Re: Beach Wheels .......... question ?????? [Re: northsea junkie] #268638
01/21/14 11:52 AM
01/21/14 11:52 AM
Hernando, Florida
M
Mlcreek Offline
Mlcreek  Offline
M
Hernando, Florida
How about a spring loaded cradle for the boat to sit on. You stand on the cradle to lower the boat and lock in location. When returning you step on the release and springs bring the cradle up under the boat. The whole cradle is mounted on beach wheels that can be towed by your trax. Just thinking.
Forrest
I-20
USA 645
" There ain't enough rum in the drum!"
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268643
01/21/14 01:41 PM
01/21/14 01:41 PM
Houston
carlbohannon Offline
Houston
Now that you mention it, a beach dolly using the new Polaris Airless Tires is build able and might work. They are probably designed for a heavier vehicle so they will be too stiff. You might be able to cut some of the supports out. I have seen some smaller ones (~12 inch?) overall diameter advertised for go karts that would handle about the right weight but I have not seen them actually for sale. I have been looking for a set to build a 4 wheeled Marstrom style dolly.
As for filling the tires with fluid, I saw that once. In the days before Slime, a guy reasoned filling the tires with anti freeze with stop leak would extend the life of his old beach tires. They were too heavy, they didn't roll, his girl friend was sitting on the tailgate with that look on her face and we were drinking beer and laughing.
Re: Beach Wheels .......... question ?????? [Re: bacho] #268644
01/21/14 02:10 PM
01/21/14 02:10 PM
Petten Netherlands
N
northsea junkie Offline
N
Petten Netherlands
Originally Posted by bacho
It seems to me that building a retractable system to bolt to the beams would not be all that difficult. They could include a linkage to turn them sideways as they are pulled up. The design in my head suffers greatly though when such a wide tire is required. It seems it would have to weigh at least 50lbs.
My greatest problem is: where do I leave the wheels during sailing. They ought to be onboard for my purpose, but sailing at sea and in a break with these big things sideways extended is impossible.
The only place seems to be flat, in front upon the tramp, but then I have to have a mechanism that not only retracts them but also turns them 90 degrees.
ronald
RAIDER-15 (homebuilt)
Re: Beach Wheels .......... question ?????? [Re: northsea junkie] #268671
01/22/14 10:08 AM
01/22/14 10:08 AM
deflate the tires for transport. Can you adapt them to those dual-stage hand pumps I see the kite-boarders use?
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268682
01/22/14 01:47 PM
01/22/14 01:47 PM
South Louisiana, USA
Clayton Offline
Clayton  Offline
Nah, just fab landing gear that retracts into the hulls just behind the dagger board wells. Pop them out as you get to the beach, step off the boat and wheel it in.
You can send my royalty check whenever you are ready! ;-)
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268683
01/22/14 02:05 PM
01/22/14 02:05 PM
M
MN3
MN3
M
just add foils, no need to retract
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268687
01/22/14 05:21 PM
01/22/14 05:21 PM
Or... sail it to the trailer.
Re: Beach Wheels .......... question ?????? [Re: northsea junkie] #268766
01/24/14 04:37 PM
01/24/14 04:37 PM
Victoria Australia
Pirate Offline OP
Pirate  Offline OP
Victoria Australia
Originally Posted by northsea junkie
My greatest problem is.....
Been turning this over in my head and can see all the issues you face with traditional gear....
Then I remembered seeing a pics of a hobie that had the beach wheels set into the hulls as a fixture, this was several years ago that I saw it and I have spent a couple of hours searching for those images again but with no luck....
From what I can recall, he cast a basic box into the bottom of the hull and then made a 2nd box that held the wheel and this box slid inside of the cast in box.... add a bit of silicone and it was installed and sealed.
the only images I could find are largely from aircraft wheel pants or wheel spats
but you get the idea.... wink
I'm sure you could design a simple yet effective setup that would work well, I don't think that the exposed tyre would cause that much grief if it was set in to minimise water turbulence ......
it would also mean no more lost/stolen beach wheels or exotic Lamborghini style door hinge setup so you can fold the wheels up onto the deck and take up room etc etc etc etc .....
just thinking out-loud
wink
Kingy
& now Mosquitos #1182 & #1740
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268768
01/24/14 05:37 PM
01/24/14 05:37 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Perhaps we are going about this wrong. Perhaps not a wheel but a set of tracks (like a bulldozer) of some kind that could either retrack into the hull or remove and store on the hull.
Mike Hill
N20 #1005
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268769
01/24/14 05:47 PM
01/24/14 05:47 PM
St. Louis, MO,
Mike Hill Offline
Mike Hill  Offline
St. Louis, MO,
Put a pair of these on your front beam. smile
Mike Hill
N20 #1005
Re: Beach Wheels .......... question ?????? [Re: Pirate] #268775
01/25/14 02:56 AM
01/25/14 02:56 AM
Petten Netherlands
N
N
Petten Netherlands
Thanks guys for presenting these visualised ideas.
Kingy, the problem with retractable wheels is the size which I momentary use. They are too large, especially for my Prindle like hull shape. ( I would choose for more reasons another hullshape now if I could do it again !)
Mike, I could make room for the retracted wheels behind my frontbeam by making a hole in my tramp (it's a net). But it's an interfering solution!
I will play further with all these ideas in my head, thanks again.
ronald
0 registered members (), 108 guests, and 86 spiders.
Posts267,056
