US Portsmouth Committe update?? #209221
04/22/10 01:07 PM
04/22/10 01:07 PM
Annapolis, MD
Mark Schneider Offline OP
Annapolis, MD
John
The racing season is about to kick off in the mid atlantic.
A few weeks ago you suggested that you would have word back on the status of US Sailing's Portsmouth Committee.
Has there been any resolution to the leadership issue?
Will there be an update to the ratings for multihulls this year?
Mark
crac.sailregattas.com
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209223
04/22/10 01:19 PM
04/22/10 01:19 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I think someone just volunteered.
Re: US Portsmouth Committe update?? [Re: wildtsail] #209225
04/22/10 01:28 PM
04/22/10 01:28 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
I can't think of anyone better than Mark to whom we level all complaints over ratings.
Re: US Portsmouth Committe update?? [Re: wildtsail] #209227
04/22/10 01:33 PM
04/22/10 01:33 PM
Maryland
Kris Hathaway Offline
Maryland
Mark.....we almost switched to Texel for the Tuesday evening races. As it is, we plan to stay with Portsmouth but also run the Texel numbers. At least that is what I think happend before the Benadryl kicked in.
I do not know the ARC-22's rating but the N20 & F16 would fare about the same relative to each other for the most part. A-Cats are a different story and the two rating systems seem to diverge relative to them.
Kris Hathaway
Re: US Portsmouth Committe update?? [Re: Kris Hathaway] #209230
04/22/10 01:37 PM
04/22/10 01:37 PM
Crofton, MD
Chris9 Offline
Chris9  Offline
Crofton, MD
Benadryl
As in Benadryl Shots? Nice. I knew I was missing a good skippers meeting . . .
Chris Allen
Nacra 20 Gertie
www.wrcra.org
Re: US Portsmouth Committe update?? [Re: wildtsail] #209234
04/22/10 01:48 PM
04/22/10 01:48 PM
Annapolis, MD
Annapolis, MD
Actually I have been very vocal that Portsmouth is not sustainable in the 21st century. So its tough to run it when you want to retire the system for catamaran racing.
My reasons are that most of the underlying assumptions simply don't apply in the current low participation environment.
Personally I argue that we should switch to ISAF SCHRS for handicap racing.
Measure the boats that exist only in the USA and complete the rating table.
Publish the ratings and have the Alter Cup area championships use the SCHRS ratings.
Boats that don't have 5 boats equivalent to a OD class in the USA will be required to get an individual valid measurement certificate if they want to compete for the Area Championships.
A provisional rating would be determined for less rigorous events.
Re: US Portsmouth Committe update?? [Re: ThunderMuffin] #209236
04/22/10 02:04 PM
04/22/10 02:04 PM
Annapolis, MD
Annapolis, MD
Complaints???
It's very hard to argue with a ruler.
SCHRS is the ISAF handicap system... the measurement formula is administered over in the EU. Currently Scooby Simon is chair of the committee. Less familiar with Texel.
I suggest we follow the ISAF and World Multihull council recommendation and use SCHRS.
Philosophically, my personal ax is that nonlinear performance of Hobie 14's to Nacra F20's is best handled by two ratings... one for the non trapeezing range... and the trapeezing range. The counter argument is that it's too complex and does not do a better job of handicaping boats then a linear approximation with a single number.
Your milage may vary.
Anyway... its not in SCHRS.... but IMO SCHRS is a better solution then what we currently use.
That's about it for easy controversies..... after that... you best have some engineering background to debate particular aspects of the rule. The EU guys seem to be happy with either Texel or SCHRS.
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209237
04/22/10 02:05 PM
04/22/10 02:05 PM
pgp Offline
pgp  Offline
Sounds reasonable.
Pete Pollard
Blade 702
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209238
04/22/10 02:05 PM
04/22/10 02:05 PM
Portland, Maine
Portland, Maine
Sure but its very easy to argue with a formula into which you plugin numbers you got from a ruler. Whose to say that one rating systems' calculations are better than another's?
Re: US Portsmouth Committe update?? [Re: ThunderMuffin] #209240
04/22/10 02:19 PM
04/22/10 02:19 PM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
That can be said about EVERY handicap system and is the soft spot of every rating system. Pick your poison and move on.
DPN has some significant administration issues that need to be dealt with and what SCHRS offers us is the potential for global acceptance which could lead to a larger resource pool to admin the system, and the bulk of the work is done and managed outside the US.
You might say getting measurements is a hassle and impossible to obtain. I believe this is a weak argument against the system, certifying boats is relatively easy, now becoming an ISAF certified measurer is another matter.
At the end of the day all handicap systems suck a$$, but SCHRS seems to suck the least.
