| Re: Forestay bridle attachment
[Re: Schnoogie84]
#245259 03/05/12 09:29 PM 03/05/12 09:29 PM | Scarecrow
| Scarecrow
Unregistered | I basically agree with matt but recommend cutting either an oval or rectangle with a jig saw. If you make it 2" longer than it is wide you can then laminate a bonding flange on what will be the inside surface, let it cure, cover it with glue push into hull, rotate and hold in place. Let it cure then fair and paint. This will give you a much better repair. | | | Re: Forestay bridle attachment
[Re: ]
#245262 03/06/12 12:08 AM 03/06/12 12:08 AM |
Posts: 44 | Thanks guys, I think I can do this So what I am thinking is that I cut the hole in the deck over the top of the bulkhead so that I have access to both sides of the bulkhead, so I can I unmount the chainplate, strengthen the bulkhead and remount the chainplate. If cut this in a rectangle or oval, I can laminate a second peice of ply to the underside of the peice I removed which will be glued to the underside of the hull around the cutout. By ' flairing' , I am guessing this means sanding the surrounding area around the repair so that I can blend in the paint? Does the deck rest on the bulkhead and will they be glued together? Have I interpreted this correctly, or do you suggest I cutout the hull where the chainplate exits the hill? Excuse my ignorance, this is all new to me! Thanks again, Andrew | | | Re: Forestay bridle attachment
[Re: Schnoogie84]
#245266 03/06/12 05:04 AM 03/06/12 05:04 AM | Scarecrow
| Scarecrow
Unregistered | Andrew, if your nervous about cutting holes in your boat I don't live far from you (assumption based on the fact you're sailing at sugerloaf. If you bring you boat up to my place in the Kalorama I'd be happy to help out. | | | Re: Forestay bridle attachment
[Re: Schnoogie84]
#245304 03/07/12 01:55 AM 03/07/12 01:55 AM | Scarecrow
| Scarecrow
Unregistered | Easiest Place in melbourne for what you're after will be www.marinetimbers.com.au they should have everything you need and be able to advise you on how to proceed. Having said that, for this job you could almost get everything at Bunnings. Always available for a chat if you're after advice. Follow the link below and you'll soon find my phone number.
108
guests, and 112
