Chicken line #277630
02/18/15 08:42 AM
02/18/15 08:42 AM
H
Hullflyer1 Offline OP
H
Looking for the simplest way to install a hand held chicken line on a 2005 nacra F18. Crew needs it when sailing to weather.
Thanks
Re: Chicken line [Re: Hullflyer1] #277632
02/18/15 09:25 AM
02/18/15 09:25 AM
If it's just to be hand-held, tie one end to the rear footstrap (or rudder gudgeon on the hull with a small shackle and drilled hole). Run the bitter end into the rear beam to a bunji to pull up slack.
[Linked Image]Untitled by Green Room Graphics, on Flickr
Re: Chicken line [Re: Hullflyer1] #277633
02/18/15 09:29 AM
02/18/15 09:29 AM
Thanks
Wait...to weather? He needs to tell his skipper to fly a hull better!
Re: Chicken line [Re: Jake] #277637
02/18/15 10:56 AM
02/18/15 10:56 AM
The mainsheet is a great upwind chicken line when you're pounding into chop...
Re: Chicken line [Re: Hullflyer1] #277654
02/19/15 09:04 AM
02/19/15 09:04 AM
H
H
Thanks I will use Jake's method, looks perfect for us. I'm 70 yrs old and she is 65.
Re: Chicken line [Re: Hullflyer1] #277657
02/19/15 10:42 AM
02/19/15 10:42 AM
You may need to take that all the way to the front beam so the crew will have easier access to it.
This is a little hard to explain without a diagram but on our distance race boats, we'll sometimes put a chicken line that goes from the front beam to the back of the boat that we can use when reaching in big waves. We'll tie the chicken line at both bitter ends just inside the front beam (tied to the internal casting that supports the beam bolt loads), and then tied to the rear rudder gudgeon. The chicken line goes through a micro-block at the rear beam and the micro block is tied to a bunji also in the rear beam. The micro block pulls the slack of the chicken line into the rear beam and leaves it tight against the hull. It's there for either the crew or skipper (or both) to grab and will help hold you from being washed backwards or forwards on the boat when extended.
We also have used some cleats on our trapeze harness spreader bar that we can drop the line into for convenience. It's a little hard to get the angles right on the cleat mounts but once it's right, it's really nice to have.
1 registered members (windman), 470 guests, and 110 spiders.
Posts267,056
