Touch up paint #244710
02/24/12 03:34 AM
02/24/12 03:34 AM
Schnoogie84 Offline OP
Hey there,
So I am picking up my new old mosquito on Sunday, and whilst it was recently resprayed 2-pac, there is a very small section on one hull where the paint has cracked a little (the timber is fine). I hear this can be common with 2-pac paint jobs as the hulls move but the paint doesn't.
I want to 'touch this up' to keep water away from the timber - whats the best paint and procedure to do this? I don't really mind about how good it looks for now, I just want to make sure the hulls are protected.
Cheers,
Andrew
Re: Touch up paint [Re: Schnoogie84] #244761
02/24/12 07:26 PM
02/24/12 07:26 PM
Matt_Stone Offline
Matt_Stone  Offline
sand it back to the timber and feather out the edges, you can put "everdure" by international which is a timber preservative then once dry tape up boat exept the repaired damaged and spray 2pac undercoat eg International "interprotect" can be rolled too, then you can go to a paint shop or do it your self colour match the paint and spary it on. its ok if you make a mess as you can once its dry wet n dry the area and polish it to blend in
Matt
Re: Touch up paint [Re: Schnoogie84] #244861
02/27/12 04:27 PM
02/27/12 04:27 PM
Scarecrow
Scarecrow
The everdure is the important step here. It is very thin and will actually wick into the ply before hardening, thus forming a physical barrier inside the wood against water ingress and there for rotting.
0 registered members (), 116 guests, and 132 spiders.
Posts267,056
