Rudder Stocks #274937
08/24/14 03:40 AM
08/24/14 03:40 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Hi All,
I'm after a new pair of aluminium rudder stocks. It doesn't matter if they are assembled or not. Does anyone know where I can get a set to suit the current JK rudder blades.
Thanks all.
Nic Maan
Sanity 1815
Re: Rudder Stocks [Re: Nic M] #274938
08/24/14 06:14 AM
08/24/14 06:14 AM
South Oz
Phillip Offline
Phillip  Offline
South Oz
Contact me via email
ppearce@internode.on.net
I can supply bent sections to your required measurements.
To much detail is required for this posting.
Phillip.
Mozzie Aldebaran VI
1827
Re: Rudder Stocks [Re: Nic M] #274940
08/24/14 06:54 AM
08/24/14 06:54 AM
Melbourne
Nic M Offline OP
Nic M  Offline OP
Melbourne
Thanks Phillip,
I'll drop you an email tomorrow.
Many thanks.
Nic Maan
Sanity 1815
Re: Rudder Stocks [Re: Phillip] #274980
08/26/14 03:53 AM
08/26/14 03:53 AM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
Phillip,
have you ever used 10mm stainless tube for the cases ?
reason I ask is I have a set here in Stainless (off of Jurassic Karp) that failed at some stage, I was thinking of making a new set of them from stainless with a couple of minor changes...
wink
Kingy
& now Mosquitos #1182 & #1740
Re: Rudder Stocks [Re: Nic M] #274982
08/26/14 07:02 AM
08/26/14 07:02 AM
South Oz
Phillip Offline
Phillip  Offline
South Oz
Hi Pirate. No as I can't weld SS as I know you can. I have never had the aluminium fail although others have. My construction method only requires drilling, bolts, some thread tapping; no great skills required. I strengthen suspect places especially around the rudder pivot holes and the top pintle hole in the tiller arm with riveted SS plate; off the shelf fitting RF27. I also know the aluminium system is lighter than Carp's.
Thanks for your interest.
Mozzie Aldebaran VI
1827
Re: Rudder Stocks [Re: Phillip] #275001
08/26/14 05:02 PM
08/26/14 05:02 PM
Victoria Australia
Pirate Offline
Pirate  Offline
Victoria Australia
I intend to replace Karp's cases at some stage and will probably go with the alloy version of the ones I made for TwiceShy, both stainless and alloy sets I own have had a failure of some sort.....
Karp's failed at the hinge and Shy's failed at the lower pintle, and I can see why each failed at their give points and how to 'fix' the 2 issues without major effort.
I haven't finished with Shy's cases yet and intend to make more changes in order to get it a more workable system, even the latest changes I did will be improved on with very minor mods that will give a vast improvement yet again......
The lower stainless pintle plate will be first to be changed, unfortunately it's a new plate time again but should solve the rivet load problem, the 2nd mod will be to the carbon locking system,..... It will self release when it comes under excessive load
wink
Kingy
0 registered members (), 401 guests, and 98 spiders.
Posts267,056
