Infusion Main Halyard (not) Locking (ing) #247019
04/15/12 05:55 AM
04/15/12 05:55 AM
Karl Funk Offline OP
Paul and I made our maiden voyage on the Kwyjiboat yesterday. My first time on a cat as well as a wire. 12-18 TWS. It was a blast. No regrets. Relatively few things blew up...
However - after spending altogether too much time holding the boat in the 45 degree water while trying to lock the main halyard - we finally pulled it over and locked it by hand.
Wondering if anyone has some advise on this system. Unlike the one in the Nacra manual - ours has a swiveling hook (perhaps a standard now?). We had the knot forward and everything was run properly. I did notice that the head of the main was probably interfering with the swivel and perhaps pushing it aside at just the wrong moment.
Does the size of the knot matter? The diameter of the halyard? Our ring seems just slightly twisted so I will replace that. Anything else?
Cheers,
Karl
Team Kwyjiboat
Nacra Infusion MkII'ed
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247022
04/15/12 06:51 AM
04/15/12 06:51 AM
USA1273 Offline
USA1273  Offline
Just so everyone understands the very frustrating launch, this is the newer Infusion rig...
This was over 1 hour or work. Boat had to be flipped twice to look at the issue, finally flipped the boat to lock the ring on the hook.
Not using a bowline, so we are getting max hoist.
Knot forward
Knot aft
Reverse hook - retie
Knot forward
Knot aft
Pull and reverse the main halyard
Knot forward
Knot aft
Knot forward
Knot aft
With the hook that swivels do you need to notch the headboard so the headboard does not turn the hook when at max hoist hoisting? it looks like the top of the headboard actually can turn the hook when it hits the bottom
of the "floating" hook.
I have sailed cats since 1991 and I have never had a locking issue as bad as this one with any of the rigs I have ever owned.
F18 USA 1273
Andrews 77 (SOLD) Melges 32 (SOLD) Formula18 Olympic 49er (FOR SALE)
Always outnumbered - Never outgunned....
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247028
04/15/12 09:16 AM
04/15/12 09:16 AM
I'm not sure why it works, but try running the halyard up the other side of the hook - if it is on the starboard side, switch to port.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247029
04/15/12 09:43 AM
04/15/12 09:43 AM
No experience with the Infusion, but on the AHPC boats, sometimes what direction the knot is tied matters, (I have no idea why), as in left over right or right over left. Also we use a double over hand knot.
My latest boat was a nightmare to hook and unhook. I tried every which way, and nothing worked consistently. I ended up making a tapered main halyard, splicing a loop on the end, and luggage tagged the ring on to the halyard. It too is crabby sometimes.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247031
04/15/12 02:36 PM
04/15/12 02:36 PM
What JW said is true, for some reason our line always has to starboard of the hook.
Last year we had a lot of problems with locking, this was due to the ring getting streched a bit.
It wasnt even that much but they do have to be round to work properly.
Last year someone posted a picture of a line they had spliced to the ring, is that still around?
Re: Infusion Main Halyard (not) Locking (ing) [Re: Tony_F18] #247038
04/15/12 08:03 PM
04/15/12 08:03 PM
G
goose151 Offline
goose151  Offline
G
Throw away the standard infusion setup and replace with a large SS ring and large twist shackle.
I am on my 3rd Infusion and still dont use the nacra supplied setup. Their rings are to small in thickness and stretch and the knot gets in the way.
I use the same setup the old Nacra 5.8 had. It is a 50mm SS ring 8mm and large twist shackle. Never have a problem.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247039
04/15/12 08:43 PM
04/15/12 08:43 PM
The Wildcat has a cool setup. The ring is sewn into the head of the sail, and you tie the halyard on I think. Except for scratching the bu-jesus outta the mast, I'm a huge fan of the skyhook.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247042
04/15/12 09:38 PM
04/15/12 09:38 PM
Newport, RI
wildtsail Offline
wildtsail  Offline
Newport, RI
I loved that setup on the wildcat.
Karl, another thing to try is to untie the line from the top of the ring and tie it with a figure eight and loop style around the top of shackle and bottom of the ring, provided you have a one piece welded shackle and ring. The line should run in front of the top of the ring.
We had no issues for a year then they started so we switched to this method and had no issues since.
