| Re: Freestyle 474
[Re: ryanm]
#184416 07/08/09 06:19 AM 07/08/09 06:19 AM |
Posts: 757 japan | if you want to rake your mast further aft, and it is already as far aft as the forestay chainplate allows, then you are in exactly the same situation as the hobie 16 guys about 10 years ago in their case rather than lengthen the forestay most just added a 2nd chainplate. now that hobie has realised that the hobie 16 goes better with more rake they have lengthened the forestay itself so owners don't have to add the extra chainplate/adjuster ie i suggest you add a 2nd chainplate to your forestay bridal before buying a longer forestay edit. rereading your last post it sounds as if you have NO forestay chainplate/adjuster, if that is so, get yea down to your local chandlers and get one this is what you should be looking like http://picasaweb.google.com/lh/photo/6kfFxrtYvhb5YCVHBPxSRw
| | | Re: Freestyle 474
[Re: ryanm]
#184426 07/08/09 08:44 AM 07/08/09 08:44 AM | andrewscott
| andrewscott
Unregistered | On most catamarans is there hardware on the forstay for adjusting the the rake? And could some other users input on the raking? I only skimmed some of these more lenghty posts.. so please excuse me if this has been asnwered ... on my TheMightyHobie18 rake was adjusted by going DOWN 1 (or more) holes on the side stay chain plates and UP 1 (or more) holes on the forestay chainplate. On my current boat i use a ring on my furling jib (turnbuckle) that i tie with line, so there is no chainplate. I set the side stays where i want them and tie the forestay. | | | Re: Freestyle 474
[Re: pepin]
#184429 07/08/09 08:59 AM 07/08/09 08:59 AM |
Posts: 3,528 Looking for a Job, I got credi... | Don't bother with a forestay chainplate. use a length of non-stretch line, attach the two bridles end with a bowline, loop the line a couple of time between the stay and the bridles, tie a good knot, done. Instant solution, less hardware. If you have a mast up storage, tape the knot. Agreed. Also allows you to fine tune your rig tension. As for taping it up. ALways tape the knot up.
F16 - GBR 553 - SOLD I also talk sport here | | | Re: Freestyle 474
[Re: scooby_simon]
#184433 07/08/09 09:36 AM 07/08/09 09:36 AM |
Posts: 976 France | pepin, ill give that a try. It is mast up storage, but with your idea i wont even have to lower the mast. Do you have a picture of it? I'm sailing tonight, I'll try to remember to take a pic of my forestay. | | | Re: Freestyle 474
[Re: David Parker]
#184478 07/08/09 12:45 PM 07/08/09 12:45 PM | andrewscott
| andrewscott
Unregistered | Dave, why are you messing with my boat/forestay? Next time i will have to turn on my electo-shock alarm...
| | | Re: Freestyle 474
[Re: pepin]
#184560 07/09/09 04:01 AM 07/09/09 04:01 AM |
Posts: 976 France | I'm sailing tonight, I'll try to remember to take a pic of my forestay. I completely forgot to take a pic, but my setup is exactly the same as the portuguese turnbuckle in David's pics. | | | Re: Freestyle 474
[Re: pepin]
#216348 07/22/10 01:54 PM 07/22/10 01:54 PM |
Joined: May 2010 Posts: 11 Stoney Lake, ON, Canada Ian Cowie
Posts: 11 Stoney Lake, ON, Canada | Daggerboards: When I am beaching and storing, I use the loop of rope on the top of the daggerboards and hook that over the trap handles. While sailing, I use bungee cord slipped through a piece of fabric reinforced hose - Tygon?. The hose about 6" longer than the width of the daggerboard. The ends of the bungee cord go through the supplied grommets in the trap and are knotted on the underside. Rudders: Same thing is used to hold up the rudders ... bungee cord and a piece of hose. Length of hose is about 10" long. Center the hose in the hole in the rudder and then run a length of bungee through the hose. Pass both ends of the bungee cord through the rudder tiller and tie the end together. The knot will then catch on the tiller/tiller bar bolt. I can take some close-up photos this weekend and post. Ian
Freestyle 474, Hobie 18, Hobie 16, Tornado
| | | Re: Freestyle 474
[Re: Ian Cowie]
#286729 04/29/17 06:18 PM 04/29/17 06:18 PM |
Posts: 7 | Hi, I'm trying to set up the rigging on my Freestyle 474 and was wondering if you ever got this dialed in? I'm wondering what lengths to have my mainstays at since all my rigging was stolen in a vehicle a long time ago.
