| Tacking angle #246075 03/25/12 03:18 PM 03/25/12 03:18 PM |
Posts: 5,525 | I had a college sailor out on the boat and almost the first thing she asked me was, "what is the tacking angle?" Of course I didn't have a clue and said so.
So what is the tacking angle on F16/F18s? 110? 105? Or any cat for that matter...
Pete Pollard Blade 702
| | | Re: Tacking angle
[Re: Nacra5.8NA1386]
#246080 03/25/12 05:42 PM 03/25/12 05:42 PM |
Posts: 12,310 South Carolina | It's probably closer to 80-90 degrees for most of us. Tacking angle isn't everything though and is hard to compare to monohull world. Speed is king on cats and although we can sail just as high (or higher) than any other monohull while still going faster, we can get to the top of the course more quickly sitting in the 80 to 90 degree range. Speed through the water increases dramatically as we crack off of the wind. Talk of tacking angle also ignores the effect of speed - apparent wind angle. Because we move faster, our apparent wind angles are much higher and our sails/mast/tuning are tailored to handle this high apparent wind angle. This is ultimately the limit of getting to the top of the course in short order.
Jake Kohl | | | Re: Tacking angle
[Re: pgp]
#246087 03/25/12 06:45 PM 03/25/12 06:45 PM |
Joined: Jun 2001 Posts: 425 Toledo, Ohio (western end of ... Mike Fahle
Posts: 425 Toledo, Ohio (western end of ... | A rule of thumb for most sailboats is that they tack through 90 degrees. For any given sailboat many different influences affect the actual tacking angle. Some are: water condition - smooth is higher, rough is lower; wind speed - very light is lower, medium is higher, heavy is lower; displacement - heavy is lower, lighter is higher, sail shape - fuller is lower, flatter is higher; boat surfaces - rough is lower smooth is higher; keel or daggerboard length - longer is higher, shorter is lower; cat rigged (main only) is higher, sloop is lower; etc. So using those general guides you can see why the A cat is probably the highest pointing cat design as it incorporates the most influences that give it that advantage. Also you can understand why an F-16 single handed with main only points higher than the same boat with jib and crew. Now go back and tell the college sailor that, upon further review, you have an answer for them. | | | Re: Tacking angle
[Re: pgp]
#246103 03/26/12 09:16 AM 03/26/12 09:16 AM |
Joined: Aug 2003 Posts: 351 Santiago, Chile Andinista
Posts: 351 Santiago, Chile | Get an iphone and a waterproof case. Get iRegatta app and sail to all directions so you register your polar for the current wind speed. If you want to know your optimum tacking angle, look at the VMG polar. It works if wind direction and speed are fairly constant, which is probably not so common though...
| | | Re: Tacking angle
[Re: Andinista]
#246107 03/26/12 09:56 AM 03/26/12 09:56 AM |
Posts: 3,906 Clermont, FL, USA | Get an iphone and a waterproof case. Get iRegatta app and sail to all directions so you register your polar for the current wind speed. If you want to know your optimum tacking angle, look at the VMG polar. It works if wind direction and speed are fairly constant, which is probably not so common though... Cool app. Pair it with with some Bluetooth waterproof headphones and you've got yourself a fun little training app.
| | | Re: Tacking angle
[Re: pgp]
#246108 03/26/12 09:57 AM 03/26/12 09:57 AM |
Posts: 6,049 Sebring, Florida. | And this matters...why? Can we measure it on the water? ie, do we say, "Well, we are only at 87 degrees, we'll have to wait another 3 degrees to tack..."
No, we don't. We tack when we think we can make it, and I have no idea exactly what angle that is. When it looks right, I tack. That's why the guys with the most experience do it better than the newbs, they know what looks right.
It's all well and good on a chalkboard, as this college sailor is probably used to being shown, but in reality, who cares exactly what the angle is?
We don't cary enough electronics (like the AC guys do) to make it a worth while number to know, or measure or present that info to us, on board, so what's the point? When it looks good, tack. If it didn't work, tack again.
Blade F16 #777
| | | Re: Tacking angle
[Re: Timbo]
#246117 03/26/12 11:36 AM 03/26/12 11:36 AM |
Posts: 12,310 South Carolina | And this matters...why? ... Because it's what monohull sailors use to compare their boat to others. At 3 knots, 0.5 degrees higher is a big deal.
[Re: pgp]
#246123 03/26/12 12:14 PM 03/26/12 12:14 PM |
Posts: 5,525 | Why? Because I'm training them (a guy and a girl) that the forward position is the skill position on an F16. They have to pull all the strings, call the lay lines, pick shifts and tactics; as well as run the clock. I figure if I'm buying lunch I oughta get my money's worth.
| | | Re: Tacking angle
#246124 03/26/12 12:15 PM 03/26/12 12:15 PM |
Posts: 5,590 Naples, FL | And this matters...why? ... Because it's what monohull sailors use to compare their boat to others. At 3 knots, 0.5 degrees higher is a big deal. Crap, Jake. Got Soda in my nose again thanks to that... man it burns..
| | | Re: Tacking angle
[Re: pgp]
#246126 03/26/12 12:24 PM 03/26/12 12:24 PM |
Posts: 5,525 | I haven't forgotten how dismal my racing history is! I was hoping to learn from these people. She thinks tacking angle is important, I'm going to find out why.
But... I'm beginning to suspect no one knows!
| | | Re: Tacking angle
[Re: pgp]
#246133 03/26/12 12:37 PM 03/26/12 12:37 PM |
Posts: 5,590 Naples, FL | Tacking angle is good for judging course laylines and some strategy.. Shorter time on the course usually keeps you ahead of competition (unless you're pinching, which is slow death) if all else is the same.
Let her drive and she'll figure out that tacking angle isn't nearly as important as tacking speed
| | | Re: Tacking angle
[Re: pgp]
#246135 03/26/12 12:40 PM 03/26/12 12:40 PM |
Posts: 3,224 Roanoke Island ,N.C. | I haven't forgotten how dismal my racing history is! I was hoping to learn from these people. She thinks tacking angle is important, I'm going to find out why.
But... I'm beginning to suspect no one knows! Jake told you why. Because it's what monohull sailors use to compare their boat to others. At 3 knots, 0.5 degrees higher is a big deal. Sounds like she's a pokey boat sailor, and is thinking like one in reference to multis. Different thought process. It's just a huge variable on multihulls that use apparent wind. The faster you go the less the angles are.
| | | Re: Tacking angle
[Re: pgp]
#246136 03/26/12 12:42 PM 03/26/12 12:42 PM |
Posts: 5,525 | Slight variation in subject: can you sail your A cat at 70 degrees(without pinching)?
| | | Re: Tacking angle
[Re: pgp]
#246149 03/26/12 02:16 PM 03/26/12 02:16 PM |
Posts: 3,224 Roanoke Island ,N.C. | Slight variation in subject: can you sail your A cat at 70 degrees(without pinching)? I've never kept track of it ( just now getting a tack tick set-up on the A) and I'd be guessing if I gave you an answer. I'm sure there are plenty who could tell you. Bob Hodges and Bob Curry ( as well as others) have done alot of documenting and tuning with GPS and could probably give you an educated answer.
1 registered members (Mark Wasleyy),
487
guests, and 100
