mosquito best combination of parts #254263
11/02/12 05:35 PM
11/02/12 05:35 PM
gold coast
fast energy Offline OP
gold coast
hello all
a question of best hull shape , sail brand , rudder , centre board type , mast and rigging
i plan on building a new boat or good second hand in glass or a timber cheap boat
as i am on the gold coast there is not many boats to look at so the more info the better especially on brand and where to get these parts
does a hull shape suit a sail brand or can you mix up any combo
do you get a sail made to suit your sailing area and boat weight
thanks for your time and info
brett
Brett Kelly
Fast Energy
Gold Coast
Re: mosquito best combination of parts [Re: fast energy] #254320
11/04/12 06:05 PM
11/04/12 06:05 PM
Gippsland Lakes
mitchellsailor Offline
Gippsland Lakes
The Russel Denholm mould, sometimes referred to as "Fay" is regarded as the best within the rules and what all new composite boats have been produced from for a fair while. Phillip Warren-Smith is who you contact for more info on buying a new boat (link on mozzi wbsite)
Irwin is widely regarded as the best & most common brand for mainsails & spinnakers, while Goodall is used by top competitors as well (it's a more powerful sail)
As far as foils go there is alot of personal preferences but basically there is a trend for more high aspect foils with tapered trailing edges. (most are older generation A class stuff)
Mast is available from the association and is slightly softer and lighter than alot of the older boats.
That's fairly brief so feel free to ask more
Mosquito 1750 Bonnie-GLYC / Peninsula
The plan was simple.... Like my brother in law Phil, except this plan just might work!
Re: mosquito best combination of parts [Re: fast energy] #254326
11/05/12 01:09 AM
11/05/12 01:09 AM
gold coast
gold coast
thanks mitchell
i will investagate your info
thanks brett 0437 81 81 81
Brett Kelly
Fast Energy
Gold Coast
Re: mosquito best combination of parts [Re: fast energy] #254363
11/06/12 05:45 AM
11/06/12 05:45 AM
Matt_Stone Offline
Matt_Stone  Offline
Again, Irwin is the most common sail on the water in Victoria, as its the one cut and measures right, Goodall sails, is more custom if you know what you are doing! the mast you can from Phillip (website)and I Matt can make up the spreaders, spanner, top hook, boom cars, gooseneck ect.
You can get a whole spin kit from me as well.
Matt
Re: mosquito best combination of parts [Re: mitchellsailor] #254440
11/07/12 04:01 PM
11/07/12 04:01 PM
To windward of you!
Sixth Element Offline
To windward of you!
HI Brett,
dispite the Vics bias opinions there are more than the two (Irwin and Goodall) sailmakers making mossie gear. Over here in SA Alegayter Sails (the only sail maker that actually sails the class) and Clifton are making sails aswell as Ashby in Vic. I also make tramps and other sundries at Alegayter sails.
as other have mentioned alot of things like masts and beams are available from the association.
The rudders and contre boards im using are from JK Fibreglass in bendigo who also makes the new "Fay" hulls.
"Sixth Element"
1782 MK2 w/spinnaker.
Lake Bonney Y.C.
National Sec. / S.A President / S.A Measurer / Commodore LBYC
Re: mosquito best combination of parts [Re: fast energy] #254449
11/08/12 05:18 AM
11/08/12 05:18 AM
Matt_Stone Offline
Matt_Stone  Offline
sorry, i forgot to mention you!!
Re: mosquito best combination of parts [Re: fast energy] #254452
11/08/12 07:26 AM
11/08/12 07:26 AM
gold coast
gold coast
thanks for all the info the responce has been great for someone looking to get into this class
the question i have , can you have a timber boat that still goes well in compertition or would timber only suit club racing
do the fay hulls make a large differance to hull speed , stiffer ,and more volume
if fay boat is faster how can you or could you inprove the timber boast speed
thanks brett
Brett Kelly
Fast Energy
Gold Coast
Re: mosquito best combination of parts [Re: fast energy] #254459
11/08/12 11:39 AM
11/08/12 11:39 AM
Gippsland Lakes
Gippsland Lakes
-Trying to answer as best I can-
Just to clarify the fay hulls are the absolute largest(fullest/most buoyant) that can fit in the mosquito template on every measurement as well as having alot more rocker than all shapes that came before it. They can be pushed a bit harder downwind and because they sit "on top of the water" they tack a fair bit better.
