| Hull Cradles #262987 08/29/13 07:06 AM 08/29/13 07:06 AM |
Posts: 22 | Does anyone know where I could find some metal hull cradles? Preferably ones that aren't carpeted or padded yet. The fiberglass ones seem to break often with a little abuse and I would like to put something other than carpet on them to try something new.
"Nothing that is worth knowing can be taught." ~Oscar Wilde RPSailing.blogspot.com
| | | Re: Hull Cradles
[Re: RParentsail]
#262992 08/29/13 08:12 AM 08/29/13 08:12 AM |
Posts: 5,590 Naples, FL | I have a set of fiberglass ones never used (still in box - with carpet) for an N20 or other symmetrical hull.. Can't remember if they've got the pivot bracket or not on them already...
| | | Re: Hull Cradles
[Re: RParentsail]
#262999 08/29/13 09:30 AM 08/29/13 09:30 AM |
Posts: 932 Solomon's Island, MD | On my last trailer the cradles had foam under the carpets. This is what I should do with my current cradles, but it's a pain removing the carpet. Others have been trailering with throwable life jackets between the boat and the rollers. What is the consensus on reducing shock load's on the boat with the use of foam?
What are you going to padd/carpet the metal hull cradles with? I don't think they exist. We might could fabricate some but big might, they are a tricky part and lend themselves more nicely to fiberglass. I haven't had any issues with the fiberglass cradles if you don't over-tighten the bolts.
Scorpion F18
| | | Re: Hull Cradles
[Re: bacho]
#263035 08/30/13 07:13 AM 08/30/13 07:13 AM |
Posts: 12,310 South Carolina | does anyone have pictures of those stamped cradles?
Jake Kohl | | | Hull Cradles, make them yourself cheap and easy
#263230 09/05/13 11:51 AM 09/05/13 11:51 AM |
Posts: 144 Near SLC, Utah | I had an awful time finding hull cradles that were cheap, tough and readily available.
I finally found a broken section of thick gauge and large diameter PVC pipe at a constructions site, in their dump pile.
It was given to me after a short conversation with the site foreman.
I took the broken piece home.
From this discarded PVC remnant, I cut four pieces to the shape I wanted.
After marking where I wanted the new cradles to support the cat on the trailer, I slid the cat off the trailer and capsized it on my lawn.
I then placed towels on the keel, at these marked location and used my wifes kitchen oven to heat the four pieces that I cut from the salvaged PVC remnant.
You have to watch the heat carefully, but the PVC will quickly become very pliable and rubber-like.
Using oven mitts I gingerly removed these pieces from the oven and placed them on something to carry them outside and to my overturned cat.
I then placed the heated PVC shapes on the boat's keel at the right locations and let them cool.
When cooled, they returned to being as rigid and tough as before the PVC material was heated and shaped exactly to the shape of my hull, in the desired locations.
I then cut two slots in each of the new cradles, where I used large hose clamps from Home Depot's plumbing Department to affix them to each end of my trailer's bow and stern cross member supports.
After gluing and cutting a bit of new carpet remnants obtained for free from a carpet shop, to pad the inside of these new cradles, I was ready to flip the boat right side up and put it back on my trailer.
These are absolutely the best cradles I've ever used and they are tough, resilient and sitting in the hot summer sun hasn't caused any deterioration that I can see.
I still have enough left over PVC material for a few more cradles, when I want to replace those on my other beach cat trailers.
Try it, you may find that you like them as much as I do. These are cheap, easy, tough and made from readily available materials if you just keep your eyes open and ask a construction site foreman.
A cold soda in hand, may help a bit with the transaction.
| | | Re: Hull Cradles, make them yourself cheap and easy
[Re: RParentsail]
#263233 09/05/13 01:12 PM 09/05/13 01:12 PM |
Posts: 932 Solomon's Island, MD | I'd love to see a photo of Jill's stamped aluminum cradles.
Tom,
Can you post photos? I am curious what beach cat you have-this sounds like a reasonable solution for a Hobie 16 and maybe even a Hobie 18. A modern F16 and F18 have wide hulls; wide enough I'm not sure PVC is available in near the desired width
You most also excuse the below tirade. I like the creative use of someone elses trash to save $200+ on hull cradle. But I also don't like killing people.
From this website, http://completewastemgmt.com/education/backyard-burning/: "it only takes 5 ounces of burning PVC to give off enough hydrogen chloride gas to kill the occupants in an average size bedroom in ten minutes."
Using a kitchen oven to melt PVC is pretty risky business. Not something I could endorse to others. Would I do it myself? Perhaps, but I have a hot box with digital thermostat for this kind of situation. If you accidentally melt PVC in your oven that oven very well could be toast; cleaning it up would be a total mess and the toxins left behind are pretty nasty. New ovens are $$$.
