Re: C20na ... downwind nospin. traveler question [Re: ] #253120
10/04/12 10:36 AM
10/04/12 10:36 AM
Santiago, Chile
Andinista Offline
Andinista  Offline
Santiago, Chile
I found myself once returnig to the beach with strong wind blowing exactly in the same direction, in a narrow path with lots of obstacles. I centered the traveller and sheeted in. Then tried to control gybes by staying slitghtly out of DDW direction and making controlled gybes when necessary. Centering the traveller is a good idea, it depowers the boat in that case and also restrict the effect of an unwanted gybe. The problem is that things get scary very fast if you change direction, but I doubt that it happen primarily because of the traveller position. It's just because the main is sheeted in and you may not be able to sheet out fast enough. Landing was a bit scary actually. It wasn't sand but little stones, so I had to control the boat before landing. It wasn't 30 knots, in that case I'd have tryied to drop the main as suggested above.
Re: C20na ... downwind nospin. traveler question [Re: ] #253121
10/04/12 10:40 AM
10/04/12 10:40 AM
pgp Offline
pgp  Offline
The last time I was in this situation, the wind was much lighter than 30. I was trying to fetch the dock at the Sanibel boat ramp (not the mainland ramp at Punta Rassa), the wind was coming off the land and would switch directions wildly and puff from near zero to 15-20 in an instant. Being in no particular hurry, I just ran the travel down about a foot sheeted the main tight but not absurdly so. That allowed me to hold the bows off the wind for ease of steering and depowered the main all at the same time. It was all together a pleasant 10-15 minutes, with me practicing the "hold the boat in one place" manuever.
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: ] #253122
10/04/12 10:55 AM
10/04/12 10:55 AM
M
MN3
MN3
M
I have gone out only 2x in above 25 intentionally. both times it was on a dart (18 & 20) and it got up above 40.
we were loving it on the dart 18.. until it got so hairy the skipper couldn't effectively steer it and we beached it about 1/2 mile south of our target sans damage.
The second time was with 3 of us on a dart 20... it was fast, furious and very wet... we were snapping battens left and right...
In hindsight... i'd probably stay on land
Re: C20na ... downwind nospin. traveler question [Re: ] #253123
10/04/12 11:19 AM
10/04/12 11:19 AM
pgp Offline
pgp  Offline
To me that's pointless. I've only done that once intentionally and it was immediately clear it was a mistake. We made it back to the beach with no damage and I've never repeated the mistake.
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: ] #253124
10/04/12 11:31 AM
10/04/12 11:31 AM
Usually my vote.
Usually.....
Semi funny. My crew lost the boat, I was still in the water. I slid back as she was drifting to the rear, and grabbed onto the rudder, she grabbed my foot. She yelled "Now what?!" I said climb me. The boat was drifting so fast I wasn't able to pull both of us up.
A weather station a mile or so away reported 60mph winds. It was definitely blowing like hell, but I don't think it was that high where we were.
Re: C20na ... downwind nospin. traveler question [Re: samc99us] #253127
10/04/12 11:53 AM
10/04/12 11:53 AM
Originally Posted by samc99us
Key is NOT to sail ddw. It's much easier and safer to reach a little with the traveler dropped, in conditions where hoisting the kite on a planning boat is dangerous.
The real question is what do you do when you are reaching at exactly 90 degrees to the wind and are fully depowered, traveled down and start running out of main sheet? This is with the crew on the wire, helm not because the waves are questionable.
We came to a consensus at the club this week but I'm curious what others think. Doesn't matter if is a spin boat or not for the most part but the main is a square top and fully powered up.
Try 32+ knots. You have no choice but DDW.
Try 40+ gusting to 50+ knots. Balls of steel+DDW seem to be the consensus. And people were giving me **** for wanting reef points in a new TheMightyHobie18 main.
You don't have a mainsail up the mast in that going downwind...unless the mast is pointed toward the bottom. Boats will auto-right in 35+ and won't even stay capsized unless they're turtled.
Re: C20na ... downwind nospin. traveler question [Re: Karl_Brogger] #253128
10/04/12 12:01 PM
10/04/12 12:01 PM
pgp Offline
pgp  Offline
Usually my vote.
Usually.....
laugh Did you find your hat?
Pete Pollard
Blade 702
Re: C20na ... downwind nospin. traveler question [Re: pgp] #253130
10/04/12 12:25 PM
10/04/12 12:25 PM
M
MN3
MN3
M
Gotta test the limits sometimes to know how far is "too far"
where i sail is protected from the gulf waves and if we capsize there is land within a mile or 2 in every direction. As long as the wind isn't pushing you out the pass into the gulf... your not gonna drift for to long...
even the 2nd time was fun and i had a cute girl screaming and holding on to me the entire time, meanwhile Capt Steve had a **** eating grin from ear to ear... the whole time, even when the battens were snappingin gusts around 45mph.
Both Darts handled the wind like a champ...
Re: C20na ... downwind nospin. traveler question [Re: Karl_Brogger] #253131
10/04/12 12:29 PM
10/04/12 12:29 PM
M
MN3
MN3
M
Usually my vote.
Usually.....
you dirty dog! - but i am gonna try that line next time i capsize with a hottie onboard
PS who took those amazing pictures?
Re: C20na ... downwind nospin. traveler question [Re: Karl_Brogger] #253133
10/04/12 12:46 PM
10/04/12 12:46 PM
tampa, fl
K
ksurfer2 Offline
ksurfer2  Offline
K
tampa, fl
Usually my vote.
Usually.....
Holy crap....this is the second photo sequence of you wiping out in one week. Either a) you wipe out A LOT, or 2) Photo boats seem to find you at the best possible times!
Re: C20na ... downwind nospin. traveler question [Re: ] #253135
10/04/12 01:17 PM
10/04/12 01:17 PM
M
MN3
MN3
M
Top pic gets my vote:
you see the hat in the air, and the crew falling into the drink through the trampoline
Re: C20na ... downwind nospin. traveler question [Re: ksurfer2] #253136
10/04/12 01:48 PM
10/04/12 01:48 PM
Yes, and yes.
0 registered members (), 108 guests, and 86 spiders.
Posts267,056
