Page 10 of 19 1 2 8 9 10 11 12 18 19
Re: F85SR Concept Boat [Re: Rolf_Nilsen] #272617
05/21/14 04:48 PM
05/21/14 04:48 PM
phill Offline OP
phill  Offline OP
Sourcing the Lay Flat Tubing can be problematic because it usually comes in 800 meters rolls. I just got lucky as they found a roll with only 200 meters on it for me. Quite a bit more than I need so I can send you some if the size suits. The stuff I got gives a 360mm circumference which is Ok for the 90mm tubes I need to make. It comes in all sizes and thicknesses and this has got me thinking again- (this is not necessarily a good thing). The chap I dealt with said he would try to help out if I needed any other sizes in small quantities but I have to drive 85km to pick it up. He wouldn't ship it.
Still making the spinnaker pole and carbon boom this way will be fun projects.
Re: F85SR Concept Boat [Re: phill] #272670
05/22/14 11:41 AM
05/22/14 11:41 AM
I'll pass on it for now and rather see what I can find here on the other side of the planet when the time comes. Thanks for the offer Phill!
I have been busy the last month restoring a timber winch. Lots of rust and stuff. Your project looks much cleaner than my current workshop wink
Re: F85SR Concept Boat [Re: Rolf_Nilsen] #272726
05/23/14 12:45 PM
05/23/14 12:45 PM
Oh gelcoat masters, is this anything to be concerned about? Noticed it on my F24. Only on one side. Interesting zig-zag pattern
Re: F85SR Concept Boat [Re: waterbug_wpb] #272727
05/23/14 12:50 PM
05/23/14 12:50 PM
[img]http://i90.photobucket.com/albums/k245/jronline13/RudderCloseup_zps61dbe59b.jpg?t=1400866545[/img]
Here's a close up (don't know why it won't show up here)
Re: F85SR Concept Boat [Re: waterbug_wpb] #272795
05/26/14 06:11 AM
05/26/14 06:11 AM
phill Offline OP
phill  Offline OP
Jay,
The question may be better put to the f-boat egroup where you may find some F24 guys who have experienced the same problem.
Re: F85SR Concept Boat [Re: phill] #272816
05/27/14 09:29 AM
05/27/14 09:29 AM
Agreed, although I have a much tougher time navigating that site (and don't know all the street cred of the posters) smile
Love the progress you're making on yours!
Re: F85SR Concept Boat [Re: waterbug_wpb] #272821
05/27/14 05:19 PM
05/27/14 05:19 PM
phill Offline OP
phill  Offline OP
Jay,
All I can tell you is that my rudder is designed with two layers of double bias carbon wrapped around it over the leading edge with an extra one on the head. But this is a daggerboard rudders and doesn't have the cut out your swing rudder has.
If your rudder is built along the same lines where the core is cut out of the leading edge in the head (to make sure it kicks forward enough when down) they would most likely have to cut the Double Bias carbon and wrap each end of the cut fabric over itself.
The stress fractures that you see in the gelcoat are the same pattern as the DB carbon and may indicate the core is trying to shear. However if built the same as mine there are measures taken in the design in the high load areas to prevent this and the cracking may only be superficial.
I have my own view on which one but it's a guess.
An F24 owner that has experienced the same problem should know and therefore be more helpful.
If you are being led astray on the f-boat egroup it is likely that Ian will chime in and set it straight.
Re: F85SR Concept Boat [Re: phill] #272836
05/28/14 08:14 AM
05/28/14 08:14 AM
Thank you for your insight, Phill. I also emailed my local Corsair dealer for thoughts.
I'll poke around to see if this is something to worry about, as well as potential fixes if it ends up being an issue.
Perhaps buy a spare to keep on the boat (mostly daysailing in light conditions these days) in case something happens.
Re: F85SR Concept Boat [Re: phill] #272862
05/28/14 09:34 PM
05/28/14 09:34 PM
Phil, Wow! I can't believe I didn't know this thread existed. What a find! Thanks for the updates - enjoying reading through your progress!
I saw some questions about vacuum pump setups. I have a decent resource for plans at http://www.joewoodworker.com/veneering/welcome.htm
I built a vacuum pump system that has every bell and whistle you could ever imagine. I've pieced it together with spare parts and items bought from ebay - it's controlled by an Allen-Bradley PLC, has a ambient pressure chamber (so the pump doesn't startup with a vacuum on it's inlet), adjustable pressure switch that controls the cycling of the pump, small reservoir (PVC tubes), and a vacuum regulator so I can dial in exactly how much vacuum I'm after. I've also incorporated four spdt switches that trigger inputs on the PLC so I can set a crude timer in binary logic. 0001 is one hour, 0010 is two hours, 0011 is three hours, etc. Those will start an onboard timer that, once expired, will not cycle the pump anymore....like I said, overkill.
[Linked Image]Vacuum pump controller (no, it's not a bomb) by Green Room Graphics, on Flickr
Re: F85SR Concept Boat [Re: Jake] #272889
05/29/14 03:30 PM
05/29/14 03:30 PM
yeah, try telling that to Homeland Security...
Re: F85SR Concept Boat [Re: Jake] #272989
06/03/14 03:30 AM
06/03/14 03:30 AM
phill Offline OP
phill  Offline OP
Jake,
Thanks for the compliment.
It's a pity that Rick has taken down the photo album for catsailor because most of my earlier progress posts
presented pics that I had stored in the photo album.
Now the posts talk about photos that you can't see.
I still have the pics and in fact a quick check on the pics that I've taken shows around 2,000 photos of the work stored on my laptop.
It has been very useful. I work out a technique of doing something and sometime later want to replicate it,
I just find the relevant photos and it all comes back.
As far as vacuum pumps you have a pretty cool setup. It never occurred to me to put a timer on my setup.