Basically if you follow multihull design for the last 40 years you will see a trend from very skinny sleek hulls that "cut" the water extremely efficiently-to "fuller" hulls with more buoyancy that can cope with alot more powerful rigs and hence go quicker in a broader range of wind ranges.
the majority of wooden boats have some age on them and were built to a different mindset, it's not that they couldn't get the "fay shape" it's that they chose not to. there are a few wooden boat builders on this forum who know more, but if you have the skills and the will then making a competitive wooden boat is very possible.
Re: mosquito best combination of parts [Re: fast energy] #254460
11/08/12 11:52 AM
11/08/12 11:52 AM
Gippsland Lakes
Gippsland Lakes
having said all that a Fay boat WILL NOT just sail past you, far from it. we're talking tenths of a knot if that and the best sailor will ALWAYS win, 4 out of the top ten boats at last nationals were not Fay. You have to be very very good for the boat to be the difference, I'm just trying to properly inform
Re: mosquito best combination of parts [Re: fast energy] #254483
11/09/12 02:17 AM
11/09/12 02:17 AM
Matt_Stone Offline
Matt_Stone  Offline
i like to add that a timber home built boat from S.A did come 8th overall in the last nationals at southend. as mitch said, the best sailor will ALWAYS win.
Re: mosquito best combination of parts [Re: Matt_Stone] #257391
02/13/13 01:48 AM
02/13/13 01:48 AM
Gold Coast QLD
Damo Offline
Damo  Offline
Gold Coast QLD
Hi Guys.
Just reading the above info,so although the 1990's Boyer hull is no doubt outdated buy the current shape, as a home build would you consider this to still be reasonbly compettive in the right hands if well sailed?
Damo smile
Damien 1820 Raw Prawn (under construction)!!!
QLD
Re: mosquito best combination of parts [Re: fast energy] #257392
02/13/13 04:17 AM
02/13/13 04:17 AM
Matt_Stone Offline
Matt_Stone  Offline
yes they are quite compettive, if sail right, look at recent nats, mitch on 1747 and nic on 1749,
Matt
Re: mosquito best combination of parts [Re: Damo] #257586
02/18/13 07:35 PM
02/18/13 07:35 PM
Scarecrow
Scarecrow
Originally Posted by Damo
Hi Guys.
Damo smile
Damo,
there is info around about adding volume in Boyer Tornados basically they were popping the decks off, forcing shape into the bows with extra frames then putting a new deck on. I can't find the info online (its there somewhere), but if you're nice to them the Somers boys might get Griffo to dig them up for them.
Re: mosquito best combination of parts [Re: fast energy] #257592
02/18/13 10:44 PM
02/18/13 10:44 PM
Gold Coast QLD
Damo Offline
Damo  Offline
Gold Coast QLD
Thanks Chris
The patterns that came with the mould seem full in the bow and certanly wont fit while the hull skin is in the mould so before I finalise the bulkheads and deck the hulls I was going to check them in the tempalates before I go any further as wasn't a 100% sure, but after your comments this makes sence but I will check first. Thanks for the info.
Damo
PS Did you end up buying a Mozzie?
QLD
Re: mosquito best combination of parts [Re: Damo] #257595
02/19/13 03:13 AM
02/19/13 03:13 AM
thricebitten
thricebitten
Thanks Chris
Damo
No he bought a son of Mosquito wink Was at the Nats after the Main event at Paynesville. confused
Re: mosquito best combination of parts [Re: fast energy] #257625
02/19/13 05:33 PM
02/19/13 05:33 PM
Scarecrow
Scarecrow
By the time I got my shi t sorted the Mossie fleet at my local club was on the fall while the Taipans were on the rise (why sail in a fleet of 4 on a good day, when you can be in a fleet of 5 on a bad day). So I bought an old wooden Taipan and spent the winter sanding and fixing.
Painsville nationals were a lot of fun, but having only sailed the boat in 8 races before the event all but 1 of which was in less than 7 knots I was always going to be at the back of the fleet.
Re: mosquito best combination of parts [Re: fast energy] #257719
02/21/13 06:51 PM
02/21/13 06:51 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
G'day can you guys recommend a place to get new beams and tramp tracks?
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: mosquito best combination of parts [Re: JeffS] #257723
02/22/13 02:22 AM
02/22/13 02:22 AM
thricebitten
thricebitten
Hi Jeff,
I get them from my local alumimium supplier/fabricator. Track is what they use for caravans etc. He has to order in the beam section though. I believe S.A. assoc has beam section also.
0 registered members (), 259 guests, and 102 spiders.
Posts267,056
