Hull pressurizing #289304
06/13/22 08:39 AM
06/13/22 08:39 AM
Hopkinsville, Ky
DaleYoung Offline OP
Hopkinsville, Ky
Just completed refurbish of a Supercat 17. After sailing I noticed a lot of air pressure built up inside of the hulls. I would imagine that could do some damage if left. Is there a recommended spot to drill a vent hole? or is there a vent available?
Thanks in advance!
Re: Hull pressurizing [Re: DaleYoung] #289305
06/13/22 06:04 PM
06/13/22 06:04 PM
Memphis, Tennessee
Damon Linkous Offline
Memphis, Tennessee
I don't know if Supercats had factory hull vents. On other cats that do, they are usually under the beams for protection, and often get clogged up. (Hobie 16)
How did you notice the pressure? Were the hulls distorted? Do you have deck ports? Are the hulls painted a dark color?
Re: Hull pressurizing [Re: Damon Linkous] #289306
06/14/22 08:16 PM
06/14/22 08:16 PM
Hopkinsville, Ky
Hopkinsville, Ky
When I would pull the drain plug after sailing, it would let off a blast of air. My hulls are white. They weren't distorted. No. I don't have an ports, but I'm going to either drill a small hole or add some kind of vent. Just didn't know what others were doing. I'm new to cats.
0 registered members (), 741 guests, and 84 spiders.
