| Re: Refinishing Wave Hulls, XIM Primer
[Re: carlbohannon]
#257881 02/27/13 05:21 PM 02/27/13 05:21 PM |
Posts: 921 Alachua, FL | Has anyone tried or heard (1st hand) of anyone using X I M primer on Wave Hulls?
I stopped to talk to some painters that were painting roto molded decorations, to see how they got the paint to stick. They were using X I M Primer for plastics. According to the painters, this stuff is more of a glue than a paint. You rough up the surface and the primer fills the scratches leaving a smooth surface for painting. It looks like they have a shitload of different primers. XIM Primers Which one are you thinking of?
Jack Woehrle Hobie Wave #100, Tiger Shark III HCA-NA 5022-1 USSailing 654799E Alachua FL/Put-In-Bay | | | Re: Refinishing Wave Hulls, XIM Primer
[Re: carlbohannon]
#257882 02/27/13 05:40 PM 02/27/13 05:40 PM | xanderwess
| xanderwess
Unregistered | What the frak are you painting the wave hull for? Boat is slow enough without doing that to it. I used wetsand paper on all the blemishes. It still looks like butt but what are you gonna do??
[Re: carlbohannon]
#257901 02/28/13 10:37 AM 02/28/13 10:37 AM | xanderwess
| xanderwess
Unregistered | Let me know how it works, my boat looks like it was dropped off a trailer at road speed. Needs some love. | | | Re: Refinishing Wave Hulls, XIM Primer
[Re: carlbohannon]
#257963 03/01/13 10:01 AM 03/01/13 10:01 AM | xanderwess
| xanderwess
Unregistered | I did exactly that, but didn't want to admit to it here on the forum. If I took a torch to my boat, imagine the shiz I would get from everyone! It worked for me too (just like Rick did) I heated the area with a wider flame, then heated up a flat narrow scraper to redhot and it seemed to help. I sanded with some heavyish grit black wet sand paper and smoothed it up as nice as I could. Worked well enough to stay in sight of Glanden for a few races last fall Funny as hell! | | | Re: Refinishing Wave Hulls, XIM Primer
[Re: carlbohannon]
#258449 03/20/13 10:09 PM 03/20/13 10:09 PM |
Posts: 778 Houston | update I think I finally found a way to smooth the hulls. Forget he putty knife. I put a flame spreader attachment on my torch, to flame smooth the hulls. http://www.acehardware.com/product/index.jsp?productId=2564149&cagpspn=plaAs I was working I noticed the flat side looks like a red hot putty knife. It works. I was able to build the skegs back to about the original shape. You have a hot scraper or you can melt braze rod by pressing the flat side against the braze rod and the braze doesn't stick to it. Just keep the flame level to about half and don't point the flame directly at the hulls when you use it this way. Also I found that the 5200 I applied to hot hulls, last year stuck a lot better than when I applied it to a cold hull. See the West System Video about "activating plastic". | | | Re: Refinishing Wave Hulls, XIM Primer
[Re: carlbohannon]
#258642 04/01/13 10:10 AM 04/01/13 10:10 AM | xanderwess
| xanderwess
Unregistered | You won't. It is not nearly as easy as it sounds. This works fine for tiny scratches and gouges but you won't be putting a hole in anything. This boat is a tank, you'd need a gun to put a hole in it. | | |
108
guests, and 86
