Re: Do you fear the turtle? [Re: RickWhite] #210281
05/05/10 07:06 AM
05/05/10 07:06 AM
Bernhards Bay, N.Y.
popeyez7 Offline
popeyez7  Offline
Bernhards Bay, N.Y.
Originally Posted by RickWhite
Are you a Turtle?
"Bet your sweet a$$"
Willing to bet not many folks know about that one.
Rick
~~ You and I must be the only old ones on here!!!! laugh ~~~~
~~Don't fear the ''SPEED''~~ Fear the''ADDICTION''
~17,18 Hobies,
~Jet boat~Speedster 150
~2 Kayaks~
~~~~VIETNAM VET. 69-71~~~~
Re: Do you fear the turtle? [Re: popeyez7] #210285
05/05/10 08:58 AM
05/05/10 08:58 AM
RickWhite Offline
RickWhite  Offline
Anybody remember all of the questions. Keeping in mind the answers are very sinless and innocent.
I remember one question was:
What does a man do standing, a lady does sitting down and a dog does on three legs?
Answer: Shake Hands
If you knew the answers to all the Turtle questions, and someone asks if you are a Turtle, the answer I gave earlier.
Rick
Rick White
www.onlinemarinestore.com
Re: Do you fear the turtle? [Re: RickWhite] #210313
05/05/10 01:29 PM
05/05/10 01:29 PM
Doesn't this belong somewhere on "TEST" thread? I'd flunk this one too...
Re: Do you fear the turtle? [Re: RickWhite] #210317
05/05/10 01:42 PM
05/05/10 01:42 PM
Q
Quarath Offline
Quarath  Offline
Q
That inflatable mast float on that Farrier Tri is really cool. Someone should make an market one like that for cats that can be easily installed after market. It doesn't have to have a fancy CO2 inflator either. AN inflation hose of some type that either travels through the mast to a port at the bottom or attached to the outside of the mast somehow that can be inflated manually even with a small pump or something This would be more to help you get right after a turtle than to prevent one probably) The auto or selected CO2 inflation could be cool as well. But you would not have to have a big float on the top unless you needed it. It would need to be reusable of course not like an airbag that can't be repacked after use.
Re: Do you fear the turtle? [Re: Quarath] #210318
05/05/10 02:02 PM
05/05/10 02:02 PM
JACKFLASH Offline
JACKFLASH  Offline
Good luck inflating a bag manually that is 28 to 30 feet down for the same reason that scuba divers have to have pressurized air.
Collin Casey
Re: Do you fear the turtle? [Re: RickWhite] #210319
05/05/10 02:08 PM
05/05/10 02:08 PM
JJ_ Offline OP
JJ_  Offline OP
Re: Do you fear the turtle? [Re: David Ingram] #210324
05/05/10 04:41 PM
05/05/10 04:41 PM
ButchG Offline
ButchG  Offline
Originally Posted By: UndecidedSeal your mast and a "hobie bob" isn't necessary.
No Tad that is not correct. If you stick it hard in choppy seas going downwind you will turtle quickly regardless of how well your mast is sealed.
_________________________
Ya got that right! The only thing that prevented our boat from
a full turtle was the fact that Mobile bay, where we ate it, is
only 8 feet deep. Even at that I had mud 2.5 feet up
(down?) my mast. Spi run, 4ft chop. . . my wife swears Mobile
Bay hates her wink
"There are four boxes to be used in defense of liberty: soap, ballot, jury, and ammo. Please use in that order."
ButchG
Prindle 19 w/Spi
Re: Do you fear the turtle? [Re: brucat] #210370
05/06/10 10:44 AM
05/06/10 10:44 AM
JJ_ Offline OP
JJ_  Offline OP
Originally Posted by brucat
Putting your weight in the wrong place (intentionally or not) will also cause turtling.
I can't imagine why a Hobie Bob couldn't be made to fit on any mast of any boat, it should be just a matter of adapting a bracket.
Yep, there is a kit and the Bob is "easily removed for racing".
Although, if sail's headboard mounts into the top of the mast as it does with the Tiger and others, then flotation fights sail for space. (Horizontal-mounted empty water cooler jugs are out in this situation.) And, you got to drill holes in the mast for brackets. Holes in mast not good. Really hesitate...
British company has an inflatable.
California moves... Most of time, pretty sure turtling more has to do with how well particular hulls will roll. Some boats roll quicker and turtle harder. The Hobie Wave for example stays turtled when no float.
Rest of the time, it is situation. Yes to float in shallow water or when you're just messing around. No when racing or in deep water for safety reasons...
