Rob,
Take a look at this post with the drawing of the F16 rules; it may well help you understand the rules. A picture is more powerfull than a 1000 words Ehh ? (click on attachment ; right under the header of the post)
http://www.catsailor.com/forums/sho...2920&page=&view=&sb=5&o=The newer version of this is suppost to be placed on the website next week; but is has had this status for some 8 weeks now. I think I need to get my behind into gear and do it.
Maybe you can go directly to the pic by clicking this link :
http://www.catsailor.com/bb_files/22920-F16_rules_sketch.jpgIf your boat conforms to all these rules than your boat satisfies the limits set by the F16 class. Official recognision is achieved by having the design checked by your local F16 class representative for safety and compliance with the spirit of the rule (protection against rule beaters). This last issue should not pose any problems.
A class vote to allow a design in is only required when one or more specs break the F16 rules; In this case maybe the minimum weight will give rise to this but that we will only know after weighting a relatively new platform. MInd you the rules allow up to 7 kg's of corrector weights to be carried. So when your boat is say 102 kg's sloop rigged with spi (likely) than carrying some corrector weight avoid the need for a class vote. However in this case I advice to go for the class vote and get dispensation for being underweight. Your smaller mast and sailarea's which limit performance more than your light weight can correct out over should be sufficient to land the official status. Mosquito's have gone the road before you.
With respect to Mozzies and Cobra playing with spinnaker. I think it would be smart to combine these two in a formula class; both your numbers are relatively small and together you both have more fun and a better chance at keeping the design alive in the future. With a little luck the ISAF youth class decides on a design that is extremely close to your Mosquito's and Cobra's. This is likely when looking at the provisional handicap ratings of the entered boats. This may of course be an individual formula class of your own but when you choose to use the F16 setup and organisation then will make us all yet again stronger and more capable to promote fast 16 footers in the world as a whole. Like I said before I see eventually the Prindle 16 and Hobie 16 with spi join too. Maybe even the Dart 18's although I'm told these boats don't take the spi that well. All of these classes will either die out or loose alot of sailors top the newer spinnaker boats. This will be a pitty. All of these boats are extremely similar in overall performance and could easily race first in wins against one another. Seriously 1 or 2 handicap points difference between these boats is nothing.
It would also be best to settle together on one spinnaker size and for that a central organisation is practical. It seems like 14-15 sq. mtr. is the right kite for these boats and the draw height their masts can accomodate.
In this setup I see potential in the area's of South Africa, Australia and also Europe and USA. The latter having huge fleets of old secondhand H16 and P16; Europe as a good sized Dart 18 fleet as well as does South Africa. This is an important breeding group of new sailors. We start sailing cats on one of these older secondhand platforms and this is where the new breed of racers will come from. Any class would do well to remind itself of this very important fact.
These are my views on the subject. We would welcome you in but you shouldn't feel pressured to do so. Spirit of the F16 rules right ! Everbody is welcome and we will cooperate with every other catsailor who wishes to do so to advance us both.
In this respect, I haven't been able make much headway in this but we're looking to extend the same hand towards the I-17 and FX-one sailors. Again it is more fun for us all and it only those few handicap point between us is nothing when compared to the generally huge difference in sailor skills. The best sailor/crew will come in first anyway.
Answering your questions :
1. Is there a formal decision required to establish beyond doubt if the Cobra qualifies, if so, who by? and how/when does it get to happen?
Yes, depending on full compliance or not is maybe be done by your local representative (Phillip Brander) or done by a class vote. This is a formality preventing every builder "using" the F16 name as well as an extra check on design specs and safety. The vote is required when one of the specs is non compliant with the F16 class rules. To prepare for this vote a temporary dispensation reviewed yearly) dispensation can be given by your local representative. Or you could invoke the grandfather rule and get the same dispensation from your local representative.
Summary : Introduction and grandfather dispensation can be handled by your local representative on your request. "Qualification beyond a doubt" I take that as "full compliancy status" can only be achieved by having your boat measured and found to be in compliance with all of the F16 rules. This will give you a measurement certificate which will garantee your participation as F16 in all events. Again your local representative can do this on you request. Dispensation for non-compliance must be accepted by the class as a whole in a vote and your local representative can help you in preparation for this.
>>2. What then is the full list of cats accepted for the class?