Re: Infusion Main Halyard (not) Locking (ing) [Re: wildtsail] #247053
04/16/12 06:17 AM
04/16/12 06:17 AM
Wilmington,NC
Dlennard Offline
Dlennard  Offline
Wilmington,NC
The hook on top of the mast also has a metal loop that that the halyard has to pass though to keep the hook from moving. I have good luck with just running the halyard though the loop on the ring and whipping it and then put a piece of heat shrink tubing over it (about a inch tail). When you hoist the sail go slow when you get to the top and you can hear the ring hook on the catch, don't pull the sail up too high as it just moves the ring out of the way. Last make sure the the top of the mast is in alinement with the hook as you can bend it a little to make it work better ( I had one that was very bad out of alinement).
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247057
04/16/12 09:28 AM
04/16/12 09:28 AM
rexdenton Offline
rexdenton  Offline
Todd's (WildTsail) suggestion is good. I sailed that boat and it works better than mine, which was done the conventional way. However, also check to see that the hook freely swivels. Ours would catch on the mast, and did not freely swivel. This made taking the main down a bit of a hassle, as turning the mast would also turn the hook too, as there is a loop on the inside of the hook that can catch. A little tweak with pliers and no problem.
Nacra F18 #856
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247082
04/17/12 08:58 AM
04/17/12 08:58 AM
USA1273 Offline
USA1273  Offline
Thanks everyone, lots of stuff for us to try..... and good to know that we were not the only team struggling with this set up....
See everyone at the NE training Sunday.
F18 USA 1273
Re: Infusion Main Halyard (not) Locking (ing) [Re: goose151] #247095
04/17/12 01:49 PM
04/17/12 01:49 PM
Toronto, Ontario
pitchpoledave Offline
Toronto, Ontario
I have some with larger rings, about 1/4" larger if anyone wants..
I tried a larger Hobie ring on my F20c and I stretched it into an oval.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247350
04/22/12 09:57 PM
04/22/12 09:57 PM
USA1273 Offline
USA1273  Offline
Switched to our new Glaser main - locked on the first try every time, every session, this weekend.... looks like a ring vs. a headboard and cutting the boltrope down 2 inches makes a huge difference.
F18 USA 1273
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247390
04/23/12 02:46 PM
04/23/12 02:46 PM
Makes sense, the ring that hooks on the mast can't twist as easily with a head board.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247394
04/23/12 03:45 PM
04/23/12 03:45 PM
FWIW, I did some rigging on a 2007 Infusion over the weekend that included a new main halyard - the team complained that they had significant difficulty both raising and lowering the main, to the point that their halyard broke from pulling it so hard. I used a low-stretch halyard, cleaned out the mast track, lubed it with good silicon spray, and filed two pinch-points that appear to have resulted either from trailering or dropping the mast. Got a "thank you" email last night indicating that the main went up and came down on the first try. Seasonally checking the track, a good cleaning to get out the salt and sand, and using a quality silicon spray is a good idea.
Re: Infusion Main Halyard (not) Locking (ing) [Re: John Williams] #247395
04/23/12 04:30 PM
04/23/12 04:30 PM
JACKFLASH Offline
JACKFLASH  Offline
Silicone spray? Wouldn't a dry tef/Mclube be better in that it won't attract sand and salt to stick to it.
Collin Casey
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247407
04/23/12 08:09 PM
04/23/12 08:09 PM
http://www.westmarine.com/buy/products/14147-silicone-spray-lubricant-9oz.html
This stuff is great and doesn't gum up at all. More persistent than McLube, in my experience.
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247419
04/24/12 08:27 AM
04/24/12 08:27 AM
All great suggestions. Thanks!
As Paul said - switching to the Glaser main made a difference. I have now modded the Performance main to work the same. It no longer holds the rotating hook off to the side.
On Sunday we had to use the moving the halyard to the other side of the hook trick as well.
I agree with JW in regards to keeping the track clean and lubed. Probably worth putting McLube on the actual bolt rope as well.
Cheers,
Karl
Re: Infusion Main Halyard (not) Locking (ing) [Re: Karl Funk] #247420
04/24/12 09:00 AM
04/24/12 09:00 AM
Maryland
Kris Hathaway Offline
Maryland
Hoisting the main is probably the most ritualistic operation I follow. I always use the same "Aussie" halyard ring. The knot is always tied the same and always facing aft. The halyard is always on the port side of the "hook". As a result, it is always a clean hoist and douse.
Nothing worse than being on a crowded "beach" and have your hoist ring hung up. Especially after a challenging day of racing and the beer is cold.
Kris Hathaway
0 registered members (), 237 guests, and 106 spiders.
Posts267,056
