| Nacra 5.5Uni - F17 or F18 square top work? #278037 03/19/15 05:26 PM 03/19/15 05:26 PM |
Joined: Apr 2002 Posts: 195 White Bear Lake, MN h17racer OP
Posts: 195 White Bear Lake, MN | I am curious to learn if anyone has tried an F17 or F18 square top sail on a 5.5 Uni?
Mast length is more similar with an F17 and I am aware the "F" sails require a boom.
Thanks, Tom G
| | | Re: Nacra 5.5Uni - F17 or F18 square top work?
[Re: h17racer]
#278038 03/19/15 06:34 PM 03/19/15 06:34 PM | MN3
| MN3
Unregistered | i own 2 f18 sails that i have used on my mystere 5.5 (30' mast) a gen 1 and a gen 2 capricorn sail
they worked well, were very powerful upwind but lacked size for downwind sans spin (the sail is designed to be used w a spin downwind)
i like them both very much but don't use them anymore unless my main is in the shop getting repaired | | | Re: Nacra 5.5Uni - F17 or F18 square top work?
[Re: h17racer]
#278039 03/19/15 08:41 PM 03/19/15 08:41 PM |
Posts: 6,049 Sebring, Florida. | Are you saying the 'stock' Mystery 5.5 sail has more sail area than the F18, square top sail? I would think any square top would project more sail area than the equivalent pin top? I know my F16 square top main has a LOT more sail area up high were you want it, than my Prindle 18 pin top. In fact, I run the Prindle pin head in big wind, just because it has so much LESS sail area up high.
Blade F16 #777
[Re: h17racer]
#278046 03/20/15 07:51 AM 03/20/15 07:51 AM | MN3
| MN3
Unregistered | nope, the f18 has more sail area
but i dont sail stock sails i use cut down tornado sails or other custom sails i have had made. | | | Re: Nacra 5.5Uni - F17 or F18 square top work?
[Re: h17racer]
#278074 03/23/15 09:11 AM 03/23/15 09:11 AM | MN3
| MN3
Unregistered | and the stock mystere sails has lots of roach and was designed for upwind and downwind sailing
the f-18 has no roach and is designed for upwind sailing and spin assist downwind | | | Re: Nacra 5.5Uni - F17 or F18 square top work?
[Re: ]
#278075 03/23/15 09:14 AM 03/23/15 09:14 AM |
Posts: 382 SE MI / NE IN | the f-18 has no roach and is designed for upwind sailing and spin assist downwind Perhaps I'm ill-informed, but I thought the amount of roach was defined by drawing a line from the end of the boom to the top of the mast and looking at the ratio of sail area that is beyond that line. If that's the case, I'd say the square-tops are very "roachy" | | | Re: Nacra 5.5Uni - F17 or F18 square top work?
[Re: rehmbo]
#278077 03/23/15 09:53 AM 03/23/15 09:53 AM | MN3
| MN3
Unregistered | let me re-phrase that the mystere sail has a lot more roach than an f18 sail PS i am not sure but i would think that roach is measured from the clew and head of the sail, not the boom / mast, but could be wrong the f-18 has no roach and is designed for upwind sailing and spin assist downwind Perhaps I'm ill-informed, but I thought the amount of roach was defined by drawing a line from the end of the boom to the top of the mast and looking at the ratio of sail area that is beyond that line. If that's the case, I'd say the square-tops are very "roachy"
183
guests, and 148
Mod | | Forums26 Topics22,405 Posts267,056 Members8,150 | Most Online2,167 Dec 19th, 2022 | | | |
