus sloop rigged inequality as Texel has.
<br>
<br>Other system :
<br>
<br>- Which other system ? D-PN won't work for that is an experience driving system.
<br>
<br>- We can use our own calculations but those have no meaning in the rest of the world
<br>
<br>- We just could change the jib rule to :
<br>
<br>Max rated jib are < 4,01 sq.mtr. and place the F16HP somewhere past the F18 (and F20 in heavier airs) and below the iF20 in lighter airs. Under Texel we would be raed faster than F18's and under ISAF we would be rated sometimes slower and sometimes faster.
<br>
<br>
<br>So please reply and give us your opinion at the end of the discussion we'll choose the default system for the jib rule
<br>
<br>Wouter<br><br>
<br>
<br>
<br>
<br>Texel :
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>ISAF :
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>Other system :
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>Wouter<br><br>
