| Mast Base Amputation #114518 08/13/07 09:52 AM 08/13/07 09:52 AM |
Joined: Aug 2007 Posts: 22 Fairhope, Alabama cookwithgas OP
Posts: 22 Fairhope, Alabama | On Sunday I took out my 1981 Hobie 16 for the second time. When I was stepping the mast, the base separated leaving me in a precarious position. I was lucky to have my neighbor along (I had considered sailing solo that day). He was able to run around and catch the falling mast before I did any damage. I plan to get some new rivets from my Hobie dealer today and maybe use larger rivets where the four small rivets are used. I made a short video of my stepper hinge in action and noticed that when raising the mast the hinge lifts up and causes the ball to miss the socket. Take a look at the video here (you should first save it, then run it): http://www.cooknwithgas.com/Sailing/Mast_Base.AVIIt's a big file (21 MB) so don't open it if you have a slow connection. Comments and/or suggestions are appreciated. Thanks, Scott Laughlin Omaha, Nebraska | | | Re: Mast Base Amputation
[Re: cookwithgas]
#114519 08/13/07 10:22 AM 08/13/07 10:22 AM |
Posts: 35 Portland, ME | I had the exact same issue with my H16 except when my base pulled out, it ripped out the aluminum on the bottom of each rivet and my mast hit the ground, hard. I just epoxied the base back in and it's worked fine all season so far. I think the new hobie 16s aren't even riveted at the mast base, they are only epoxied. Now, when I'm stepping the mast, I keep one hand low on the mast pulling it back so the step assembly doesn't swing up. jrg
Hobie 16
[Re: cookwithgas]
#114521 08/13/07 01:44 PM 08/13/07 01:44 PM |
Posts: 17 Seattle, WA | I seem to recall a similar issue when raising my mast. I was using the older style mast step link. I purchased the newer stiffer model and have really liked it. No side-to-side wavering and no jumping up like you've described. Here's the Murrays pic: Hope this helps your mast hinge behavior. Fair winds, Eric
Eric Abbott Former Hobie 16 owner Seattle, Washington, USA
[Re: hrtsailor]
#114527 08/14/07 03:46 PM 08/14/07 03:46 PM |
Posts: 1,187 38.912, -95.37 | Hey Scott, When raising the mast, I have always raised it partway with some speed, then hesitated and pushed it on up. Howard Howard has it right, it's a technique thing, this works. The hesitation is at about 75 degrees, or just before the ball would hit the base. Also invest $25 in the new mast step hinge.
478
guests, and 92
