g-cat 5.7 jib issues #274552
08/09/14 03:23 PM
08/09/14 03:23 PM
G
gcatwisconsin Offline OP
G
When I tack my g-cat 5.7 the jib sheet gets stuck or hung up on the mast. The jib does float behind the mast when filled but that is how it was designed. I am new to cat sailing but the design seems poor. Maybe I am just not tacking it right and pulling the jib over early but when I wait it still gets hung up. Any suggestion? Alos, I am new to the forum, not sure if I posted in the right location. If so, just point me in the right direction. Thanks
Re: g-cat 5.7 jib issues [Re: gcatwisconsin] #274553
08/09/14 03:59 PM
08/09/14 03:59 PM
SE MI / NE IN
rehmbo Offline
rehmbo  Offline
SE MI / NE IN
On an TheMightyHobie18, we tie a bungie on the dolphin striker strap, run it up to the diamonds and back down and tie off - a kind of upside down V shape. Use enough tension to keep it snug, but not so much that it interferes with mast rotation.
Probably not the right forum, but frankly, I'm not sure which one would be correct either.
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: g-cat 5.7 jib issues [Re: gcatwisconsin] #274561
08/10/14 12:33 AM
08/10/14 12:33 AM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Hopefully this photo will show clearly, we have the jib problem on my Nacra 5.8 so I run a bungy from the inside of the hull to the mast and back to the other hull along the front beam and another bungy from the jib downhaul to the mast which stops any issue of jib hangups
5.8 Closeup 2.jpg (170 downloads)
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: g-cat 5.7 jib issues [Re: gcatwisconsin] #274562
08/10/14 12:47 AM
08/10/14 12:47 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
My 5.8 used to get the jib blocks caught on everything! we rang a bungie from the diamond wires to the base of the bridal, ultimately cured by changing boats and going to the self taking jib.
you are in the right forum to buy a f18 and fix this problem for good smile
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: g-cat 5.7 jib issues [Re: gcatwisconsin] #276750
12/18/14 12:45 AM
12/18/14 12:45 AM
N
nawaz Offline
nawaz  Offline
N
this is very nice post
______________________
Nawaz
1 registered members (WorrellGal50), 641 guests, and 94 spiders.
Posts267,056
