JIB: Upgrade to a single swivel cleat? #231407
04/21/11 08:56 AM
04/21/11 08:56 AM
Bluesman Offline OP
Bluesman  Offline OP
My 84 has the stock jib setup with a pair of fixed swivel cam, cleats on the cross bar,and the tall sliding car with spring that slides on the track.
My spring jib cars, on the track need replacing, and instead of buying new ones, for almost the same price I am thinking about buying new swivel cam cleats with sliding cars from Salty dog marine and using just these on the track, and removing all of the old setup (including the swivel cleats on the crossbar). I don't feel the need for a traveler.
Here is the part I would buy:
Swivel cam cleat with car
I would appreciate any comments on doing this. I think the new hobies run this type of setup on the integrated track.
thanks
Re: JIB: Upgrade to a single swivel cleat? [Re: Bluesman] #231419
04/21/11 12:22 PM
04/21/11 12:22 PM
Clinton, Mississippi
rattlenhum Offline
rattlenhum  Offline
Leave the swivel cleats for future use as jib travellers (when your feelings change!).
Jerome Vaughan
Hobie 16
Re: JIB: Upgrade to a single swivel cleat? [Re: rattlenhum] #231420
04/21/11 01:14 PM
04/21/11 01:14 PM
Bluesman Offline OP
Bluesman  Offline OP
Sounds like a good plan. Are there any real disadvantages to loosing the spring car in the rigging?
Re: JIB: Upgrade to a single swivel cleat? [Re: Bluesman] #231457
04/23/11 08:09 AM
04/23/11 08:09 AM
SE Pa. or Chesapeak Bay
HMurphey Offline
HMurphey  Offline
Please go research how the most current H16's are equiped .... "rattlenhum" is correct ....
Harry
H18Mag/P19MX
Re: JIB: Upgrade to a single swivel cleat? [Re: HMurphey] #231460
04/24/11 01:11 AM
04/24/11 01:11 AM
dseeker Offline
dseeker  Offline
Hi, Nice to meet you.
cabal online cabal online
Re: JIB: Upgrade to a single swivel cleat? [Re: Bluesman] #231470
04/24/11 07:18 PM
04/24/11 07:18 PM
rattlenhum Offline
rattlenhum  Offline
None at all. You will find that the replacements you are proposing are far superior.
Jerome Vaughan
Hobie 16
Re: JIB: Upgrade to a single swivel cleat? [Re: rattlenhum] #231560
04/26/11 06:59 PM
04/26/11 06:59 PM
“an island in the Pacifi...
hobie1616 Offline
hobie1616  Offline
Here's some stuff from one of my really old posts:
I used Trentec cars with Harken cleats mounted between the track and the mast base for 20 years. You can add additional lines to set up a barber haul system to set the cars where you want them. It's a bullet proof system.
The Trentec cars pull to the center with a bungee that passes in front of the mast through a pad eye.
The barber haul lines (red and green) go around a cheek block pop riveted to the corner casting, through the pad eye, through the lance cleat for adjustment and are tied to the shrouds.
The jib sheet is tied off with a figure eight knot in the Trentec car. It goes through the block on the jib, through a block that’s attached to the car with a shackle, through the Harken cleat and to the crew.
Don't put those swivel cam cleats with cars in the old style tracks. You'll eventually rip them out by the roots.
US Sail Level 2 Instructor
US Sail Level 3 Coach
0 registered members (), 647 guests, and 173 spiders.
Posts267,056