Bflo
“If you want to find the secrets of the universe, think in terms of energy, frequency and vibration.†- Nikola Tesla
| | | Re: Freestyle 474
[Re: nobrush]
#287363 06/19/17 04:43 PM 06/19/17 04:43 PM |
Posts: 11 Stoney Lake, ON, Canada | Okay let me try to get you the rigging information. Here is an overall view of the mast with all the rigging attached. I personally never remove any of the rigging and simply use the halyard to tie up all the wires and make it a neat package to store away in the winter. Here I have layed out the halyard which is 55' long or one foot longer than the rope doubled the length of the 27' mast. This shows the wires attached to the mast: There are 5 wires. Outer pair are the trapeze wires, the inner pair are the shrouds and the centre wire is the forestay. Trapeze Wires: These are 0.1" (3/32") diam by 205.5" measuring from thimble to thimble. So the length of the wire itself would have to be a few inches longer to allow wrapping around the the thimble and fastened with the swaged fitting. Remember to slide on a trapeze handle before terminating the wire with the thimble and swaged fitting. Shroud Wires: These are 0.13" (1/8") diam by 236.5" measuring from thimble to thimble. Shroud is terminated with an adjustable fitting or stay aduster. Forestay Wire: This is comprised of a single 0.13" (1/8") diam by 167.5" wire connected to a bridle of 2 @ 0.13" (1/8") diam by 75" wires. The connection of the forestay to the bridle is shown here. Hope that helps! Ian (No clue why the last picture won't show up ... I'll just post another followup.
| | | Re: Freestyle 474
[Re: ryanm]
#287588 07/03/17 11:38 PM 07/03/17 11:38 PM |
Posts: 7 | I'm curious what type of ferrules are used on your boat. I bought aluminum ones (without really thinking since it was at West Marine) years ago preparing to rig the boat, then was thinking to use Stainless, but then have been told people use nickel plated copper. It appears that's what these are.
| | | Re: Freestyle 474
[Re: nobrush]
#287632 07/11/17 10:40 AM 07/11/17 10:40 AM |
Posts: 11 Stoney Lake, ON, Canada | Nobrush ... need a little more info regarding your question about ferrules ... namely ... what ferrules? Does my boat have ferrules? Sorry but I must call your "ferrules" something else as I am confused as to what boat part you are referring. Cheers!
| | | Re: Freestyle 474
[Re: Ian Cowie]
#287634 07/12/17 08:12 AM 07/12/17 08:12 AM |
Posts: 118 fl | The product which is used to make an Eye splice is known as: Oval Sleeve, Figure 8 Sleeve, Hourglass Sleeve, Duplex Sleeve, Ferrule, Nicos. Nobrush ... need a little more info regarding your question about ferrules ... namely ... what ferrules? Does my boat have ferrules? Sorry but I must call your "ferrules" something else as I am confused as to what boat part you are referring. Cheers!
Mn3
| | | Re: Freestyle 474
[Re: nobrush]
#287635 07/12/17 08:53 AM 07/12/17 08:53 AM |
Posts: 807 Hillsborough, NC USA | I'm curious what type of ferrules are used on your boat. I bought aluminum ones (without really thinking since it was at West Marine) years ago preparing to rig the boat, then was thinking to use Stainless, but then have been told people use nickel plated copper. It appears that's what these are. Use copper swages (either bare or zinc-plated). Aluminum swage sleeves are not as strong and therefore unsuitable for load-bearing applications (deck railings yes - boat rigging no). Stainless steel ferrules generally need much greater pressure and require hydraulic swaging tools. | | |
656
guests, and 129
