Quick change jib clew hardware #276865
01/03/15 12:18 PM
01/03/15 12:18 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Currently using a standard shackle to attach the sheet to the jib clew, but looking for something that allows lower-risk changing of clew board position out on the water. Recommendations?
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Quick change jib clew hardware [Re: rehmbo] #276866
01/03/15 02:07 PM
01/03/15 02:07 PM
Kingston SE South Australia
JeffS Offline
JeffS  Offline
Some infusions here at the Aussie nacra nationals are using little hooks like miniature downhaul hooks, ronstan supply them
Jeff Southall
Current boats
Nacra 5.8 1667 Ram Raider
Nacra 18 Square
Arrow 1576
Re: Quick change jib clew hardware [Re: rehmbo] #276867
01/03/15 05:12 PM
01/03/15 05:12 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Do you mean something like this?
link here
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Quick change jib clew hardware [Re: rehmbo] #276868
01/03/15 09:01 PM
01/03/15 09:01 PM
If you drill the clew plate out, the wichard snap shackle like what is likely on your downhaul works pretty awesome.
Re: Quick change jib clew hardware [Re: rehmbo] #276870
01/04/15 03:03 AM
01/04/15 03:03 AM
Hobart, Tasmania, Oz.
Dazz Offline
Dazz  Offline
I use a 4mm stainless steel carbine. (no drilling required) I don't like the S hook because they can fall off and stuff gets hooked up on them.
the wichard is a pain when they invariably get bent and don't close up properly. expensive too.
C2 AUS 222 by Goodall design
"Darph Bobo"
Re: Quick change jib clew hardware [Re: rehmbo] #276871
01/04/15 07:48 AM
01/04/15 07:48 AM
JeffS Offline
JeffS  Offline
link here
That's the one they work a treat when we were getting boats up the ramp in a blow they just unhooked it from the jib
Jeff Southall
Current boats
Nacra 18 Square
Arrow 1576
Re: Quick change jib clew hardware [Re: rehmbo] #276872
01/04/15 12:47 PM
01/04/15 12:47 PM
Greenville SC
bacho Offline
bacho  Offline
Greenville SC
Ive got one of these, I really like it. Has yet to come unhooked when I did not want it to. Ive heard that Harken has a similar product out.
http://www.tridentuk.com/gb/product-20mm-dynamic-hook-block-al-a2021hk.html
Re: Quick change jib clew hardware [Re: bacho] #276882
01/05/15 04:23 PM
01/05/15 04:23 PM
JACKFLASH Offline
JACKFLASH  Offline
I have been using the miniature hook as pictured above for a few years. I have never had an issue.
Collin Casey
Re: Quick change jib clew hardware [Re: rehmbo] #277750
03/01/15 05:09 PM
03/01/15 05:09 PM
Memphis, TN
Andy Humphries Offline
Memphis, TN
At APS part no HA2021HK, $22.10.
Re: Quick change jib clew hardware [Re: rehmbo] #277752
03/01/15 06:07 PM
03/01/15 06:07 PM
SE MI / NE IN
rehmbo Offline OP
rehmbo  Offline OP
SE MI / NE IN
Oooh. I like. Very Sexy
Jeff R
H18, C2 USA1193
cramsailing.com
crescentsail.com
Re: Quick change jib clew hardware [Re: rehmbo] #278688
04/30/15 09:26 AM
04/30/15 09:26 AM
Clermont, FL, USA
David Ingram Offline
Clermont, FL, USA
I am a HUGE fan of the quick release hook on the jib. I've been crewing for Dick MacDonald on his Cirus and we dumped it several times in conditions that will push you and being able to release the jib quickly made the process of righting the boat significantly safer. Having the jib completely free bought us more time to get on the boat and get things under control before it began its auto turn downwind. The boat was clearly more stable with the jib free. It was also very easy to reattach the jib once we were ready.
If you don't have a quick release please consider it.
F18 USA 242
http://www.solarwind.solar
0 registered members (), 511 guests, and 84 spiders.
Posts267,056
