| Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257320 02/11/13 04:41 PM 02/11/13 04:41 PM |
Posts: 12,310 South Carolina | I'd like to re-iterate that it wasn't for lack of maintenance on the boat that caused this, rather a stopper ball that should have been a bit smaller. So a lack of PROPER maintenance?
Jake Kohl | | | Re: Hagar Feb 9?
[Re: ThunderMuffin]
#257371 02/12/13 03:55 PM 02/12/13 03:55 PM |
Posts: 382 SE MI / NE IN | Here was my little misadventure last month at Tradewinds. I think I have the dubious honor of being the only sailor to take an unintended swim that weekend. Fortunately, no damage and the water was warm. http://www.youtube.com/watch?v=RExuf_WlbRs My trap hook had some kind of spring clip retainer. When I went out, the hook/clip must have been just resting on the edge of the ring. As soon as I put weight on it, splash. Needless to say the clip was removed. My crew's first instinct with the main sheet wasn't quite spot on either... Later, trying to uncleat the center-sheeted main from in the water was a real PITA. | | | Re: Hagar Feb 9?
[Re: Karl_Brogger]
#257380 02/12/13 06:07 PM 02/12/13 06:07 PM |
Posts: 12,310 South Carolina | I've never thought about that. Taking the cleat off is the answer there I'd think. First thing I do with a new harness. As long as your bunji system is functioning properly, it keeps upward tension on the dogbone and the keeper isn't necessary. It's more of a liability in my opinion.
[Re: ThunderMuffin]
#257381 02/12/13 07:02 PM 02/12/13 07:02 PM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | Yeah, but capsizes are inevitable.
(edit)- I was talking about the mainsheet.
| | | Re: Hagar Feb 9?
[Re: Karl_Brogger]
#257383 02/12/13 07:10 PM 02/12/13 07:10 PM |
Posts: 12,310 South Carolina | Yeah, but capsizes are inevitable.
(edit)- I was talking about the mainsheet. Oh....I cleat the mainsheet all the time. I'm wimpy. I adjust it a lot but I do give myself breaks with the cleat. However, I'm johnny on the freakin spot with the uncleating flick at all times.
[Re: rehmbo]
#257384 02/12/13 07:13 PM 02/12/13 07:13 PM |
Posts: 12,310 South Carolina | Here was my little misadventure last month at Tradewinds. I think I have the dubious honor of being the only sailor to take an unintended swim that weekend. Fortunately, no damage and the water was warm. http://www.youtube.com/watch?v=RExuf_WlbRs My trap hook had some kind of spring clip retainer. When I went out, the hook/clip must have been just resting on the edge of the ring. As soon as I put weight on it, splash. Needless to say the clip was removed. My crew's first instinct with the main sheet wasn't quite spot on either... Later, trying to uncleat the center-sheeted main from in the water was a real PITA. I don't think your crew was going to be able to get to the main sheet before he was sliding down the trampoline anyway - he didn't have many options. Can't you just reach around the rear beam while standing on the hull that's in the water to uncleat the main?
[Re: Karl_Brogger]
#257387 02/12/13 08:38 PM 02/12/13 08:38 PM |
Posts: 12,310 South Carolina | Aaaaa...I see. Crew had hold of the mainsheet before all this began...gotcha.
[Re: Gilo]
#257408 02/13/13 10:24 AM 02/13/13 10:24 AM |
Posts: 1,121 Eastern NC, USA | If you think one trap fail sucks.... Gilo - what happened here? Trapeze shackle at the top give way?
Tom | | | Re: Hagar Feb 9?
[Re: tshan]
#257505 02/14/13 11:50 AM 02/14/13 11:50 AM |
Posts: 5,590 Naples, FL | Props to Collin for a nearly perfect crew maneuver - didn't get wet until he stepped off. AND didn't go through the main unlike Tad's little vid at Hagar's And you're little pirouette wasn't bad either. Stick not broken, didn't hurt yourself, and the boat didn't sail too far without you... Yeah, ditch the keeper on your harness hook. Seems no good comes of that thing. Either hangs you up when trying to get out, or doesn't get you hooked in correctly.
227
guests, and 373
