Posted By: Wouter
Robi, here a pic of my skipper trap setup - 05/23/05 04:25 PM
![[Linked Image]](http://www.catsailor.com/bb_files/49970-Typhoon_F16_skipper_trapeze_line_1.jpg)
It is in its "light weather storage" position = away from the trampoline and far forward. In strong winds I don't run it through teh ring near the sidestays but fix the hook to the dogbone right away it comes up through the trampoline. I'm using the same 3 mm dyneema line for my trap lines as I do in my mainsheet system. I actually swear by this line. It takes 500 kg before breaking and it weights less than water so it floats. Steel wires weight 7 times the weight of water per given volume. I also use this line as spi pole support lines. It is too thin to use as trim line, but its is again in the second and third stage of my cascaded downhaul system. It is rather flexible you see and this improved the eefficiency of these systems alot !
If there is any problem with this setup it is that it may sometimes be difficult to unhook. At least with the trapeze harness I use. You don't have the flexing of the bungee to give you some extra slack to flick it out of the harness hook. I know what alot of others are saying about this setup but they really don't know what they are talking about. I have it on my boat, I tried it and I raced with it. With expensive blocks it may be better but I consider everything from a cost to performance perspective and this setup scores high. And there are also less components that can break or foil up. Found that reducing the number of components used with both make the boat clean and easy to sail and make it more dependable. If not more inexpensive.
The trapeze for the crew doesn't have the jam cleat adjusted and is setup more along the lines of the conventional system. A small block is at the end to the trap line and a line with jammer and bungee on one end and a dogbone on the other.
I can really recomment the plastic hooks at the end of the bungee cord as soon in the picture. They give excellent functionality, better then sisterclips and alot cheaper as well. Also going form "light weather storage" position to heavy weather position is really simple. Unhook and let the hook slip from your hand. The hook is too big to go through the eye in the trampoline. Than you grap it again and hook it onto the dogbone again. Finito ! It is also great when putting the boat on or off the trailer.
