main sheet dropping overboard through trampoline #109545
06/14/07 06:25 AM
06/14/07 06:25 AM
The Netherlands, Europe
flying_dutchman Offline OP
We are going to participate the [color:"red"] Round of Texel [/color] <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" />- The Netherlands- June 23, 2007 <img src="http://www.catsailor.com/forums/images/graemlins/laugh.gif" alt="" /> (biggest Catrace in the World [http://www.roundtexel.com/] with almost 500 subscriptions already!!) In rough conditions (waves) the main sheet tends to slip through the apertures in the trampoline <img src="http://www.catsailor.com/forums/images/graemlins/mad.gif" alt="" /> - especially the rear one. Very inconvenient when both hanging in the trapeze! <img src="http://www.catsailor.com/forums/images/graemlins/confused.gif" alt="" /> Tried to avoid this by inserting kind of mesh which actually does the trick more or less. Does not seem to be a long lasting solution however. Anybody a (better) solution?
other question: we have to have 2 paddles somewhere on board - which we will almost for sure never use. We would like to attach them under the trampoline to keep as much free space as possible. Any suggestions?
Happy sailing from The Netherlands!
Eddie
Hobie 16 (1992) # 99173 & CT11 - with spi
Re: main sheet dropping overboard through trampoline [Re: flying_dutchman] #109546
06/14/07 12:27 PM
06/14/07 12:27 PM
train your crew to tend to the slack in the main.
Re: main sheet dropping overboard through trampoline [Re: Karl_Brogger] #109547
06/19/07 06:30 PM
06/19/07 06:30 PM
Sodus NY
h16bill Offline
h16bill  Offline
Sodus NY
Your crew should be holding the traveler line. This takes up a lot of the slack. There shouldn't be enough to fall through after that.
cheers
Bill
Re: main sheet dropping overboard through trampoline [Re: h16bill] #109548
06/25/07 08:30 AM
06/25/07 08:30 AM
As my traveller doesn't really run smoothly when sheeted in we use the traveller line as kind of chicken line at the same time. Finished 273 out of 509 competitors (483 finished)
Both of you thanks for your reply.
Eddie
Eddie
Re: main sheet dropping overboard through trampoline [Re: flying_dutchman] #109549
07/13/07 02:56 AM
07/13/07 02:56 AM
Durban, KwaZulu-Natal, South A...
Clint_SA Offline
Clint_SA  Offline
I put the paddles under the tramp in the middle, parallel to the hulls. Used some old stretch cord to create loops, which I tied around the tramp lacing running up the middle. I put the paddle in from the back, handle first, then stretch the front cord to wrap around the small handle (if you don’t have you can improvise). This works really well, never in the way, tight up, so no dragging and easy to get when needed (might have to get a bit wet).
Dubulamanzi
Re: main sheet dropping overboard through trampoline [Re: Clint_SA] #109550
07/14/07 07:03 AM
07/14/07 07:03 AM
North Carolina
hrtsailor Offline
hrtsailor  Offline
North Carolina
I use a plastic paddle that flexes a little and I put it on top of the tramp. The handle goes up through the lacing a few inches, then I slide it back to get the end of the paddle blade under the lacing. It isn't in the way yet easily available. It helps keep the main sheet from going through the lacing but doesn't eliminate it from happening.
Howard
0 registered members (), 236 guests, and 256 spiders.
Posts267,056
