| Re: Textile rigging
[Re: Smiths_Cat]
#170126 03/02/09 05:17 PM 03/02/09 05:17 PM |
Posts: 5,525 | Does anyone have photos of a typical application?
Pete Pollard Blade 702
| | | Re: Textile rigging
[Re: tami]
#170144 03/02/09 07:28 PM 03/02/09 07:28 PM |
Posts: 712 | Dynex is a normal SK75 spectra product. Dux is a version that has been pre-stretched under a proprietary heat process that aligns the fiber's and gives it the low creep characteristics. Dux comes in 7mm, 9mm, 11mm etc. Nothing smaller at this time. FWIW, we (layline.com) are a DUX retailer and distributor for Hampidjan
I'm in the process of replacing all of the standing rigging on my R33 and converting it to a canting rig using Dux 7mm.
I've already replaced the trap wires on my A-cat with 2mm Dynex (rated at 800kg). It's scary thin...
| | | Re: Textile rigging
[Re: mikekrantz]
#170147 03/02/09 07:40 PM 03/02/09 07:40 PM |
Posts: 1,911 South Florida & the Keys | Mike, are you using rope block with the trap adjustment? If you did, would the texture be prone to slip through the block under load? I am using Amsteel, I haven't sailed with it yet but I am concerned with the waxy feel.
Eric Arbogast ARC 2101 Miami Yacht Club | | | Re: Textile rigging
[Re: arbo06]
#170163 03/02/09 09:18 PM 03/02/09 09:18 PM |
Posts: 12,310 South Carolina | Mike, are you using rope block with the trap adjustment? If you did, would the texture be prone to slip through the block under load? I am using Amsteel, I haven't sailed with it yet but I am concerned with the waxy feel. It will slip. Been there...a-done that. 2mm!?
Jake Kohl | | | Re: Textile rigging
[Re: tami]
#170282 03/03/09 01:59 PM 03/03/09 01:59 PM |
Posts: 115 | Hi Tami, The link to vendor's zylon site is http://www.toyobo.co.jp/e/seihin/kc/pbo/menu/fra_menu_en.htm If mechanical properties were the only factor, Zylon or carbon non woven cables would be the winners. But carbon is fragile and Zylon is afraid to come out into the sunlight. Also if you have parallel (non-woven) strands of fiber it's almost impossible to devise a way to ensure they are loaded equally. There is at least one company making non woven carbon standing rigging but it looks incredibaly expensive and wouldn't work for trailer sailors. I use the Precourt dead eyes for standing rigging including diamond stays on my trimaran. I experimented once with kevlar diamond stays for my Tornado. I took a 10 lb spool of kevlar tow and made about 20 wraps around the spreadres, mast hound, and a mast base adjusting turnbuckle. I wetted the fiber with epoxy and loaded the rig up while it cured. Then I primed it and painted with the same awlgrip used on the mast. Not too scientific but it worked great for three years. I'm guessing it was about 3mm in diameter. Kevin | | | Re: Textile rigging
[Re: tami]
#170296 03/03/09 03:55 PM 03/03/09 03:55 PM |
Posts: 5,590 Naples, FL | I'm going back to hemp.
It's the only thing that might actually biodegrade in less than two millenia (if it's not smoked by some teenager before then)...
aaaaaarrrrr!
| | | Re: Textile rigging
[Re: yurdle]
#188489 08/20/09 08:05 AM 08/20/09 08:05 AM | andrewscott
| andrewscott
Unregistered | Klaus did try it stated he ended up having to tighten his stays ever time he went out... (on page 1)
but i think that was before the sk-78 came out. I to plan to use dyneema trap lines next time.. but i have been warned about chafing on the mast area... so i think i will make steel pigtails for up there..
the new | | | Re: Textile rigging
[Re: ]
#188501 08/20/09 08:22 AM 08/20/09 08:22 AM |
Posts: 3,224 Roanoke Island ,N.C. | Klaus did try it stated he ended up having to tighten his stays ever time he went out... (on page 1)
the new Wouldn't that defeat the point of the line,reducing weight aloft? Or are you going for the look? On my A I used a piece of braided line cover over the line where chafe would be a problem.
| | | Re: Textile rigging
[Re: Team_Cat_Fever]
#188502 08/20/09 08:35 AM 08/20/09 08:35 AM | andrewscott
| andrewscott
the new Wouldn't that defeat the point of the line,reducing weight aloft? Or are you going for the look? On my A I used a piece of braided line cover over the line where chafe would be a problem. haha, no my goal is not the "look". Though that is a good point. My goal would be to save money and be able to splice and hang this myself (as apposed to having it made at a cost for me at my local shop). That being said.. i think it will be a while before my steel trapwires need replacing . . . Did the braided jacket hold up? i have been using Robline dingy control line (dyneema 75 with a jacket) and i love the line, but it didn't hold up so well to chaffing.
| | | Re: Textile rigging
[Re: Rolf_Nilsen]
#188504 08/20/09 08:49 AM 08/20/09 08:49 AM |
Posts: 3,224 Roanoke Island ,N.C. | What Rolf said, No problems.
467
guests, and 110