I guess I'm not that bright as it would have saved me getting up in the early hours of the morning to turn it off
quite a few times.
All my really big vacuuming jobs are now done but I think I'll still get the timer setup for the many small ones
left to do.
I currently have the forward berth under vacuum. After that goes in I'll get back to making my carbon spinnaker pole and boom.
Re: F85SR Concept Boat [Re: phill] #273104
06/08/14 01:25 AM
06/08/14 01:25 AM
phill Offline OP
phill  Offline OP
I have a number of different projects on the go right now but with the fwd berth finally coming to a close I'll post a couple pics.
The first pic is taken down through the fwd hatch showing the molding that i put in place to form the glass flanges to sit the berth on.
Ian has a much simpler way outlined in the plans but I didn't think I could get the results that I wanted that way.
The second pic shows the glass flange with the form work removed and the hull under the berth all painted.
The third pic shows the berth all glued in.
With such a large area beneath the berth I want to make max use of it to store bulky lightweight items and so I put in two access hatches
to make sure that I could easily get to everything in storage. Along with a third round one fwd of the watertight bulkhead under.
fwd berth 1.jpg (1188 downloads)
fwd berth 2.jpg (1185 downloads)
Fwd berth 3.jpg (1186 downloads)
Re: F85SR Concept Boat [Re: phill] #273362
06/21/14 10:48 PM
06/21/14 10:48 PM
phill Offline OP
phill  Offline OP
I'm currently working at fitting the CMMs (Central Mounting Modules).
Its hard to bring one self to cut big holes in a hull that I've put so much work into but it has to be done.
The CMMS are what the folding mechanism bolts too and the beam fold down onto. So they are quite an important part of the boat.
In order to get the fwd CMM level I made up two simple timber frames and used threaded rod so I could make fine adjustments
to the heights of each of the 4 corners.
Prior to this I set the boat up level. The gunwales were made level with water levels and once the boat was level at the gunwale a plumb bob confirmed the bow was perfectly aligned vertically and when the plumb bob was set from the cabin centreline it went do to the keel C/L. I was pretty happy about this as it indicates the boat couldn't have much twist.
The following pics show some of the setup.
Fwd CMM fitting 1.jpg (1048 downloads)
Fwd CMM fitting 2.jpg (1038 downloads)
Fwd CMM fitting 3.jpg (1041 downloads)
Re: F85SR Concept Boat [Re: phill] #273363
06/21/14 11:08 PM
06/21/14 11:08 PM
phill Offline OP
phill  Offline OP
Once I had the fwd CMM held in place with bog I removed my timber frame and cut it down so I could use it to level the Aft CMM.
I put straight edges though the hull and used a tape to set the spacing. Then I braced the position of the Aft CMM by clamping a length of alloy box section two the two CMMs.
A friend brought around his engineers level to check my work leveling the beam pads. This level is extremely sensitive and it worked out my greatest error was only 0.35mm.
This was basically 3 thicknesses of peel ply under one end to make it perfectly level on the worst beam landing. I was very surprised it worked out so well.
A few more pics below.
aft cmm fitting 1.jpg (1037 downloads)
aft cmm fitting 2.jpg (1036 downloads)
aft cmm fitting 3.jpg (1037 downloads)
Re: F85SR Concept Boat [Re: phill] #273493
06/27/14 07:52 AM
06/27/14 07:52 AM
Phill,
do you know if this level of accuracy is the norm with homebuilders of Farrier designs?
Re: F85SR Concept Boat [Re: Rolf_Nilsen] #273515
06/27/14 04:50 PM
06/27/14 04:50 PM
phill Offline OP
phill  Offline OP
Rolf,
I don't know what others do.
It may depend on how much they enjoy building.
I enjoy what I'm doing and look at each task as a challenge to do the best I can.
Re: F85SR Concept Boat [Re: phill] #273522
06/28/14 09:30 AM
06/28/14 09:30 AM
Wayne Gorrie Offline
Hi Phil.
just joined this forum. I'm the guy who bought Glynn's F85SR in Subic Bay and shipped her to Vancouver Island where we are now sailing her and making her our own. Lots of changes. We have re-named her "Mail Order Bride". Having built my previous ultra light F 9AR Redshift I can appreciate what you are accomplishing with your build. Looks like you are doing a great job. Will be happy to share our experiences with the boat as we make changes and get to know her.
Wayne
Re: F85SR Concept Boat [Re: Wayne Gorrie] #273528
06/28/14 03:07 PM
06/28/14 03:07 PM
phill Offline OP
phill  Offline OP
Wayne,
Congrats on the new boat.
It would be great to hear about Mail Order Bride along with any changes.
Re: F85SR Concept Boat [Re: phill] #275295
09/11/14 05:36 AM
09/11/14 05:36 AM
phill Offline OP
phill  Offline OP
I haven't touched the boat in over 2 months . I've been busy making etching presses.
Just converting 100 yr old dissused washing mangles.
Given the time it takes it's a lot like boat building in as much as it is a labour of love.
Anyway now 4 more artists will have the opportunity to explore the many varied and creative
facets of the art of printmaking. Before my wife getting hooked on it I had no idea of how
involved and creative this art can be.
Hopefully by the end of next week I'll have made some more progress on the boat.
etching press 1.jpg (672 downloads)
etching press 2.jpg (670 downloads)
Re: F85SR Concept Boat [Re: phill] #275371
09/15/14 01:24 AM
09/15/14 01:24 AM
Hi Phill,
do you happen to have som "before" pictures of the mangles?
I notice some new looking brackets and bearings, but it would be fun to see your starting point.
I bet there are four happy artists now..
1 registered members (WorrellGal50), 641 guests, and 94 spiders.
Posts267,056