You can replace the carpet with plastic on the hulls and layup some fiberglass cradles in a similar time frame. Materials costs is about $50.
Scorpion F18
[Re: RParentsail]
#263249 09/05/13 07:27 PM 09/05/13 07:27 PM |
Posts: 144 Near SLC, Utah | Samc99us:
All good points.
I'll have to shoot some photos next time I'm at the lake house where my boats are stored and sailed.
Last time I checked, most anything that is in your car, garage or home, etc., when it burns, it all can kill you and others with the smoke and toxins.
Even your beach cat would probably kill you if you inhaled the toxins when burned...but your points are well taken.
The PVC isn't being melted, it is being softened.
One might be able to do that simply by placing the material into boiling water or subjecting it to hot air.
The PVC pipe I used was from a large diameter pipe, used in commercial construction and was about 12 inches in diameter.
When cut and flattened in the heat of the oven or what ever, gives you a piece that is nearly 18 inches wide by what ever length one chooses.
I don't recall cradles that are that big, so the final product is smaller than that for most beachcats and boats that I've seen.
That would be large enough for cradles on my Stiletto 27 if I weren't using rollers.
Cheeers | | | How to soften PVC to reform or shape it.
[Re: Dlennard]
#263261 09/06/13 08:06 AM 09/06/13 08:06 AM |
Posts: 144 Near SLC, Utah | SUBJECT: How to soften PVC to reform or shape it. This discussion got me curious, so I did a bit of internet research and found the following info: When they extrude PVC, the melting temperature is about 330 +/-20 F. depending on application. However, PVC softens at relatively low temperatures. This softening occurs at about 104 degrees Celsius, or 219.2 degrees Fahrenheit. Since water boils at 100 degrees Celsius, 212 degrees Fahrenheit under standard conditions at sea level, using boiling water (or steam) is an answer to how to heat the stuff to make it pliable enough to reshape it from a section of discarded construction site material into the shap of a cradle. This may also lessen the likelihood of accidentally burining the material and creating bad gases and toxin release. For your "Gee Whiz" file of perhpas useless but interesting information, you may wish to note the following: GASES • When you burn PVC pipes, you produce dioxins and hydrogen chloride. In addition, heated PVC can give off these dangerous gases without actually being incinerated. CONSEQUENCES • Exposure to dioxins can lead to cancer and damage your immune system and reproductive system. Hydrogen chloride gas is a corrosive gas that can damage your respiratory system and cause skin burns. Read more: http://www.ehow.com/facts_7687006_there-gases-heating-pvc-pipes.html#ixzz2e7FJAsYYOne should easily realize that all things can be dangerous, one way or the other. For example we know that we shouldn't breath smoke or noxious fumes from gasoline, smoke, cleaning solutions or other chemical. However, many of those same folks find it acceptible to smoke tobacco, work with and sand fiberglass, and get drunk on the weekends and think it is not only acceptable but great. It that ironic or what??? | | | Re: How to soften PVC to reform or shape it.
[Re: RParentsail]
#263264 09/06/13 08:18 AM 09/06/13 08:18 AM |
Posts: 932 Solomon's Island, MD | Tom,
Thank you for the information. The boiling water and/or grill trick seem most appropriate. These can be done outside where there is no risk of releasing harmful chemicals inside your home-just into the atmosphere for your tobacco-smoking neighbors to breath.
To be frank, smoking tobacco, sanding fiberglass and getting drunk are all MUCH less dangerous than breathing dioxins and hydrogen chloride. Most people don't do the above activities inside their homes, and if they do it's usually only once. Hydrogen chloride can cause permanent lung damage with relatively short exposure times. Again, I'm not saying this is a bad idea, just advocating the use of proper safety measures and doing this outside in a well ventilated area counts as a proper safety measure.
It does sound like this is much easier and cheaper than building fiberglass cradles.
Scorpion F18
[Re: RParentsail]
#263266 09/06/13 08:24 AM 09/06/13 08:24 AM |
Joined: Feb 2005 Posts: 4,118 Northfield Mn Karl_Brogger
Posts: 4,118 Northfield Mn | Guess I'll stand back a bit more next time I have a tire/pvc fire
[Re: Karl_Brogger]
#263275 09/06/13 10:31 AM 09/06/13 10:31 AM |
Posts: 5,590 Naples, FL | Guess I'll stand back a bit more next time I have a tire/pvc fire Then how will the marshmallows get toasted with you standing back so far? Oh,right... use my dandy asbestos skewer
1 registered members (Axsip),
383
guests, and 97
