| Nacra stern paint question #23043 08/08/03 12:05 PM 08/08/03 12:05 PM |
Posts: 74 Maryland, USA | I need to re-paint the rear of my Nacra. Many Nacras have sterns that have a flat black paint of some type rather then white gel-coat. The fiberglass texture normally shows. My paint has rubbed/faded off and bare fiberglass is showing back there. Boat is a 1991. Any ideas on what type of paint to use? I was thinking of some black Interlux Brightside since it is available in pint size from local West Marine store. It is single part polyurethane meant for top sides but boat is not kept in water. Any drawbacks to this, or things I need to be aware of? Any special primer needed? Found this forum discussion on hull painting in general, with normal differences in opinion: http://www.catsailor.com/forums/sho...=&sb=5&o=&fpart=all&vc=1 Thanks,
Patrick Ragen Taipan 4.9 USA 274
| | | Re: Nacra stern paint question
[Re: PRagen]
#23044 08/08/03 01:22 PM 08/08/03 01:22 PM |
Posts: 12,310 South Carolina | flat black Krylon in a can. If you are just doing the sterns (and they are recesed like on my old 5.2) why go to all that trouble? I painted my 5.2 sterns with it and it looked great for years. The recessed sterns are simple to mask off (just run the tape around the outside) so even if it needs another coat in two years, it will take you 15 minutes and $2.00. After repairing a nearly dismembered stern on my 6.0NA (this stern is not recessed) I shot it with gloss Krylon and it's holding up fine. Would I paint a whole boat like that? Heck no. Sterns only? yep.
Jake Kohl | | | Re: Nacra stern paint question
[Re: PRagen]
#23046 08/09/03 12:30 AM 08/09/03 12:30 AM |
Joined: Jul 2001 Posts: 290 Pensacola, Florida / Katy, Tex... Cookie Monster
Posts: 290 Pensacola, Florida / Katy, Tex... | Back in the old days, around 1980, I painted the sterns on my Nacra 5.2. I went to K-Mart and bought a can of the cheapest, flat black paint I could find for $1.19. Painted both sterns --- looked great until it was sold in 1984. Did the same thing again on an old 5.2 my brother bought in 1999. Same results. From my experience, I certainly wouldn't go overboard with the paint selection.
Just my 2 cents.
Don Cook
ARC22 #2226
ADRENALIN
[Re: PSAILOR]
#23048 08/09/03 09:23 AM 08/09/03 09:23 AM |
Posts: 12,310 South Carolina | During that time, the sterns were added after the two hull halves were joined (the two halves left a big opening for the stern). Later they changed this (as did Supercat I believe) so that the stern was part of the main mold to make it a more efficient assembly process with less finishing required.
[Re: PRagen]
#23049 08/14/03 12:40 AM 08/14/03 12:40 AM |
Posts: 217 | I believe the type of paint on the sterns is completely irrelevant - it won't slow you down if it's the "wrong" paint, will it? As long as it isn't "heavy", and stays there, go with cheap. So why go with flat black, why not make a statement? My boat has one stern green, one stern red - guess which is which? If you trailer your boat, why make the sterns black? Why not white? or even some highly reflective paint? The more visibility on the highway, the better!!
181
guests, and 101