Fully optimized F16's (no restrictions on participation)
Taipan 4.9 + spi (Foundation boat)
Taipan F16 (as supplied by AHPC with wider beam, different rear beam, F16 sails, different jib)
Stealth F16
Stealth R (Foundation boat)
+ several one-off (Bob Hall's, Michael Coffman's, Harry Slump, Stewart's, Mine)
+ Blade F16 (Pending; measurements of prototype still have to be performed)
Dispensated :
Spitfire (dispensated for 18 sq. mtr. spi)
Cirrus Energy (dispensated for 18 sq.mrt. spi)
Mosquito spi (dispensated for underweight)
Grandfathered :
Bim 16 and Bim Javelin 16 (on officially fixed specs of respectively jan 2001 and nov 2002)
Nacra Inter 17 (intentionally included when writing the grandfather rule)
Hobie FX-one (intentionally included when writing the grandfather rule)
>>>3. At a F16 event, how does it work with the 'open class' and the fully compliant boats. Is this 2 results within the one race ?
Mostly the rules concerning the Fully compliant and open classes are written to have a handle to protect ourselfs from any design making use of the open dispensation and grandfather rules to exploit any loophole to the more strict F16 box rule. In extreme cases a group of organisers may want to limit the participation in major events to only fully compliant designs for to prevent abuse or because allowing others in would nullify the purpose. An example of the last is the following project :
http://www.geocities.com/f16hpclass/Dutch_coast_challenge_2004.htmlThis is going to be a promotional tour of F16's in Europe (in concept stages at this time) and allowing Hobie and Inter designs in would nullify the promotional effect.
With these footnotes I can assure sailors of dispensated and grandfathered boats that the Spirit of the class is layed down to be as open as possible. In addition to my role as chairman I'm also the local representative of the Dutch, Belgium and German scene. I this last role I WILL NOT EXCLUDE any of the grandfathered of dispensated boat from any F16 event except the promo tour. Nor from any future Open Dutch Nationals. It is my full intention to hold all events as "open" where by the local national champ will be the highest placed local sailor. So in this situation, Open and Closed class designs will share the same course, start fleet, and final result listing on elapsed times. Solo and doublehanded setups will also share the course, start fleet and final listing.
Only rule to keep the racing and the times under control will be the use of the following rule :
The finishing window will be as follows :
15 minutes after first finisher < finish window < (Elapsed time first finisher * 1,30) + 5 minutes
Examples :
First finisher comes in at 25 minutes. Finish window is then 25 minutes to 40 minutes = (25+15) since the start. = 15 minutes open, the minimum.
First finisher comes in at 50 minutes. Finish window is then 50 min to 50*1.3+5 = 70 minutes since the start = 20 minutes open.
First finisher comes in after 2 hours 3 minutes . Finish is then 123 min to 123*1.3+5 = 164.9 = 165 min. = 42 minutes open
Anybody who arrives after this time or abandons the race gets the number of points of the last finisher + 2
In this setup I don't care wether a Hand Primowees enters himself on a Prindle 15 as long as his boat is checked for F16 compliance, he accepts to race on elapsed time and finishes in the finish window or abandons the course to allow the second start to commence. This Hans guy actually beats over halve the fleet of much faster boats each year at the Texel race on elapsed time. Even a-cats typically only finish some 15-20 minutes of him after over 3 hours of sailing. He is that good on that boat and he can probably beat us all on elapsed even when we sail F16's.
Sparring against him makes us faster and gives him a real challenge that he is looking for. Why should we disallow him because he is not sailing the latest F16 model ?
With Steve in South Africa I discussed the possibilty to make the participants more equal in bigger events like World Cups. The general idea is that the national champions of each area is invited to participate on a charter boat while the other need to bring their own boats. For our baby F16's the idea is to have wild cards for them which they can earn by achieving a certain result less then become local F16 champion. When this happens the class and builders will issue a wildcard to these teams and arrange preference to fully optimized charter boats for these crews. Both Stealth and AHPC have indicated in the past their willingness to help in such charter schemes.
Baby F16's are the boats with a Texel handicap higher then 112. Mosquito spi, Cobra Spi, H16 spi, Prindle 16 Spi, Dart 18 spi and ISAF youth boat to be. Crews with boats with a handicap of less than 112 will have to become local champion on elasped time results.
As a baby F16 you can become local champion as well and not invoke the wildcard rule. Personally I wouldn't never underestimate the Singlehanded mosquito with spi.
The red thread in all this that we all want to have fun, have as many competitors on the water as we can, make the (monetray) threshold to wannabee racers as low as possible and want to exchange idea's regarding spinnaker sailing. Together is better then seperated.
WOuter
