Mozzie Board case #259213
04/26/13 08:29 PM
04/26/13 08:29 PM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hey Guys, Just looking for some advise. Im working on the foils and board cases shortly for the hulls. Has any one built the board cases in the same shape as the foil in-staid of the rectangle on the timber hulls. For example can the foil shape be carried right through to the deck so when you look down onto the deck you see the case opening as an aerofoil shape not a rectangle "hope this makes sense"?.
Damo :-)
Damien 1820 Raw Prawn (under construction)!!!
QLD
Re: Mozzie Board case [Re: Damo] #259215
04/27/13 02:04 AM
04/27/13 02:04 AM
M
mosquito Offline
mosquito  Offline
M
The boats being built by j.k fiberglass have this you can contact him on 0402456743. Might be worth a chat to he is building new boats and boards at the moment
Re: Mozzie Board case [Re: Damo] #259218
04/27/13 06:18 AM
04/27/13 06:18 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks for the tip and contact. Much appreciated
Damien
QLD
Re: Mozzie Board case [Re: Damo] #259221
04/27/13 10:42 AM
04/27/13 10:42 AM
Matt_Stone Offline
Matt_Stone  Offline
hey guys,
i do have the lastest boat on the water, the bottom of hull is shapped to the board and the case, but the deck is a sqaure hole gong into a shaped casing, deck is old mould) but im sure u can do it, as long its in the rules.
Matt
Re: Mozzie Board case [Re: Matt_Stone] #259224
04/28/13 06:22 AM
04/28/13 06:22 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Hi Matt. There is no other benefit other than easier for me to build and no mention in the rules regarding this, thanks for the tip,
Damo
QLD
Re: Mozzie Board case [Re: Damo] #259351
05/05/13 03:50 AM
05/05/13 03:50 AM
Schnoogie84 Offline
Schnoogie84  Offline
Hi Damo, I am in the process of rebuilding a Mossie, one of the things I have done was replace the old cases and boards with some I bought from JK Fibreglass. As mentioned, these cases are moulded to the board. To fit them (after glassing the old slotss). They have a lip so that you can epoxy them so the underside of the deck. To make the gluing easier, I built a false deck out of wrc and glued the boards to that, then when it came to gluing to final deck, I epoxied and nailed the deck to the false deck, then routed out the slots. Boat still isn't in the water, however it worked quite well.
Re: Mozzie Board case [Re: Damo] #259383
05/07/13 04:35 AM
05/07/13 04:35 AM
Gold Coast QLD
Damo Offline OP
Damo  Offline OP
Gold Coast QLD
Thanks Scnoogie84
The build has slowed for a while due to work and no time(staff on holidays)but the idea helps, thanks for the tip, much appreciated, I should be back onto it in six weeks
Damo
QLD
Re: Mozzie Board case [Re: Damo] #259574
05/13/13 04:39 PM
05/13/13 04:39 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Originally Posted by Damo
.....can the foil shape be carried right through to the deck so when you look down onto the deck you see the case opening as an aerofoil shape not a rectangle ....
Mine's a timber hull and deck and has the "look" your chasing..... rectangle opening on the deck whilst the other side is aerofoil shaped... the boards themselves are rectangular only for the depth of the hull.
Mine was epoxy filled for ~20mm at the bottom and then shaped to suit the board's curve..... they are a very firm fit and have minimal forward/aft movement.
I can do some pics if your interested in going down this path
wink
Kingy
& now Mosquitos #1182 & #1740
Re: Mozzie Board case [Re: Pirate] #259582
05/14/13 12:09 AM
05/14/13 12:09 AM
No Turbulence Offline
Hi pirate,
Which boat do you have? And where are you sailing?
No Turbulence
1774
Re: Mozzie Board case [Re: No Turbulence] #259604
05/14/13 04:07 PM
05/14/13 04:07 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Jurassic Karp..... 1740 .... TBA wink
Kingy
Kingy
0 registered members (), 108 guests, and 112 spiders.
Posts267,056
