| P19-MX Info #223548 11/08/10 07:58 AM 11/08/10 07:58 AM |
Joined: Sep 2004 Posts: 75 Clearwater, FL stevefisherkeller OP
Posts: 75 Clearwater, FL | Went out sailing yesterday on my new to me P19-MX, sailing down wind was no problem. Sailing up wind, max down haul, almost block to block and the sail kept inverting, doing the crazy S. Does any one know how tight the diamond wires are supposed to be. Any solutions? Wind was 25+ and gusting. Thanks
Steve Fisherkeller P19MX
| | | Re: P19-MX Info
[Re: stevefisherkeller]
#223562 11/08/10 09:54 AM 11/08/10 09:54 AM |
Posts: 264 Long Island, NY | In that kind of breeze you should try to pull on some barber hauler on the jib to open up the slot. That's a decent sized headsail on the MX. Pretty forgiving boat huh?
G Gove
Blade #728
Long Island, New Yawk
| | | Re: P19-MX Info
[Re: gregP19]
#223588 11/08/10 01:19 PM 11/08/10 01:19 PM |
Posts: 75 Clearwater, FL | OK I will try that. I did have the jib in going to weather. Still working on learnig all of the controls. When I got done sailing for the day I thought I was going to have to file a flight plan the way the boat was shaking before getting the sails down.
| | | Re: P19-MX Info
#223590 11/08/10 01:31 PM 11/08/10 01:31 PM |
Posts: 12,310 South Carolina | Went out sailing yesterday on my new to me P19-MX, sailing down wind was no problem. Sailing up wind, max down haul, almost block to block and the sail kept inverting, doing the crazy S. Does any one know how tight the diamond wires are supposed to be. Any solutions? Wind was 25+ and gusting. Thanks Travel the main out a good bit (12") so you can foot off too - that will allow you to keep more tension on the mainsheet and keep you from pinching too much. In that kind of wind, it's going to be tough to make anything look "right".
Jake Kohl | | | Re: P19-MX Info
[Re: catman]
#223598 11/08/10 02:57 PM 11/08/10 02:57 PM | MN3
| MN3
Unregistered | Like I said, Don't look up. I once asked Catman what that noise was coming from my car, his suggestion of "turn the radio up" seemed to handle the issue (till the wheels fell off) | | |
116
guests, and 107
