| Re: Home building a mast..
[Re: Rolf_Nilsen]
#134188 03/02/08 06:25 AM 03/02/08 06:25 AM |
Posts: 9,582 North-West Europe | Yeah Timber - epoxy hulls here mate and still going strong ! Wouter
[Re: Rolf_Nilsen]
#134192 03/02/08 04:13 PM 03/02/08 04:13 PM |
Posts: 571 Hamburg | Hi Rolf, have a look at http://shop.ezentrum.de/2461261/sTVeLqG5...amp;artid=71646It is in German, but it is a CFRP tube for about 150mm diameter and 5m length, or not other crossections with same perimeter. It gives you a nice +-45 basis (which shoud be topped by some UD cloths). It is certainly not the cheapest shop, but it gives you an idea (it is certified for aircraft structures). Correctly done you dont need a dolphin striker = less nasty drilling in CFRP. Regarding engineering: Well I cannot give you full engineering support (but do you relly need it?), but some stress calculations, sizing and so on. But not within the next two weeks. Just let me know. Cheers, Klaus | | | Re: Home building a mast..
[Re: Rolf_Nilsen]
#134193 03/02/08 07:59 PM 03/02/08 07:59 PM |
Joined: Dec 2007 Posts: 90 South Carolina, USA Corksfloat
Posts: 90 South Carolina, USA | Talking about masts, the same could be applied to beams I think. I remember paying about US$300 for two alu beams for a 16 foot cat 7-8 years ago. For that price I could build composite beams instead. Just need some engineering done first, any volunteers <img src="http://www.catsailor.com/forums/images/graemlins/smile.gif" alt="" /> Even better, I know a hippie that can grow some hydroponic bamboo. It will be so strong NASA will be calling you. | | | Re: Home building a mast..
[Re: Darryl_Barrett]
#134197 03/03/08 05:26 AM 03/03/08 05:26 AM |
Posts: 25 Moscow, Russia | Actually the "re entry" surface "tiles" used by the old USSR on all their personnel carrying orbital vehicles was/is wood. <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> In real world it is some combination of phenolformaldehyde fibre and resin. No wood hard enough in our forests. | | | Re: Home building a mast..
[Re: Corksfloat]
#134198 03/03/08 06:25 AM 03/03/08 06:25 AM |
Posts: 9,582 North-West Europe | Actually, the use of wood and situations of heat/fire is actually largely misunderstood by the main populace. What else is new here ?
For example, Firefighter prefer buildings with timber trusses over steel ones. The reason being simple. It will take a very long time for a thick timber truss to burn through enough to fail. Steel and aluminium versions can weaken and bend or fail within minutes.
This effect is caused by the fact that wood chars up on the outside isolating the untounched timber on the inside and the fact that timber is largely insensitive to heat and conducts heat very badly.
Basically the core of the thick truss remains largely unaffected for long times of directed heat influx.
Metals conduct heat very well and will soften up quickly when heated up. As soon as they have heated up they will deform, bend and break bringing down the roof or walls.
The fact that Timber trusses need to be much thicker then the steel variants in order to carry the same loads actually increases this difference in behaviour favouring the timber trusses even more from the perspective of maintaining integraty under fire.
Someone said to me several years ago. "If wood was discovered today then it would mean a revolution in material use."
And it is indeed a largely misunderstood material.
[Re: Codblow]
#134201 03/04/08 09:04 AM 03/04/08 09:04 AM |
Posts: 435 Finland | I read here some while ago somebody said he used less epoxy to save the environment. If somebody is caring about the environment then have a look at the process of producing carbon fibre, it’s absolutely eating energy... http://pslc.ws/macrog/carfsyn.htmIt’s not the same thing that the carbon the blacksmith use in his forge... <img src="http://www.catsailor.com/forums/images/graemlins/smirk.gif" alt="" /> | | | Re: Home building a mast..
[Re: Rolf_Nilsen]
#134204 03/04/08 09:46 AM 03/04/08 09:46 AM |
With respect to aluminium this only applied for produce NEW aluminium from its ore (Bauxiet).
Recycled aluminium is MUCH less energy intensive. Interestingly enough recycled aluminium is practically undistinguishable from new aluminium even after having gone through many cycles.
That is why recycling aluminium (soda cans) is such a wide spread activity.
I keep saying it. Aluminium is a pretty wonderful material. Only it low 0.2% yield stress limit is somewhat of a party pooper.
156
guests, and 223