F18 USA 242
http://www.solarwind.solar
Re: US Portsmouth Committe update?? [Re: David Ingram] #209241
04/22/10 02:20 PM
04/22/10 02:20 PM
Portland, Maine
Portland, Maine
Thats true - and why handicap racing sucks!
Re: US Portsmouth Committe update?? [Re: ThunderMuffin] #209246
04/22/10 02:34 PM
04/22/10 02:34 PM
Annapolis, MD
Annapolis, MD
AH... but you have to know something to argue with the formula!
Whining that you don't like the outcome because you "KNOW" you should be doing better against that blah blah misrated boat won't persuade a lot of people to take your seriously.
The answer to that guy... is... STFU....learn to sail your boat better... Fact of life... Some boats are hard to sail.... some boast are easy.... That's life... do your research before you get the boat.
Measurement rating systems use real results to test how well their rule fits the real world. Texel just rolled their quality control in with a reversion to a previous definition and rescaled their ratings.... No significant changes resulted
My point... these measurement rules are not simply handed down by fiat like moses and the tablets... ... they are continually worked on using selected data sets by the respective committees.
Mind you... this is a 180 degree turn for me... Completely driven by the changes in the US sailing scene over the last 10 years.
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209249
04/22/10 02:38 PM
04/22/10 02:38 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
What's Fiat got to do with it?
I thought they were out of business.
Now a handicap rule by Moses would be good.
Isak Dinesen
E. B. White
Re: US Portsmouth Committe update?? [Re: Team_Cat_Fever] #209257
04/22/10 02:48 PM
04/22/10 02:48 PM
Portland, Maine
Portland, Maine
I don't have a dog in this fight since I couldn't care less about handicap racing (I consider it a side show to the real events). But, I'm 100% opposed to whatever you are in favor of Mark, if only because its so easy to tweak your nipples and get you all upset and produce diatribes consisting of 1 to 2 line sentences all separated with a character return. :P
It literally makes me howl.
Re: US Portsmouth Committe update?? [Re: ThunderMuffin] #209277
04/22/10 04:37 PM
04/22/10 04:37 PM
andrewscott
andrewscott
LOL
Re: US Portsmouth Committe update?? [Re: Kris Hathaway] #209279
04/22/10 04:48 PM
04/22/10 04:48 PM
Annapolis, MD
Annapolis, MD
Kris
You are right... there are small differences on the water between the rating systems currently. I don't expect any regattas to change in their outcome if we switch. I have run all of the handicap regattas in our area over the last couple of years and nothing surprising shakes out. This of course is the way it should be! Switching to a different rating system won't "Fix" any perceived problem that I or anyone else has..
The reason to change is that the underlying rationale for changes to existing ratings is solid and sustainable. The ratings updates don't depend on good turnouts of boats and top helms at portsmouth regattas. Moreover, the measurement rule can be applied to any new or one off designs AND we would be in alignment with the international scene.
Why change now?
Portsmouth could not cope with the introduction of three popular boats. N20, F18 and F16 in the first year and a half of racing... (much much longer for the F16...) (The Tiger was initially just a bit faster then a stock hobie 20). Now we have the introduction of the Nacra F20 that will be equally problematic to rate with Portmouth methods. Portsmouth can't deal with the M20's, CFR 20 and similar highly modified or one-off boats. Basically we make up a "fair" rating now...
The best solution going forward is SCHRS.
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209280
04/22/10 04:54 PM
04/22/10 04:54 PM
Who does the measuring,you?
Isak Dinesen
E. B. White
Re: US Portsmouth Committe update?? [Re: Team_Cat_Fever] #209282
04/22/10 05:11 PM
04/22/10 05:11 PM
Annapolis, MD
Annapolis, MD
Locally, I hope to get Tony Arrends and George Saunders (A Class measurer), both boat builders to help us get a Nacra 6.0 Na and a Supercat 22 measured some time this season.... it won't be official... it will be accurate.
But your point is spot on... It would be best if the Multihull council got someone like Carla Schiffer to take on the project. Carla is an ISAF measurer and the certifications would be official.
Re: US Portsmouth Committe update?? [Re: Mark Schneider] #209283
04/22/10 05:17 PM
04/22/10 05:17 PM
Keep in mind that the Portsmouth Committee is a committee of US SAILING - not the Multihull Council. The Council does not control or put people on the Portsmouth Committee.
Re: US Portsmouth Committe update?? [Re: John Williams] #209284
04/22/10 05:32 PM
04/22/10 05:32 PM
Annapolis, MD
Annapolis, MD
John, I understand that. .... My question is about the PN status... I called USSA today and left some voice mails for Lee...
I understood you to be waiting for some report or info about the committee, a 2010 ratings table and perhaps it's future.
0 registered members (), 499 guests, and 97 spiders.
Posts267,056