Whether the mast by itself will hold you up or you need mast-end flotation -- and how much -- is just a matter of how quickly the boat will roll. Have heard different stories about water-tight masts providing enough flotation...
It's a riddle. Like these two turtles who get bored and decide to walk in a straight line for the rest of lives. First turtle travels 1/2 mile first day, 1/3 next, then 1/4, then 1/5, 1/6, 1/7 and on. Second walks 1/2 mile first day, 1/4 next, 1/8 next, 1/16, 1/32, 1/64 and so on.
Which one walks only about a mile and the other forever?
heh, heh, expecting some riddle about the Titanic or crane? grin
Re: Do you fear the turtle? [Re: JJ_] #210374
05/06/10 11:24 AM
05/06/10 11:24 AM
srm Offline
srm  Offline
The first turtle goes on forever, his travel is based on summation of the equasion y=1/x. The second approaches 1 mile, his travel is based on the summation of the equation y=1/(2^x).
But in reality, neither one walks on forever since they both eventually die.
sm
Re: Do you fear the turtle? [Re: srm] #210415
05/06/10 04:48 PM
05/06/10 04:48 PM
japan
erice Offline
erice  Offline
japan
flipped my 14' weta tri yesterday while 2 sail reaching in the death zone
big blast sent the ama under
then the proder
then the bow
and over we went
with it's skinny, hollow, open mast it rolled straight over into a turtle
but popping an ama cover to flood it got the boat on it's side just like the video
http://www.youtube.com/watch?v=F6S7o5nHiKU
was a little worried that the time taken would send it onto the rocks but when turtled there is very little windage and so very little drift
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: Do you fear the turtle? [Re: erice] #210418
05/06/10 06:16 PM
05/06/10 06:16 PM
JJ_ Offline OP
JJ_  Offline OP
Whoooo, nice save, erice.
SRM, a formula!? Wow! Also can add the fractions. Different frequencies. Google or you heard it before?
Speaking of google, this turtle thing has been talked about a lot with same concerns, problems, and same range of answers in a lot of different places. Found the water jug pic from two years back.
Re: Do you fear the turtle? [Re: David Ingram] #210504
05/08/10 06:52 AM
05/08/10 06:52 AM
Kiel, Germany
Baltic Offline
Baltic  Offline
Kiel, Germany
Agreed. However, a sealed mast will put the boat by itself in the position mast/ sail on the surface again. I was surprised how fast this worked ...
F18: C2 / A-Cat: Minelli
Re: Do you fear the turtle? [Re: Baltic] #210535
05/08/10 04:06 PM
05/08/10 04:06 PM
JJ_ Offline OP
JJ_  Offline OP
After reading all the stuff on mast floats (via Google), my conclusion on turtles... is that all masts should have an eye strap or straps or some optional attachment point near the tip where a buoyancy bag or some flotation device can be fitted.
I am surprised that this attachment point is not a standard safety feature item. (It is with some, yes. Like the Wave that has to have one no matter what.)
With marginal swimmers on or when in locations where the water is shallower, then the float looks like a necessity. (Marginal swimmers also make it a necessity not to go out where turtling may be required unless there is a safety boat around.)
The Weta certainly does have a very slick righting concept...
A while back, Jeremy ran a "what-if" here on an TheMightyHobie18 that had to be turtled because of someone going overboard. It was a nice mental exercise (not for them, for the forum). Turtling was about the only option in that case. What those guys could have done better, IMO, was pre-think their boat to conditions before going out...
Anyway, it all seems to be personal preferences and I don't want to beat a turtle... that is already, like, dead.
Re: Do you fear the turtle? [Re: JJ_] #210548
05/09/10 07:35 AM
05/09/10 07:35 AM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Well every boat with a spinnaker setup is ready to hoist something appropriate once you have turtled - if you have something with you. I guess a dinghi PFD isn't enough however.
Re: Do you fear the turtle? [Re: JACKFLASH] #210746
05/11/10 04:10 PM
05/11/10 04:10 PM
Q
Quarath Offline
Quarath  Offline
Q
Good point I didn't think of that. Guess you would have to have some sort of CO2 inflation then.
Re: Do you fear the turtle? [Re: Smiths_Cat] #210749
05/11/10 04:19 PM
05/11/10 04:19 PM
andrewscott
andrewscott
Hmmm, maybe i will string a few 100 rubber duckies on my spin halyard and give it a try.
Quack
1 registered members (Seanziepop), 581 guests, and 110 spiders.
Posts267,056
