new old shark #188716
08/22/09 12:42 AM
08/22/09 12:42 AM
C
captinnitro Offline OP
C
Hi I was wondering if there are any plans out there for these sharks. I am trying to rebuild one. My friend bought a shark that seemed to be in good shape. However much to our surprise the shark literally stared to come apart while we where sailing it on Lake Michigan. We took on so much water and nearly lost the rig. Also the plywood decking stared to crack. We somehow made it back. Now the plane is to restore it to seaworthy shape. Any help or advice would be helpful.
Re: new old shark [Re: captinnitro] #188720
08/22/09 07:57 AM
08/22/09 07:57 AM
jimshark533 Offline
jimshark533  Offline
greetings, just go to cedarshark@aol.com and John can fix you up with a complete set of instructions on rebuilding. I do have an old MFG shark ready to be scrapped if you need anything. Also where do you hail from? I am sailing out of Grand Traverse Bay.
Re: new old shark [Re: jimshark533] #188725
08/22/09 10:57 AM
08/22/09 10:57 AM
C
C
I am from Chicago. I know that the deck will need to be redone. As I said, pieces of wood where braking off as we hit the waves. We where moving very fast. I know for sure we will need to re do the deck, the dagger boards and some how seal the hulls. Any problems we should be looking for in an old shark?
Thank you Rob.
Re: new old shark [Re: captinnitro] #189763
08/31/09 05:10 PM
08/31/09 05:10 PM
Penfield NY
rturbett Offline
rturbett  Offline
Penfield NY
As long as the main and rear beams are good, the rest is easily dealt with. If there is floatation foam in the hulls it is probably waterlogged and adding a lot of weight.
A spar can be placed across the bridle mounts if there is a lot of flex in the hulls.
Rob Turbett
Shark fleet #1
canandaigua NY
Re: new old shark [Re: captinnitro] #190933
09/14/09 01:03 PM
09/14/09 01:03 PM
all fiberglass Offline
on the new old shark ,if you are talking about your trap trays.
i make fiberglass trays,also centerbroads
allfiberglass
Re: new old shark [Re: rturbett] #190934
09/14/09 01:10 PM
09/14/09 01:10 PM
if you have flex in the hulls best ck stiffer on the inside of hulls(time to pull top deck)
allfiberglass(shark #1001)
0 registered members (), 269 guests, and 212 spiders.
Posts267,056
