Page 1 of 4 1 2 3 4
using gps #218380
08/27/10 04:34 AM
08/27/10 04:34 AM
pgp Offline OP
pgp  Offline OP
Does anyone know if the Foretex 301 will allow me to upload gps waypoints and another person download them into their gps device?
Thanks.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218381
08/27/10 06:40 AM
08/27/10 06:40 AM
Thanks.
Yes - but you'll need a PC interface cable and a PC with the Garmin software.
Re: using gps [Re: Jake] #218383
08/27/10 06:47 AM
08/27/10 06:47 AM
pgp Offline OP
pgp  Offline OP
Thanks Jake.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218424
08/27/10 07:00 PM
08/27/10 07:00 PM
japan
erice Offline
erice  Offline
japan
if you have garmin's mapsource software
you'd use it to connect to your foretrex and download the tracks, waypoints and routes
then you'd delete the tracks and routes leaving only the waypoints
then save the file as something like pgpwaypoints.gpx file
thius .gpx file can be sent by email as an attachment
the receiver could then load the .gpx file to pretty much any gps that had a computer connection as .gpx files are supposed to be the new standard for gps transfers
if you don't have mapsource there are many other freeware programs that can do much the same thing
eric e
1982 nacra 5.2 - 2158
2009 weta tri - 294
Re: using gps [Re: erice] #218439
08/28/10 09:14 AM
08/28/10 09:14 AM
pgp Offline OP
pgp  Offline OP
Thanks Eric. I'm planning to use "Garmin Connect", but this is all new to me.
Any idea how accurate the speed is for the Foretrex?
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218450
08/28/10 05:22 PM
08/28/10 05:22 PM
japan
erice Offline
erice  Offline
japan
speed readings are generally very accurate on gps as long as they have a good lock on the sats. eg they are generally MUCH more accurate than car speedometers (zero to +10%) which rely on tyre size, eddy currents, cables etc.
but they can sometimes give some wacky results, like 500mph, when you startup in a new area. however once settled down with a good lock and open skies they are the best
after all the top units are used to measure changes in the earth's surface of less than an inch around volcanoes and fault lines etc
eric e
2009 weta tri - 294
Re: using gps [Re: Jake] #218586
08/30/10 12:58 PM
08/30/10 12:58 PM
Hamburg
Smiths_Cat Offline
Smiths_Cat  Offline
Hamburg
Thanks.
I had the 201 and it worked also with usual freeware. Problem was the pin... so it is no on the seabed.
Cheers,
Klaus
Re: using gps [Re: Smiths_Cat] #218594
08/30/10 02:40 PM
08/30/10 02:40 PM
pgp Offline OP
pgp  Offline OP
Hmm, that's good to know! This one has a velcro thingey to wear around the forearm. I was going to mount it on the boom. Maybe not.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218598
08/30/10 02:44 PM
08/30/10 02:44 PM
Portland, Maine
ThunderMuffin Offline
Portland, Maine
on the boom you should be fine. the problem with the pin is when you put your hand on the deck or some other position where your hand is bent 90 degrees to your arm. It puts stresses on the pin as the unit is bent between your arm and hand and the pins just pop out. Presumably your boom will remain straight (hopefully) so it should be safe on there.
You can always use the patented Tawd Hart insurance policy and aqua-seal (liquid nails) the strap to the back of the 201 housing.
Re: using gps [Re: ThunderMuffin] #218599
08/30/10 02:50 PM
08/30/10 02:50 PM
pgp Offline OP
pgp  Offline OP
Well...at least he didn't use duck tape.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218607
08/30/10 05:51 PM
08/30/10 05:51 PM
Port Noarlunga, SA, Australia
Darryn Offline
Darryn  Offline
As long as the 201 doesn't get to wet they are fine. In conditions were its being blasted with water, which happened to my boom mounted units, they failed.
I have yet to find a waterproof gps, even velocitek speedpucks, which I use now, get a bit misty inside and require regular dissassembly and drying out.
On the plus side with the foretrex most of them come back to life after a drowning, one of them it took over a year to dry out enough to work, but it does.
Darryn
Mosquito
Bullet
1782
Re: using gps [Re: Darryn] #218608
08/30/10 06:09 PM
08/30/10 06:09 PM
Portland, Maine
Portland, Maine
none of my 201's ever died to water exposure. I have lost two in the drink though because of the pins and then one time the velcro strap just came off my arm during a launch at daytona beach.
Re: using gps [Re: Darryn] #218609
08/30/10 06:13 PM
08/30/10 06:13 PM
pgp Offline OP
pgp  Offline OP
I got the 301. It arrived today. Hopefully, the bugs have been worked out.
Years ago, a friend had trouble with his expensive "yachting chronometer" (wrist watch), falling off his wrist and disappearing into the drink. So, he cut a section off the arm of a defunct wet suit, cut a hole in it so he could read his watch and slipped it over his wrist and watch. He was able to push all the buttons just fine and had no more problems. Maybe I'll try something like that, except on the boom.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218637
08/31/10 10:41 AM
08/31/10 10:41 AM
2017 F18 Americas Site
Dan_Delave Offline
Dan_Delave  Offline
That is a very good idea Pete. Wonder why I have not come up with that idea? I am going to make a VHF radio mount, Video Camera mount and GPS mount out of my old wetsuit.
Re: using gps [Re: Dan_Delave] #218646
08/31/10 11:41 AM
08/31/10 11:41 AM
pgp Offline OP
pgp  Offline OP
Hopefully you'll post some picture? Details get the best of me.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218923
09/07/10 11:33 AM
09/07/10 11:33 AM
pgp Offline OP
pgp  Offline OP
So, I'm finally getting around to the Foretrex 301. All I've been able to determine so far is that I must buy a download from Paretologic. It's only $30, still, does this sound right?
https://buy.paretologic.com/safecar...&uid=0&buttonTrackingID=18597837
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218924
09/07/10 11:48 AM
09/07/10 11:48 AM
Portland, Maine
Portland, Maine
What?! No! If all you want to do is share GPS coordinates, there are a plethora of FREE software applications available that will talk to your GPS. EasyGPS is one such product amongst thousands.
You don't need to buy software.
Re: using gps [Re: ThunderMuffin] #218925
09/07/10 11:56 AM
09/07/10 11:56 AM
pgp Offline OP
pgp  Offline OP
thanks Tad. I owe you a beer.
Pete Pollard
Blade 702
Re: using gps [Re: pgp] #218936
09/07/10 02:46 PM
09/07/10 02:46 PM
catman Offline
catman  Offline
.....I would say at least $30 in beer.
Re: using gps [Re: ThunderMuffin] #218952
09/07/10 06:39 PM
09/07/10 06:39 PM
Vancouver, BC
Tornado Offline
Tornado  Offline
Vancouver, BC
GPS Action Replay can be used to replay your entire track on a pc and even on a webpage..like google earth...but also has sailing specific indicators/features.
Mike Dobbs
Tornado CAN 99 "Full Tilt"
Page 1 of 4 1 2 3 4
0 registered members (), 143 guests, and 88 spiders.
Posts267,056
