The online manual (older) for the Infusion setup does not show the same blocks that actually ship with the boat now (HC8454 on the traveler up to HC7668 on the boom). Has anyone found a reeving diagram that is helpful?
First bit is the hardest to work out if you don't know how to do it, the old system on the manual and this new one reve up the same at first except that the double in the middle has been moved out to each side.
Thanks but I was really hoping to find a clear diagram. I do know that the top blocks should be perpendicular to the lower blocks but both top and bottom should rotate freely, right? Harken includes little metal "limiters" that can be used to keep them from rotating. I know I'll want the lower blocks to rotate freely but what about the uppers?
Re: Infusion mainsheet reeving
[Re: uogecko]
#206951 03/28/1002:06 AM03/28/1002:06 AM
Harken just sent me a 10:1 reeving guide for the Infusion mainsheet setup I have. It's too big to attach to this post so let me know if you want it and I can email it to you.
Sorry for asking. Have my boat miles away and need to order new mainsheet. What length are you using (I remember it to be 13.5 meter? but it sounds lengthy) provided you use it back-to-back. Also, am I right in assuming tapering would be arround 3 meters to be able to lock it upwind in full swing and outside tapered area (using normal mast rake).
Cheers, Jonas
JFR Infusion Mk2
[Re: uogecko]
#249315 06/07/1201:37 AM06/07/1201:37 AM
hope this helps http://www.harken.com/pdf/4450.pdf cheers from germany in case you are looking for a 10:1 combo i can provide a diagram on request. cheers from germany
[Re: uogecko]
#249473 06/12/1209:45 AM06/12/1209:45 AM
