Nacra 5,7 beam strap bolt hole screw thread lost, how repair #209475
04/25/10 12:32 PM
04/25/10 12:32 PM
agur Offline OP
agur  Offline OP
Hi!
Just bought Nacra 5,7, and found that 2 of front crossbeam strap bolt holes has lost its screw thread. frown
Does anyone has a good solution for repairing screw threads, so the crossbeam can be fastened tightly and properly.
Thaks, blush
Agur
Estonia
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: agur] #209476
04/25/10 12:49 PM
04/25/10 12:49 PM
K
kyle robberts Offline
K
auto parts stores sell a product called a helicoil repair kit This type of repair has worked fine for me in the past.The other option is to drill and tap for next size up bolt
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: agur] #209477
04/25/10 12:52 PM
04/25/10 12:52 PM
On the Water
P.M. Offline
P.M.  Offline
On the Water
It's a pretty simple fix. Buy the next size larger tap and tap the hole and replace with the larger bolt. You will need to carefully drill the SS strap a little bit larger to allow the larger bolt to pass through.
Philip
USA #1006
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: P.M.] #209478
04/25/10 01:02 PM
04/25/10 01:02 PM
agur Offline OP
agur  Offline OP
Thanks a lot for a quick reply!
I will try this new larger size tap method.
Regards
Agur
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: kyle robberts] #209480
04/25/10 01:12 PM
04/25/10 01:12 PM
agur Offline OP
agur  Offline OP
Does this helicoil will be strong enough compared with new larger tap?
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: agur] #209481
04/25/10 01:39 PM
04/25/10 01:39 PM
TeamChums Offline
TeamChums  Offline
It would be stronger to drill and tap for a larger bolt (more thread area in contact with each other).
Lee
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: agur] #209482
04/25/10 01:52 PM
04/25/10 01:52 PM
V
Ventucky Red Offline
V
Regards
Agur
I would also recommend Teflon coating the new bolt or using a few dabs of water proof grease when putting them in.
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: Ventucky Red] #209483
04/25/10 02:02 PM
04/25/10 02:02 PM
Annapolis, MD
Mark Schneider Offline
Annapolis, MD
crac.sailregattas.com
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: Mark Schneider] #209487
04/25/10 03:50 PM
04/25/10 03:50 PM
Roanoke Island ,N.C.
Team_Cat_Fever Offline
Originally Posted by Mark Schneider
I miss Greg.
Isak Dinesen
E. B. White
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: Team_Cat_Fever] #209502
04/26/10 03:22 AM
04/26/10 03:22 AM
agur Offline OP
agur  Offline OP
Just for information - how thick walls has this inner bolt tube?
I think that using a DROP-IN Internally-Threaded Expansion Shell Anchor insn`t good idea? It will probably damage the tube walls and surrounding fiberglass?
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: agur] #209510
04/26/10 08:10 AM
04/26/10 08:10 AM
42.904444 N; 88.008586 W
Todd_Sails Offline
Todd_Sails  Offline
Your last question, probably not a good idea. The other two options is what I'd go with.
As has been said, it is crucial to use a good, long lasting anti-seize coating when reinstalling.
F-18 Infusion
#626- SOLD it!
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: Todd_Sails] #209513
04/26/10 08:22 AM
04/26/10 08:22 AM
I don't think it's a tube , but a plate embedded in the layup of the hull. That is definitely the way it is in my N20 as I had to re mount it after too much beating on it trying to get out a broken bolt with a broken EZ out inside of it. My guess would be it's the same program with the strap as with the beam bolt.
DSCN0032 (Small).JPG (108 downloads)
DSCN0038 (Small).JPG (108 downloads)
Isak Dinesen
E. B. White
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: kyle robberts] #209514
04/26/10 08:50 AM
04/26/10 08:50 AM
Houston
carlbohannon Offline
Houston
There is a helicoil kit made for aluminum motorcycle engines that seems to work the best. It included a plastic sleeve and a 2 part mixture that looked like epoxy. This combo was supposed to passivate the aluminum and electrically isolate the SS helicoil from the aluminum. I would check with a local motorcycle shop.
Re: Nacra 5,7 beam strap bolt hole screw thread lost, how repair [Re: carlbohannon] #218257
08/25/10 01:32 PM
08/25/10 01:32 PM
agur Offline OP
agur  Offline OP
thanks everyone for advices! I used this time helicoil and seems that it works fine.
thanks!
agur
0 registered members (), 249 guests, and 260 spiders.
Posts267,056
