| Re: Hull cover leakage
[Re: Arjan13]
#288700 04/01/18 04:47 AM 04/01/18 04:47 AM |
Joined: May 2006 Posts: 1,383 Kingston SE South Australia JeffS
Posts: 1,383 Kingston SE South Australia | If you can get rid of all traces of silicone, Marine grade Sikaflex is awesome but it won't stick on top of silicone
Jeff Southall Current boats Nacra 5.8 1703 Animal Scanning Services Nacra 5.8 1667 Ram Raider Nacra 18 Square Arrow 1576
[Re: Arjan13]
#288717 04/11/18 12:32 PM 04/11/18 12:32 PM |
Joined: Sep 2005 Posts: 1,187 38.912, -95.37 _flatlander_
Posts: 1,187 38.912, -95.37 | sikaflex 291 is what you want It is a Swiss product, and what all boat builders are using these days Less than half the cost of 3M
Unfortunately not available in small tubes, like 3M products
[Re: Arjan13]
#288720 04/12/18 08:28 AM 04/12/18 08:28 AM |
Joined: Mar 2009 Posts: 932 Solomon's Island, MD samc99us
Posts: 932 Solomon's Island, MD | John,
Does Sikaflex 291 harden in the tube after opening? I recently learned that freezing the 3M products prolongs their in-tube life indefinitely.
-Sam
[Re: samc99us]
#288730 05/01/18 12:23 PM 05/01/18 12:23 PM |
Posts: 1,187 38.912, -95.37 | Sam,
Yes, moisture and air are enemies. Put in a storage bag in the freezer. (the fridge is for gelcoat ;p)
[Re: Arjan13]
#288759 05/08/18 07:51 AM 05/08/18 07:51 AM |
Posts: 932 Solomon's Island, MD | My recommendation is to apply the non-skid that you see on newer F18's/A-Cat's. There are several brands, Seadek and Raptor Decking come to mind. The other option is a strip of non-skid tape: https://webshop.nacrasailing.com/product/non-skid-tape-black-per-meter/The final option is basically a strip of the 3-6mm non skid EVA decking along the side of the hull (where your feet go), the 505 guys use a sort of tire-like rubber for this that works quite well. I applied a full EVA deck to my Infusion Mk. 1 and it was the best upgrade we made to the boat, much more comfortable in all positions and super grippy. I used the 3mm raptor decking.
[Re: Arjan13]
#288764 05/09/18 05:44 AM 05/09/18 05:44 AM |
Posts: 1,383 Kingston SE South Australia | International has a granular additive to add to paint or gel coat, it's rounded so no sharp edges, I've done it to a few boats now, I apply it with a 4 inch high density roller. You mix it in the paint tray and go over the surface once, if that's not enough grip you go back over a second time straight away and it sticks a lot more grip on, it's very good and much cheaper than tape
[Re: Arjan13]
#288765 05/10/18 06:30 AM 05/10/18 06:30 AM |
Posts: 932 Solomon's Island, MD | Arjan,
A strip of EVA foam will stick if you use contact cement to fasten it, or super glue the edges. Paint works fine too I just find it messy and painful compared with EVA.
-Sam
553
guests, and 66
Mod | | Forums26 Topics22,404 Posts267,055 Members8,150 | Most Online2,167 Dec 19th, 2022 | | |
